Question about eMachines Computers & Internet
My laptop does not want to charge, I've checked the battery and charging cord and they both work perfectly, what do I do?
    Top Expert:
  • eMachines Master
  • 8,302 Answers
bluegreenash
  • 661 Answers
SOURCE: My laptop battery won't charge
possible when the old AC adapter blew it took part of the power management circuit with it, This is the circuit that detects and charges the battery, I'm not sure whether this a seperate replaceable daughter card or whether it is part of the main motherboard. you will need to investigate this (or send it for a service)
Posted on Oct 09, 2007
  • 3940 Answers
SOURCE: My hp compaq laptop nx6325 refused to charge its battery
If the battery charged in another system, but not in yours, then most likely you are looking at a motherboard replacement.
Average cost for motherboard is around $200, if you have it installed by a technician, another $100 or so.
Posted on Feb 28, 2009
byteguy
  • 2229 Answers
SOURCE: no charge on laptop
I agree. Batteries have a limited life. Also--once you have a new battery installed, be sure you let it discharge all the way (until the computer tells you it has to be charged--about 3% remaining) at least once a month. This will ensure you get the maximum life out of a battery.
Posted on Mar 02, 2009
SOURCE: Dell Latitude D600 won't accept charger
Had the same problem, My other Dell charger would work fine but the original one that came with this laptop would throw an error message that the Charger wasnt recognized. None of the suggestions on the forums worked.
I held the chord by the circular flex thing at the end, and pushed in the power pin with force into the laptop, held it for a few seconds and now it works fine. If you push the pin slow and gently into the laptop, it doesnt recognize the adapter. I think the problem is either with the power chord connections inside or with the adapter inside the laptop. Try it!
Posted on Aug 25, 2009
  • 181 Answers
SOURCE: Battery will not charge/ keep computer on. laptop
Sounds to me like the transformer circuit that enables the batery to charge. If you have bought your machine within the last 12 months it should still be covered by warranty so go back to the supplier. If not covered I wouod still try as it is not beyond reasonable expecations that the machine will operate perfectly in very way for more than 1 year.
Posted on Feb 13, 2010
Toshiba nb505 says battery is charging but its not.
By replaced battery, you bought one? Some aftermarket batteries do not work well with your laptop. I would return the battery as defective. Some aftermarket batteries are inexpensive for a reason. Make sure the Cord/charger and the battery are the EXACT same power specs, DC volt and Milliamps, or you may fry components.
Jan 27, 2013 | Toshiba NB505N500BL 1 GB Hard Drive
My battery wont charge but it says its charging. When I unplug the cord 3 times itll go up by 1%
Have you tried replacing the battery? It sounds like the charger circuit is attempting to charge the battery and the battery is not accepting the charge.
Jul 19, 2012 | Sony Computers & Internet
Asus UL50VT always shows charging
Either your battery or the power cord has an issue. Does the battery ever fully charge and make the charging light disappear or turn green? If not the battery could be bad.
Try running the computer off the battery by removing the power cord. if the battery starts losing charging strength real quick then your battery is bad. I've see bad batteries that say they are 100% charged but as soon as you remove the power cord it gets down to 5% i a matter of minutes.
Try running the computer on just the power cord. If it stays on and lets you operate without any problem then the power cord is good. A good power cord will not charge a bad battery.
If the laptop does not let you stay on long with the power cord, then either the power cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. If either of them is bad they will not charge a good battery.
Check your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 06, 2012 | Computers & Internet
Asus always shows charging
Jun 06, 2012 | ASUS UL50Vt Notebook
T will indicate charging but it won't charge actor
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 23, 2012 | HP Compaq nc6400 Notebook
My Asus Eee PC 1001PXD battery won't charge. The charges light is on but nothing happens and now the battery is completely dead and I cannot get my notebook on
Your problem is far more than the battery. Your problem is the power cord. Laptops for the most part will work off the power cord even if the battery is dead or even if the battery is not in the laptop. Your power cord charges your battery and if it is bad it will not charge it. You've been working off your battery even though you might have had the power cord plugged in, but if it's bad and not charging the battery, the battery drains and then you can't get the laptop to power on at all. Go purchase a ac adapter and power cord that is designed for your system. Don't buy one that some of the big box stores sell that has a an interchangeable plug at the end designed to fit just about any laptop. Those will eventually burn *********** board out.
Mar 20, 2012 | ASUS Computers & Internet
Battery light won't change colors, drops to 0% once unplugged
Let the battery completely discharge all they way and let it sit for a day or so. Some times when a battery is new most user do not let it fully charge and then completely drain this causes problems for long use batteries. Then give it a try. It also sounds like your plug your cord that connects to the battery may be faulty. Did you by a different cord with the battery? Or use the one from your old one? If you did. This is a "No No" always buy the cord that come for those battery since they are rated for the particular battery.
Feb 25, 2012 | Fujitsu LifeBook A1110 Notebook
Hello, well my acer laptop model AO751h doesnt seem to be charging. I check the battery icon and it says "plugged in, charging" but it doesnt seem to be charging cause im sure the battery icon...
is this an older laptop, if so you might just need to replace the battery. or try a different charger before buying a battery. If you need anymore assistance im here
May 20, 2011 | Acer Aspire One AO751h-1211 (LU.S820Y.108)...
Battery will not charge/ keep computer on. laptop must be plugged in to be used. I have tried a different battery and power cord (my wife by sheer coincidence bought the exact same model laptop as me a...
Feb 13, 2010 | Acer Aspire 3000 Notebook
Just purchased a compaq presario secondhand--is the battery supposed to charge automatically when you plug the computer in? Mine is not. Works perfectly with the power cord though.
All the laptops I have seen since the 1980's charge the battery, if it is installed, while the laptop is running. They charge at a slower rate if you are using the computer, and faster if you just plug it in and leave the computer powered off.
Most have a 'charging' led [green or amber] indicating that the battery is being charged when you plug the laptop in and leave it turned off. If you don't see any indication, check that the battery is connected firmly and that the connectors are not damaged. If possible, try the battery in another machine or a different battery in your machine.
tom
Dec 21, 2009 | HP Compaq Presario V6000T Notebook
Computers & Internet Logo
90 people viewed this question
Top eMachines Computers & Internet Experts
Computer Links
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
