How do i size up a new high efficency furnace and AC unit?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
There is a 'design temperature' for your locale that must be known for the calculations of the 'heat loss' and 'heat gain' of your structure. Here in the Midwest, those design temp are 5 degrees F for winter and 95 degrees F for winter.
Your target indoor temp for summer should be 75 -78 degrees F and the indoor target temp for the winter should be 65 - 70 degrees F.
There are on line calculators that determines your losses and gains as long as you enter correct information as to the type of windows, wall insulation and construction, attic insulation etc. They are reasonably self-explanatory.
Also, you should really take advantage of the free estimate offers of local HVAC contractors to see if they determine the same capacity system is required as you come up with. If not, you will be more readily prepared to ask reasonably intelligent questions about the system you need.
Posted on Apr 20, 2015
    Master:
  • 456 Answers
There are factors in estimating the amount of btu needed, insulation, sun facing, windows, and basicaly How to Calculate BTU Per Square Foot
Why does power to furnace needs to be shut off for furnace to work again?
There's a problem with the ignition sequence. It's most likely a bad flame sensor, assuming a high efficency furnace. I'd replace that first (on my own) before calling a tech in. $20 part versus $250 on site repair bill.
It could also be a bad ignitor (or something else entirely), but I'd stary with the flame sensor. It will get worse, until the furnace won't run at all.
Dec 15, 2016 | Heating & Cooling
Approx 45 mins after central heating comes on, what causes a reasonably loud vibration/expansion noise from the roof?
Hi, it may be that you have a blockage some where in the unit or piping . Best to get the whole unit checked out.
Apr 05, 2016 | Alpine AHDGAH056 56,000 BTU LOW-PROFILE...
What is the tonnage of a carrier furnace model number 58gp100-2
It can handle five tons, or a 60000 btu ac. Tonnage is a measurment for the ac, 1 ton-12000 btus. The ac dose the cooling. the furnace simply blows the air, so if its a good furnace, and sized right, no need to replace it. Simply add the split system to the existing furnace. If you want the tonnage of the ac size, let me know your homes squarefootage, age, condition. Do NOT include the basement in the sq. ft.
Apr 07, 2015 | Heating & Cooling
Furnace thermocouple
older standard efficiency furnaces have a thermocouple. mid and high efficency models do not. they are electronic ignition with a hot surface igniter
Apr 16, 2014 | Goodman Heating & Cooling
Ruud Achiever 80. How do I replace the filter?
if its not on the outside of furnace where cold air duct goes in, and you dont have a high efficency filter, which may not look like what your used to, it will be on the inside of the bottom door where blower is located. If its a standard filter, it should be changed monthly, so you may have a really really dirty furnace and this requires immediate attention to avoid fire hazards and part/blower failure and overall efficency.
Dec 22, 2011 | Heating & Cooling
I have a RUUD Furnace / AC and need pleated 21 x 28 x 4 filters with #10 efficency rating.
http://www.thefilterstore.com/
WITH THIS LINK YOU CAN ORDER CUSTOM MADE PLEATED FILTERS FOR YOUR FURNACE
HOPE THIS WAS HELPFUL
Mar 31, 2010 | Ruud UBHC Air Conditioner
Wiring
This will depend on type of system, standard high efficent furnance or heat pump. The orange terminal is for the reversing valve on the heat pump for the cooling cycle. Your best bet would be to get a thermostat that is fitted to your furnace instead of a universal t-stat. If I knew what brand of furnace, I could be more help.
May 27, 2009 | Honeywell Heating & Cooling
Blower fan runs to long
ther might be dip swiches on the circuit board you might have to change
Dec 17, 2008 | Honeywell Power Humidifier: Furnace...
Carrier Infinity DC motor drive problems
Contact the company that installed the unit. Its new, under warranty, Anything you do could void the warranty. If they do not take care of the problem without charges contact Carrier and tell them what's going on. The company who installed the unit is responsible for making it run correctly. Good luck. kstfas
Aug 26, 2007 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
