Question about Bose Lifestyle 48 System
How do I transfer stored music from Bose 48 to another storage device?
  • Hal Milton
    Hal Milton Apr 21, 2015
    I have stored years of favorite CDs on Bose Lifestyle 48. I do not wish to re-record the CDs again on another device such as an Ipad or Mac Aire. How do transfer the music stored on my BoseLifestyle 45 to an Apple product. yes, I own the CDs so it is not a copyright problem..
  • Hal Milton
    BoseLifestyle 45 should be "48"
  • 4 Answers
SOURCE: Bose Lifestyle 48 Error code 801
We had this problem. I called Bose, and they reported that the 801 error is a hard drive problem. The unit started squealing while I was on the phone to support, and the guy heard it. Said the hard drive was failing.
$200 to ship the unit to Bose to replace the drive. Wish they had a secret warantee for what seems like a common problem.
Posted on Jan 13, 2008
shaggyrat
  • 1224 Answers
SOURCE: BOSE LIFESTYLE LS 48 loose music library
if im hearing you correctly it sounds like you need a hardrive for the system as a back up easy to install and backs up all info for system
i hope im hearing this right to make sure i give you right help
Posted on Jun 08, 2008
cjackHD
  • 71 Answers
SOURCE: bose lifestyle fault code 802
Unfortunately, an 802 error is bad. That means hard drive (HDD) failure. This can happen to any hard disc drive, and there's no way to predict it and no way to fix it from home.
If you even try to troubleshoot it (reset etc), you could loose more data (music you've already stored to the system). If you try to access 'stored' music- the error will continue. Also, every time you turn the system off, it checks your HDD, and will probably cause the 802 or 801 errors to display again.
The "Format Unsupported" message may be related, but usually temporary. The 802 (and also 801) errors mean irreversible HDD damage so it doesn't matter.
Call Bose tech support immediately.. They can repair it for $165 and give a new 1 year warranty. And if it's already under warranty they will repair for free. In either case they will replace your HDD with a new one, and transfer any salvaged music files from your existing drive to the new drive.
Posted on May 31, 2009
  • 3 Answers
SOURCE: Bose lifestyle 48 won't play stored music.
Hard drive is ****..... impact computers.com hard drive number is MK4026GAX pull out of system and replace look at my other posting for 801 code!!! and dont be a ******** again and buy a bose!! TELL YOUR FRIENDS , FRIENDS DONT LET FRIENDS BUY BOSE!!!!
Posted on Mar 23, 2010
richroth
  • 9472 Answers
SOURCE: Bose LS 48 .Get failed
The problem exist because of the latest umusic software update disk. Since the release in January, some of these disks were corrupt. As a result, you get the error message 801 or 802 call bose. if you explain to the bose technical reps that the problem occurred right after you loaded the latest software release, they may consider swapping out the media center for free.
Posted on Jan 03, 2011
Cannot get USB mass storage on my moto e4 to transfer photo to computer
Connect the USB cable from the device to the computer.
From the home screen of the device, swipe down the Status bar.
Tap the USB prompt.
Tap File transfers.
On the computer, click the Start button, then click File Explorer.
Note: If Tap to choose what happens with this device pops-up, click on it, then click Open device to view files and skip the next step.
Click This PC, then double-click the device name under Devices and drives.
Double-click Phone to explore the content of your phone's internal memory.
Note: If a memory card is inserted in the device, double-click SD card to explore the content of the memory card.
Drag and drop files into the appropriate folders and/or subfolders as preferred.
Music files are typically stored in a folder titled Music.
Photos and Videos captured with the handset camera are typically stored in a folder titled DCIM.
Note: 3rd Party applications may store photos in different storage locations. Consult the application's support website or contact the developer for further assistance.
Once the file transfer is complete, disconnect the USB cable.
The files are now transferred.
Nov 03, 2017 | Cameras
How do I store music in my Bose system
You insert the CD into the console and pushe the "store" button on the face of the system. You will then see the message accessing gracenotes and the % complete. Once this % has reached 100% the music is stored in the system. Hope this helps
Nov 20, 2011 | Bose Lifestyle 48 System
FAILED 802 CALL BOSSE
I have the same problem since the Earthquake in Christchurch NZ.. Called Bose support centre and it seems the hard drive has failed and will need replacing, so all stored music etc lost. Cost to fix is roughly the same as getting a new media centre (DVD/CD) component. We are getting a new one through our insurance, apparently Bose Lifestyle's do not like being shaken around a lot or dropped.
Normally accompanied by a screetching sort of sound when you try to access stored music or turn the unit off.
May 08, 2011 | Bose Lifestyle 48 System
Bose lifestyle 48 won't play stored music. Everything else works fine
Mar 19, 2010 | Bose Lifestyle 48 System
Connecting ipod to Bose lifestyle 48
I have a Lifestyle 48 and called Bose today. It is possible all you need is a cord that is a 35mm headphone jack on one side and RCA jacks on the other. You plug it into the AUX jack in the back of your system and the headphone jack in the Ipod headphone spot. I got the cord at Best Buy for ten bucks. It works GREAT!
Aug 26, 2009 | Bose Lifestyle 48 System
My bose was playing stored music and then for no reason it has stopped. can play cds ok
My bose stereo system plays a cd for a few minutes then stops, what is this, and it says failed code, call Bose. How do I fix this.
Aug 01, 2009 | Bose Lifestyle 48 System
Bose lifestyle fault code 802 hi there- i have a bose lifestyle 48 and on display it reads format unsupported when i try to listen to cd's gut not on dvd's - in addition i am unable to store music into the...
May 31, 2009 | Bose Lifestyle 48 System
Storing disk problem
Are you trying to store a few cds one after another? approx 7.
When you store the cd's, the Bose systems temp stores on unit then transfers to perm location.
Waits few hours then try agian, overnight would be good.
To prosess faster turn system off- normally a store gracenote message comes b4 it.
turn unit off to make transfer a bit faster because it only doing one thing.
Cd name can be labeled once on there not sure about songs but i think you can.
Is this burnt Cds, if so when you r burning them, go into options and select music and data, something like that, If ya burning from orginal cd. Easier then typing with remote.
hope this helps:)
May 07, 2009 | Bose Lifestyle 48 System
May 16, 2008 | Bose 3·2·1 II System
Storing music in BOSE 38 system
The Bose uMusic system is a very powerful music management tool. The uMusic storage process involves pulling information from your CD (approximately 3-5 minutes per CD) then storing this information into a buffer area for processing. The buffer area will hold approximately 10 CDs worth of data. After the buffer is full, it must stop taking new data and process the data already in the buffer. The processing time is about 30 minutes per CD.
This means 5 - 6 hous of processing per 10 CDs. So be patient. This is not unusual. Other "media servers" such at Escient and Audio Request take 24 - 48 hours to process a full buffer. There is a lot of data processing going on during this time period and the result is amazing music management once completed.
I recommend clients load 10 CDs in the morning and let it process till after lunch. Then another 10 CDs and let it process until after dinner. Then another 10 CDs and let it process overnight. This routine completes 30 CDs per day.
If you have 100 to 400 CDs an automated services is available from HouseSys.com. This is the only automated service available for this system.
Jan 20, 2008 | Bose Lifestyle 38 System
Bose Lifestyle 48 System Logo
307 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
