Question about Ovens
My range oven has tripped the power and now it's not heating up. However this grill is still working. What could be the problem?
One of the elements has gone
this tripped the power off
now the element is prob switched off
if you switch on the unit again it will trip or not work and do nothing to the power
you need a new element
try ebay if you want to do it yourself
usually one screw and two connections per element
{power off at the mains to the unit}
or what i would do is buy the element and get a tech to do it
saves time and added cash they will add to the cost of the parts
Posted on Apr 19, 2015
SOURCE: Heat Problem
Found this link on another website: http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewtopic&t=10044 I've sent off for the element. I'll let you know how I get on with fitting it.
Posted on Oct 30, 2006
barkencoa
  • 3463 Answers
SOURCE: Whirlpool AKZ451 oven not working properly
If the fan is still working ,then you need a new oven element fitting, it will have blown, there by causing trip to operate.
Plz rate this solution .
Thanks.
Posted on Dec 12, 2008
  • 1214 Answers
SOURCE: bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
Posted on Jan 14, 2009
  • 12 Answers
SOURCE: indesit fde20 main oven wont heat up
sounds like the circular element at the back of oven has blown.
Posted on Oct 24, 2009
  • 69 Answers
SOURCE: my omega europa oven is not heating up .grill fan
Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
Posted on Mar 18, 2010
Using grill and everything tripped now grill or oven wont work
Electric grill most often uses heater element to heat up.Maybe your heater elemen is shorted to oven body thus tripping the safety device.
Check your grill system using insulation tester.If the insulation is low check the heater elemen insulation and if defective replace them.
Jun 17, 2012 | Zanussi ZBF360 Electric Single Oven
Smeg electric oven model sa22xmf/7 not heating at all after power turned off
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Nov 29, 2011 | Smeg Ovens
Heating elements in fan oven not working
Nov 26, 2011 | Smeg Ovens
Hi Our oven wont turn on, has power as the display panel has a little "A" luminated on the left of display screen but nothing else operates, no fan, Grill, timer. please advise
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Mar 24, 2011 | Smeg SE210X/1 Stainless Steel Electric...
The oven was on and working..then the electric tripped and all power went off...after putting the switch back up on the fuse box everything on the oven started working but it does not get...
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please How to Video Tutorials on Domestic Appliances
Mar 04, 2011 | Zanussi ZBF260 Electric Single Oven
Oven not heating
blue waffle is nice and i like to pop fish up my **** go to google and type in lol fish and then click im feeling lucky and do the same with blue waffle xx good look it could help your oven.
Mar 31, 2010 | Neff B1421 Electric Single Oven
Fan not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
Mar 12, 2010 | Zanussi ZBQ665 Electric Single Oven
Smeg oven
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
EOU6330 grill doesn't heat-up all the time.
hi Step 1: Check the power cord, the plug, and the outlet. Then look for blown fuses or tripped circuit breakers at the main entrance panel or at a separate panel.
Step 2: If the range is receiving power, set the timer on the range to the MANUAL position.
Step 3: If the element still doesn't heat, turn off the power to the range and test it with a VOM set to the RX1 scale thank u................
Sep 11, 2008 | Electrolux EOU6330 Electric Double Oven
Ovens Logo
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
