Question about Onan Microquiet RV Generator 4000 Gasoline 4.0 Kyfa/26100
It starts but won't stay running.is there a fuse somewhere
Car won't stay running
If the problem only happens when the engine is cold, a bad electric sensor is likely to blame. If the car stalls even when the engine is warm, the cause is likely a faulty electric fuel pump.
Why is it that my car starts but won't stay running? ' Reference.com
https://www.reference.com/vehicles/car-starts-won-t-stay-running-6449388a9326285d Car won stay running Google Search
Dec 15, 2016 | Cars & Trucks
Blown fuses
sounds like a bad ground somewhere or check your ground wire on your starter and even your igniton switch cause if they go bad then your car either wont start or wont stay running
May 14, 2013 | 2001 Chevrolet Lumina
Will start but won't stay running
Try changing the fuel filter. Chances are when it ran out of gas it sucked all the old gunk and stuff into the lines. If that doesn"t work you may have to take it to a professional to have the gunk sucked out. Also after you change the filter dump some fuel injector cleaner into the tank that should clean up any remaining residue.
Feb 05, 2013 | 2000 Pontiac Sunfire
My asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
Dec 15, 2012 | 1996 Oldsmobile Cutlass Ciera
BIKE WON'T STAY RUNNING AFTER JUMPER CABLES ARE TAKEN OFF....
Sounds like the battery may be either low or shot. Place it on a trickle charger overnite to see if it will take a charge. Once you get the bike to run without needing jumper cables to keep it running, check the charging system. Easiest way to do this is to get a battery voltage reading with a multi meter before starting the bike. After the bike is running, place the meter leads on the battery and work the throttle to get the revs up to about 2000. Meter reading should be somewhere around 13.8 to 14.2 voltsDC. It not close to these readings, you have a charging system problem.
Oct 17, 2012 | Harley Davidson Motorcycles
John Deere 310G that the hydraulics quit working
You just go to the link I attached I'm sure you will get the solution of your problem.
John Deere 310G
May 29, 2017 | John Deere Garden
Bogging
Make sure the fuel pump is kicking on it won't hurt to check the relay but I have never seen one bad yet it could be the plug on the plug on the end of the wires that plugs on the pump this run hot and it burns the ends alot several fuel pumps are replaced because of this make sure you have power at the pump if you can't hear it run it will only stay powered for a few seconds and then kick off. so you might need someone to turn it on while someone checks the power.
Dec 29, 2011 | 2000 Pontiac Grand Am GT
Unit just quit. won't start up. press start button and won't even light up
please provide the model number of the Samsung dishwasher.
if none of the lights light up, then a fuse might be blown somewhere. If the problem is the start buttion does not start the dishwasher , then the door latch switch could be faulty.
Jun 23, 2011 | Samsung Dishwashers
Onan Microquiet RV Generator 4000 Gasoline 4.0 Kyfa/26100 Logo
44 people viewed this question
Top Onan Electrical Supplies Experts
Lawrence Oravetz
Jeff Hogancamp
Jeff Hogancamp
Are you an Onan Electrical Supply Expert? Answer questions, earn points and help others
