When powering on tv with remote or the tv power button it clicks on and then right off.
    Top Expert:
  • 6,702 Answers
I can tell a long story, but the TV is defect. Would it make any difference what I could tell you it is the main bows, the backlight to the power supply? if not, please contact a tech to a repair shop. First ask them what it will cost, because today net TV's cost less than the ones you bought 1 or 2 years ago. It could be w repair is more expensive than a complete new TV, same size but a better resolution.
Posted on Apr 19, 2015
    Top Expert:
  • Televison & ... Master
  • 74,482 Answers
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Apr 20, 2015
Philips 52pfl5704 no screen image
Sounds like main board fault. Contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 28, 2014 | Philips 42PFL3704D LCD TV
How to shut off manually
UN55D6400UF TV Will Not Power Off If your TV is on but will not power off when you press the power button, you could be having an issue with your remote control or a faulty circuit inside your TV.
To determine the source of your problem, follow these steps:
  1. Power the TV on if it is off.
  2. Unplug the TV from the wall outlet for 30 seconds, and then plug the TV back in.
  3. namo_fileview.jsp?type=nfs&pid=decisiontree&did=57355&cid=yokn68wxkhym@namo.co.kr&sep=%7c
    1. Press the POWER button on the remote control.
    2. [img src="http://support-us.samsung.com/cyber/namo/namo_fileview.jsp?type=nfs&pid=decisiontree&did=57355&cid=79HKC8BOY9YC@namo.co.kr&sep=%7C" height="51" border="0" width="50">
      • If the TV powers off when you press the POWER button on the remote control turn the TV back on continue to Step 4.
      • If the TV does not powers off then there is a problem with the remote control. Click here to go to the Remote Control troubleshooting section of this guide.
    1. Press the POWER button on the TV.
      • If the TV powers off with the remote but does not power off with the power button on the TV there could be an issue with the touch sensor on the TV. Before setting your unit up for service try these two things.
        1. Try sliding your finger accross the power button.
        2. Have other people try using the touch buttons on the TV.
        3. If either of these two options work then there is not an issue with the touch sensor on the TV. There are many variable that can limit the conductivity of a persons fingers. The conductivity of your fingers might not be enough to easily control the touch sensor on the TV.
        4. If the TV does not power off when you press either the POWER button on the TV or on the remote control, then the TV will need to be serviced. Click the Create online service request button below to have the TV repaired.
Mar 26, 2014 | Samsung UN55D6400 - 55" 1080p 3D LED LCD...
When i turn it on it clicks and the goes right back off
New set?
If you're turning almost any TV on by the manual power switch on it, thats Standby mode.
The next step it's waiting for is the ON command from the remote control.
There are two main methods remotes use to go to ON from Standby:
Press the Power button for both on and off commands
Press any 1-10 (or 1-0) button for on, press power button for off.
Sep 24, 2011 | Sanyo DP42848 LCD TV
Samsung AK59-00123A remote to a M261VP vizio tv
Hello
[1] Switch your television on
[2] Point the remote control towards the
television
[3] Press and hold the TV POWER button, and
then enter the two-figure code in the table
to the right that corresponds to the brand of
your television by pressing the appropriate
number buttons.
If your television is compatible with the remote
control, it will switch off.
The remote is now programmed to operate
the TV.
The code for Zenith TV is [TV POWER + 63]
Sep 20, 2011 | Zenith ZEN700 Remote Control
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
The tv was left on and gone off wit a red led showing under the clock on the front of the tv due too the remote being broken we dont know how to put the tv on
On the right side of the tv bazel frame have manual buttons,like a power button,like 2 channels buttons one for up and one for down and a Meneu button.Push the tv manual power button,ur tv should have power and tv will be on.Or try website like Remotes.com to buy a new remote same as ur original tv remote.
Dec 02, 2010 | Panasonic VIERA TH-37PX80B 37 in. Plasma...
I would like to use the 'tv power' button on the remote which came with my zenith digital converter box to turn on and off my 20" LG flatscreen. The remote is a 'AKB36157102'.
hold down the TV Power button while clicking the Channel Up (or Down) button. after 2 or 3 clicks, your TV should turn on (or off)
Aug 28, 2010 | Televison & Video
I went turn on my tv the picture came on then off
Picture turned Yellow because the Blue CRT stopped working. Power turns off because the power supply is indicating a fault. you probably lost your HT (high tension [voltage]) power supply on the blue CRT (picture tube). Professional assistance is recommended. HT power supply CAN DELIVER A LETHAL SHOCK even when the set is unplugged.
Jan 15, 2009 | Philips 46PP9302 46" Rear Projection...
RCA model# F26071ES television set clicks on, then immediately off when using power button on TV or by using remote.
This should help you.. use the TV button on the remote instead of the power button. If the TV is working properly and the buttons aren't damaged this should do it.
I know mine clicks off as well.. unless I use the TV button to turn it on.
Chey60
Nov 01, 2008 | Televison & Video
Vizio L32 HDTV 10A-remote
Try a new Remote control, and if that doesn't fix the problem, it may be a remote sensor in the set. Hope this helps. Have a great weekend
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
