Question about Hayward Pool & Spa
How to take Hayward aqua pod gold line series out of bypass mode on spa heater
  • 22 Answers
SOURCE: heater temperature control buttons
The board is bad. The part number is IDXLCPA1930. Expect about a $400 replacement cost.
Posted on Dec 21, 2008
  • 61 Answers
SOURCE: Hayward Spa Heater ignites for 2 seconds and shuts off.
Sounds like this is a flame sensor issue. It is not detecting the flame.
Posted on Apr 04, 2009
SOURCE: Hayward H300 Spa Heater will not fire up
try to replace the thermo sensor it is located on the left side of tghe unit and has 3 wires running to it.
Posted on Jun 13, 2009
  • 4 Answers
SOURCE: my hayward heater gives a LO error when trying to
One of your limits is not working or not wired up. An easy way to check the limits - Water pressure switch, Hi limits, air pressure switch all of which have 2 wires going to them. Unplug one item and connect the 2 wires together ( paper clip works fine ) Then retest, if problem does not go away remove paper clip and reconnect wires and move to the next limit. The limits are located in the black plastic header. Always make sure water is flowing through the heater at all times while checking the limits.
Posted on Mar 01, 2010
  • 64 Answers
SOURCE: H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1: how do i fix the AO code on my hayward heater?...
AO will apply to your blower, blower tubing, or blower vacuum switch. You need to check these items.
Posted on May 20, 2010
Had a power outage yesterday now heater won't ignite. No error codes.
bo = 'Bypassed Operation'
heater is now controlled via your automation system.
Create a heat call, turn solar off if active.
Heaters should be set to auto on.
Mar 07, 2015 | Hayward Pool Products Hayward Universal...
Hayward h250
Hi this is John the Hayward tech. If you have a millivolt heater it will only have one therm and an on and off switch. What you are describing is a electronic heater. Please call our tech line at 908-355-7995
Aug 28, 2014 | Hayward H Series Millivolt 250,000 Btu...
Manual reset switch
sounds like heater is getting too hot make sure if plummed with a bypass it is only open half way if no bypass make sure filters are clean if ok check manual bypass maybe spring is stuck open
Aug 06, 2014 | Hayward H Series Pool & Spa Heater...
How do I fix "Filter VSP Communication Error" on my Aqua Pod
the VSP error is a code from the pump and not the controller or control system. the only way to clear this is to turn the breaker for the pump off for about 30 seconds to allow the electronics to reset.
Jul 09, 2014 | Hayward Pool Products Aqua Pod
Gold line aqua pod will not keep time the time stops
need more info is there a place for a battery in the box? most have a 9 volt to keep the time the hand held doesnt keep time its just a remote
Dec 07, 2013 | Goldline Aqua Pod Wireless Remote
Timer for pool does not stay on aqua pod
Check bateries on control panel. Next check the relay. Batteries in hand held too.
Dec 06, 2013 | Hayward Pool Products Aqua Pod
Aquapod doesnt sync with heater any more
what type the heater is communicating to aqualogic control is RAYPAK digital 2100 ? also go to outside where the aqualogic control is and look for diagnostic in control look for water temperature sensor connecedt to aqualogic and see what that say,
Jun 15, 2013 | Hayward Pool Products Aqua Pod
Hayward Heater H series 400 BTU will not start
This is a normal display when heater is being controlled by a remote thermostat. No service is required. If heater is not being controlled by remote thermostat, change setting by using the MODE key to put the heater into STANDBY. Press and hold the DOWN key and then press and hold the MODE key. HOLD down both keys for 3 seconds until the indication "bo" is removed from the display.
The key to this is DOWN first and then together with MODE, both for 3 seconds.
Make sure the display is not showing "BD".
Jul 06, 2017 | Hayward H Series Pool & Spa Heater 400k...
Same problem pool heater shows hayward pool heater bo error
BO means that you have bypassed operations. ie automation. if no automation is present then press and hold the Down arrow and Mode button for 3 seconds.
Aug 01, 2009 | Hayward H Series Pool & Spa Heater 400k...
HAyward H series gas heater 2500i
There is a thermistor temperature sensor beside the inlet union on the heater that goes bad, it looks line a stainless steel nut with wires on it. You can unthread to replace it and it plugs into the board behind the display. The LO means low pressure probably caused by pressure switch adjustment.
Jul 07, 2009 | Hayward Pool Products Hayward 200k Ng H...
Pool & Spa Logo
57 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
