Question about Garden
What kind of hydralic fluid does a howard price turf buzter 727 and sundstrand hyd pump use
5 Suggested Answers
  • 11 Answers
SOURCE: need hyd Motor hyd p/n 23-3802 pump hyd p/n
Call Nova Hydraulics 317-322-0242 x103.
You will need the last 6 letters of your motor code.
A correct code example 23-3802AN-JSBJ.
Posted on Jul 02, 2010
  • 11 Answers
SOURCE: I have a sundstrand pump, model 15-2078. It has 4
The suction is at the front of the pump by the input shaft. The inlet can be set up as RH or LH by simply moving the plug to the other side.
The case drain is at the back of the pump housing between the 2 ports on the end cap that go to the hydraulic motor. There are 2 case ports 180 degrees from each other.
SOURCE: wanting to know if the Hesston 565A Round Baler
The 565a has an internal hydro pump and everything is controlled from the consul in the tractor.
Posted on Dec 12, 2010
  • 354 Answers
SOURCE: Dear Sir, We have one
First you need to find out if you have fluid in the cylinder,if low or empty it will not build up pressure.Hydraulics are famous for blowing seals and bleeding hydraulic fluid everywhere. If you have fluid its possible the switch valve is sticking to go up or down or not working. if that is working check the pump motor to see if the motor shaft is attatched to the pump
Posted on Feb 15, 2011
What kind of oil is used in a sabre hydrostatic transmission
John Deere transmission fluid recommendations
For Sabre? and Scotts? garden tractors and commercial mowers
This bulletin serves to clarify the transmission fluid service requirements for several models of lawn and garden product and commercial mowing equipment that were recently introduced. The operator's manuals for these products call for 20W50 synthetic oil, which is not carried in the John Deere parts system.
The following chart has been developed from the factory and engineering as approved replacements for 20W50 in each application, and should supplement the information previously published. Transmission fluid recommendations Machine Model Recommended oil for service requirements Sabre
2048HV
2148HV
2254HV
2354HV
2554HV
Plus-50®, 0W-40
or -John Deere Hy-Gard®
(bothoils are for top-off only) Sabre All other models Turf-Gard? 10W30
- or -
Torq-Gard Supreme?, 5W30 Scotts S2554 Plus-50®, 0W-40 Synthetic
- or -John Deere Hy-Gard®
(both oils are for top-off only) Scotts All other models Turf-Gard? 10W30
- or -
Torq-Gard Supreme?, 5W30 Mid-Ztrak
Mini-Z M653 through M665
737/757
717/727 Plus-50® II, 15W-40
Plus-50®, 0W-40 Synthetic Front-Ztrak F620
F680/F687 Plus-4?, 10W40
- or -
Plus-50® II, 15W-40 QuikTraks 647/657/667 Plus-50®, 0W-40 Synthetic Last modified: 23Jan10.
Apr 03, 2017 | Garden
I changed hydralic filter now I have no hydralics--HELP-- thanks colljim3@aol.com
you have air in the hydrolics ceck oil level add to it
Oct 16, 2014 | Garden
Where do you put hydrallic oil in a mtd white lawn tractor ,
First thing hyd. oil should not and can't come out the oil filter. May a hyd. filter. I'll try to find something. Most tranmission are sealed.
May 06, 2012 | Garden
Convertible top not going up.
LISTEN FOR HYDRALIC PUMP MOTOR OPERATION IN THE TRUNK AREA..IF YES YOU HEAR HYDRALIC PUMP MOTOR RUNNING MAKING A NOISE.CHECK HYDRALIC PUMP FLUID LEVEL BY REMOVING THE SCREW TYPE CHECK PLUG.PLACE RAGS UNDER THE CHECK PLUG.AND UNSCREW REMOVE THE CHECK PLUG. FLUID SHOULD BE 1/4 INCH BELOW THE CHECK PLUG HOLE.IF FLUID IS LOW ADD FLUID UNTIL FLUID LEVEL 1/4 INCH FROM THE PLUG HOLE.IF HYDRALIC FLUID WAS WAY LOW YOU NEED TO BLEED AIR OUT OF THE SYSTEM.MAKE SURE FLUID LEVEL CORRECT.START ENGINE AND TRY RAISING AND LOWER THE CONVERTIBLE TOP USING THE SWITCH.IF TOO MUCH AIR GOT IN SYSTEM.HAVE A HELPER WORK UP AND DOWN CONTROL SWITCH WHILE YOU MANUAL OPEN CLOSE CONVERTIBLE TOP BY HANDS BLEEDING AIR OUT OF SYSTEM.KEEP EYE ON HYDRALIC FLUID LEVEL WHILE BLEEDING THE SYSTEM..LOWER THE TOP AND TURN OFF ENGINE. BEFORE OPENING THE HYDRALIC PUMP FLUID CHECK PLUG BECAUSE FLUID WILL SPRAY EVERY WHERE..IF HYDRALIC PUMP CHECK OUT OKAY AND YOU DO NOT HEAR NO HYDRALIC PUMP NOISE.POWER IS GOING TO HYDRALIC PUMP.EITHER HYDRALIC PUMP MOTOR FAULTY OR FAULTY HYDRALIC PUMP RELAY BEST TO LET MERCEDES BENZ DEALERSHIP CHECK IT OUT...
Apr 30, 2011 | 2005 Mercedes-Benz Mercedes Benz SLK350
Dear Sir, We have one Sundstrand Turolla-200 make Hydraulic Pump, Model: TFP-200/6D SC51 LAA/9B , which is not building up hyd. pressure more than 80 bar. We are also not getting source of supplier for...
Feb 15, 2011 | Danfoss Sundstrand-sauer-danfoss...
Need hyd Motor hyd p/n 23-3802 pump hyd p/n 23-2058 mfg sundstrand explain me, how to order and where? thks
Jun 03, 2010 | Danfoss Sundstrand-sauer-danfoss...
I have a sundstrand pump, model 15-2078. It has 4 ports, I know the 2 that go to the hyd. motor. I am not sure which one is the suction and which one is the return
May 28, 2010 | Danfoss Sundstrand-sauer-danfoss...
I have a 3 stacked sauer hyd pump 1st one a spn3/55 d sc47 19m 2nd a snp2/17 d 3rd tfp100/3.2 d sc06/96 i'm looking for info an the flow gpm and pressure for each pump
Call Nova Hydraulics 317-322-0242 x 103 and you will get your information. What is the input rpm turning the pumps? The flow will vary depending on the input rpm.
Mar 13, 2010 | Danfoss Sundstrand-sauer-danfoss...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
