Question about Kenmore Kitchen Ranges
How do I set the clock on my Kenmore 4.2 cu ft gas stove with a broil and serve drawer
I have tried to set the clock by hitiing th set the clock button, then using the up or down buttons to get to the correct time. I have then hit the set clock button and after a very short time I heard a ding ding and the clock went back to the original time. I tried the stop button and the same thing happened. I also tried just setting the time and leaving it alone. All of these methods reverted back to the original time
Try press and hold till it beeps as set
Posted on Apr 19, 2015
The bottom draw on my oven range is not lined up
Has a round track bearing come off? That just happened to me the other day, and I found it under the drawer. Just poped it back in.
Jan 24, 2013 | Whirlpool WFC130M0AW 30" Freestanding...
Fridge freezing everything
THIS REF. WORKS BEST WITH THE REF. SET ON 4 OR 5 AND THE FREEZER AT 2 1/2 OR 3. HAVING A HIGH FREEZER TEMPATURE CAN HAVE FREEZING IN THE BOTTOM DRAWER OF TH REF. MAINLY BECAUSE OF THE RETURN AIR VENT TO THE FREZER IS BEHIND THAT DRAWER.
Apr 25, 2010 | Maytag 21.9 Cu. Ft. Bottom-Mount...
Kenmore ~ bad smell upon first use of broil function
If you pull out the drawer at the bottom of the stove, there is a brass fitting that needs to be tightened with a 1/2" wrench.
Dec 08, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Bake and Broil not working
After you hit the function you want...bake or broil...click the up arrow.  That should give you the default temp of 350 and the unit should light.  Now adjust to the temp you want.
Nov 28, 2008 | Ovens
Kenmore Oven
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
PS go to searspartsdirect.com, type in your model number for the exact replacement part number.
Oct 27, 2008 | Stoves 500SIDL Gas Kitchen Range
Product manuals
Product manuals are available for most in-stock items.
Order a product manual by calling 1-800-366-PART (1-800-366-7278). Or download a free product manual at ManageMyHome.com.
Aug 01, 2008 | Kenmore 33169 Gas Single Oven
very likely your oven control it does those things without any input from the oven so if it doesnt do what it is supposed to it is likely bad
Aug 01, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 9114554590 will not bake or broil
The clock/display panel is faulty. There are a few relays on the display that have to work. If the clock is just flashing once with each keypress the the relays are not functioning. The clock/diplay will need to be replaced
Jun 04, 2008 | Kenmore 75022 / 75024 / 75029 Gas Kitchen...
Kenmore Stove (coils)
if the timer is on hit cancel or reset then hit clock and then use up and down arrows to set them also locate the serial plate and give me the mod num will be a buch of num like 106.48062890 around the bottom drawer on the body of the range or around the oven door if the eoc or clock isnt lit go turn the breaker off for 5sec and let me know
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 3.8 cu. ft. HE4t King Size Capacity
remove feet set on stand and put the 4 screws in 2 in the front 2 in the back the remove the drawer and level the 4 legs on the stand then lock the lock nut if you git a little vibration raise the front washer up 1/8 in usely will take care of it
May 03, 2007 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kitchen Ranges Logo
89 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
