Tv won't connect to modem - Computers & Internet
    Top Expert:
  • Computers & ... Master
  • 52,126 Answers
Most older tv,s won't
Posted on Apr 19, 2015
I don'tsee what i just purchased. 2 ganes I alredy have won"t run now. on occasioun it tells me i have no connection-not possible Please help me
it is possible,just because you are connected wirelessly,doesn't mean that you are connected to the internet,you ARE ONLY CONNECTED TO YOUR MODEM,unplug your modem from the internet and power for 30 seconds then plug in the internet wire then power and let it reboot,then see how the connection is.if you have more things connected to the modem,either wirelessly(like laptop) or wired(like xbox or tv),they will use your bandwidth which will cause connection errors on a tablet
May 28, 2015 | Tablets & eReaders
Lgv909 can not connect to wireless
Its running on a 5ghz and the modem or router is 2.5ghz. Upgrade your modem or router that it has a 5ghz and a 2.5ghz option
Dec 04, 2013 | LG Optimus V909 Android
D2 tablet 7" android 4.1 that won't connect to network
what you should do is make sure your modem is activated because if it is not then you can connect to a network you can connect but is has not internet access
Apr 07, 2013 | Arris Nvg510 At&t Uverse High Speed...
My modem and router won't work simultaneously
They chain together. Connect the modem first to the ISP drop. Then the modem to the routers main port. Then the connect the PC to the router.
Modem > Router > PC
Jan 09, 2013 | EnGenius Technologies ESR-9752 300mbps...
I can't connect to the wireless modem i just bought it says there is a connection but the internet won't work,how do i fix it??
u got the modem but need the adriver also to run the modem .so instal the modem driver from acer website
Mar 08, 2012 | Acer Aspire 5742Z-4200 Notebook
Thomson TG585 v8 connection problem
this is way too vague, try power cycling your modem and router. also make sure you have not accidentally hit the standby button (teal oval on front). let me know what lights are on and or flashing and what lights are not. that modem's GUI can be accessed by entering 192.168.100.1 in the browser bar and you may be able to diagnose your problem from there.
Nov 01, 2011 | RCA Thomson Digital Cable Modem (DCM305R)
My iphone won't connect to my sbg6580 motorola surfboard
I had to restart my IPhone and now I cannot get my Motorola Modem to join onto my Iphone 4. I have the password and the serial # for the modem, but nothing will work. Please help
Oct 22, 2011 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
New modem installed and router won't work now
First step is to make sure if the modem is working. Connect your computer directly to modem with ethernet cable and see if you can log on to internet! if yes
next step connect modem to your router's WAN port with an ethernet cable and then connect your computer to one of the LAN ports of router with ethernet cable. Power down all devices and power up modem first wait until all lights are on and then router wait until all lights are on then your computer! 9 out of 10 times this works! try good luck!!
Sep 23, 2011 | Dynex 4-Port Ethernet Broadband Router...
I have a samsung tv , and im setting up my INTERNET@TV , it ticks off everything but the Gateway Ping ! Please Help
If the Gateway Ping test fails, then your TV is not communicating properly with your Router or Modem.
To resolve this, follow these steps:
  1. Power off your TV, Modem, and Router.
  2. Unplug the power for your Modem and Router.
  3. Make sure the ethernet cable is securely connected to both your TV and your Router or Modem.
  4. Plug in your Modem and turn it on.
  5. Plug in your Router and turn it on.
  6. Make sure your IP Address information entered into the TV during the Network Setup matches the information from your Router or Modem.
  • If you are using an Automatic Setup (most users), skip this step.
  • If you are using a Manual Setup (advanced users), contact your network administrator to determine what the correct IP Address information is.
7. Run the Network Test again.
  • If the Gateway Ping test passes, but another test fails, click here to go back to the list of Network Tests.
  • If all tests pass, the TV is successfully connected to your network.
  • If the Gateway Ping test fails again, see below....
If the Gateway Ping test fails again, there may be a problem with your network setup. To determine if there is a problem with your network, follow these steps:
  3. Connect your ethernet cable directly to the TV and Modem.
  5. Power on the TV and run the Network Tests again.
  • If all tests pass successfully, then there is a problem with your Router setup. Contact your network administrator or router manufacturer for information on setting up your network.
  • If all tests do not pass successfully, there may be a problem with the TV. Connect another device (such as a Computer) directly to the modem.
  • If the other device connects to the internet, then the TV will require service. Click the Create online service request button below to have the TV repaired.
  • If the other device does not connect to the internet when directly connected to the modem, then there may be a problem with your modem. Contact your Internet Service Provider for help on troubleshooting your modem.
(from Samsung support)
Hope this helps. -Sa_Les_Ski
Feb 28, 2011 | Televison & Video
Computers & Internet Logo
192 people viewed this question
David Payne
David Payne
