Question about York Furnace Draft Inducer Blower Fasco # A224
Is there a high effecency furnace substitute?
Small dual gas turbine and use electric heating and supplies your home also ....
Posted on Apr 19, 2015
Furnace has water under it, why? Its a Dayton gas furnace.
There are several questions that need to be answered about what type of system you have, but i found this posting that may help:
As your gas furnace runs, is there water leaking at the base? Is the furnace's air filter wet, too?There are a few things that could be happening here. But if you have a high-efficiency furnace, here's the most common cause: a condensation leak.
We'll explain why a furnace creates condensation, and what's causing it to leak out of your furnace.
Note: You'll know if you have a high-efficiency furnace if:
  • The yellow energy guide tag says your furnace's efficiency is 90% or higher AFUE.
  • The vent/flue pipe is white PVC as opposed to metal.
Why a high-efficiency furnace creates condensation
How in the heck does a high efficiency furnace create condensation/water anyway?
It's all about how the furnace extracts heat from combustion gases.
A lower-efficiency furnace extracts some heat from combustion gases and then quickly vents them out the flue pipe.
But a high-efficiency furnace, to extract more heat, has 2 heat exchangers. These allow the furnace to extract heat from the gases for a longer period of time. This causes the combustion gases to cool and then condense.
That condensation then exits out your home through a drain. But if that water is pooling around the furnace, there's a problem preventing it from draining properly.
Causes of a condensation leak around a high-efficiency furnace
  • Clogged condensation tubing
  • Clogged condensation drain
  • Breaks in the condensation line
  • Issues with the condensate pump (if you have one)
You'll need a furnace technician to diagnose which of these is the issue and then fix it.
Other causes of leaking water around a furnace
If you have a conventional, standard-efficiency furnace...then its flue pipe may be incorrectly sized.
If you have a whole-house humidifier connected to the furnace...there may be an issue which is causing the humidifier to leak into your furnace. Your humidifier should be getting annual maintenance from a professional to prevent this.
Dec 13, 2016 | Dayton Heating & Cooling
Tip
2 Stage Furnaces More Comfort and Save Money
Two stage hot air furnaces can save you money and make your high efficiency furnace even better. With your furnace running at low fire instead of cranking up to the highest heating output in mild weather you can be more comfortable while saving money.
Many people think that they are getting the best they can get by buying a high efficiency single stage furnace. What they often don’t realize is that they could do better yet and for a few dollars more have a high efficiency 2 stage furnace that could keep them much more comfortable.
There are 2 stage hot air furnaces that are now available that will only run at half fire if the full fire is not needed. With a two stage furnace in mild weather when only a little bit of heat is needed, the furnace will have longer run times on low fire. This will keep you room temperatures from getting too hot before the thermostat reacts and shuts the furnace off again. This will help to keep your temperatures from overshooting the set point and help to keep your home much more comfortable.
Many of these two stage furnaces also have variable speed blowers that run at a lower speed when heating on low fire. This will also help to save money on your electric bill, because these blowers use very little electric when running at these low speeds. Air noise from the blower running at a high speed is also reduced.
If you are thinking of replacing or installing a hot air furnace, make sure that you ask your contractor to give you a price on installing a two stage furnace. The price difference probably will not be much higher than a high efficiency single stage furnace. However the comfort of the two stage furnace coupled with the electric savings will make the extra money well worth it.
on Dec 14, 2009 | Heating & Cooling
Atwood 38591 Excalibur xt 1522 LP two stage furnace. Operates on high fan only
Hi Dave. I'm Roger. Its normal for a furnace to shut down completely when the set point on the thermostat is reached. The first and second stages are used when the temp. gets close to set point. The heat output drops to its low stage at around 3 degrees before set point. Check your owners manual for specifics on the fan though.
Mar 14, 2014 | Atwood 38591 Excalibur XT Furnace 1522 15K...
Atwood 1522 LP furnace fan operates at one speed only
Furnace only works at one speed, high and low fan is usually used for AC. It never has had 2 speeds on furnace correct? Furnaces usually only have 1 speed, except for some home models.
Anyone know about high efficiency furnace?
There is a lot of calculations involved in this. You need to know the sqaure footage of living space, the R value of the insulation, the construction type, size and number of windows etc.
Jan 20, 2014 | Coleman Gas Fired Condensing / High...
Igniter isnt lighting
IF YOU LOST POWER WHEN FURNACE WAS RUNNING IT TRIPPED ROLLOUT SWITCHES AND POSSIBLY THE HIGH LIMIT . IN CENTER OF ROLLOUT SWITCHES IS A LITTLE RED BUTTON THAT YOU RESET . YOU CAN ALSO TRY FINDING HIGH LIMIT WITH POWER SHUT OFF TO FURNACE PULL BOTH WIRES OFF HIGH LIMIT AND USE PAPER CLIP TO JUMP BETWEEN THE TWO WIRES MAKE SURE YOU DONT SHORT OUT AGAINST ANY METAL WHEN YOU TURN BACK ON IF IT WORKS YOU NEED A NEW HIGH LIMIT SWITCH.
Jan 08, 2014 | Coleman 7990-319p Evcon Gas Furnace...
I have an old Intertherm gas-fired furnace, Model MGH-055AB which ceased operating last night. It was quite warm when I arrived home, and when I set the heat up a little, began to hum, but the fan would...
Tom P's answer is generally correct: The motor start capacitor is usually not the problem. However, in some cases, particularly on older furnaces, where there were capacitors of certain make and production run will prematurely fail. This happened in March on a mobile home HVAC unit where both the blower fan and condenser fan motor capacitors failed open circuit. Both caps were of the same Mfg, and production lot.
Here is a suggestion (for you or an electrically inclined friend): Locate a substitute motor capacitor having similar Mfd (or MF) and Voltage ratings. Remove power from the unit. Reach into the blower squirrel cage and spin it to verify that the shaft is not frozen. Pull the wires from the existing capacitor noting color and location. Connect the wires to the substitute capacitor and secure it place. Apply power and turn on the blower. A no start? Motor replacement time.
Nov 08, 2011 | Intertherm P3RA-048K Air Conditioner
Coleman gas furnace. Burner will re-fire for a few seconds during the cooldown. Model G8C07512MUB12A
This is a little complicated because it can be several things and you need to provide more specific info....It could be your furnace is shutting off on the High Limit...which means your furnace is running too hot...check the filter , return air vents etc would be an airflow problem...dirty blower....Furnace can be too big for your house....when the furnace shuts off on High LImit , the fan will continue to blow air , cooling it down as usual and once the furnace cools enough to reset the high limit trhe furnace will Ignite again as long as the thermostat is still calling for heat . The furnace could also be running too long and getting too hot....your Ductwork can be too small...many factors come into play
Oct 25, 2009 | Heating & Cooling
York  Furnace Draft Inducer Blower Fasco # A224 Logo
51 people viewed this question
Top York Tools & Hardware - Others Experts
Paul Carew
Lawrence Oravetz
Are you a York Tool and Hardware - Other Expert? Answer questions, earn points and help others
