Question about Sole Fitness F63 Treadmill
How do I fix a sole F63 treadmill that accelerates to maximum speed after about 30 minutes of use?
My wife has a SOLE F63 treadmill that has been working fine for the last eight years. But lately it is misbehaving. After about 30 minutes of normal use it will start to accelerate on its own to higher and higher speeds until it stops. When it stops the display shows LS and Low speed. While it is accelerating the display does not change the speed reading, but shows the speed that was set by the user. I have tried all maintenance I could, including: speed sensor adjustment, motor brush cleaning, connector checking and tightening, belt adjustmente, lubrication and self-calibraion. Unfortunately nothing worked. I am suspicious that the problem is related the some compenent overheating. This would explain why the malfunction only appers after about 30 minutes of use. I also suspect the motor thermal protection sensor. I dont'a have a detailed circuit or functional diagram, so my troubleshooting is quite limited. Any help or suggesting will be appreciated.
Usually the motor will be controlled by a triac its a silicon device you apply more volts to a pin to allow more current to flow thru it
between its two other pins
so its used to control the motor speed
its more likely its a problem before the triac
a 'driver' device
i would take the control board out and examine it carefully for any blackened devices
so to rule out this drive chain i would take the board to a service tech like a TV repair guy and ask him to cast his eye over it
i usually get a few beers from people to do this as a bribe
always works for me and you would be surprised
you could take a photo or two as jpg in macro mode of the board
component side and post them and i can cast my eyes over them for free..
Posted on Apr 19, 2015
Is my console going out? On my Sole F63
Just replace the micro switches. You will get it any electronic repairing shop. it would worth more Buying than new boards.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 30, 2016 | Sole Fitness F63 Treadmill
Treadmill speed is going fast when I have it at 2.5
Your variable resistor (speed adjustment switch) is going out
Mar 23, 2016 | Sole Fitness F63 Treadmill
Shows LS1low speed treadmill stops working what is the solution
hi check the video
Sole F80 LS1 Error
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience
Nov 16, 2015 | Sole Fitness F63 Treadmill
Sole f60 incline error E2
does the incline work at all. if not try to calibrate the incline. if this fails something could be wrong with the incline motor
Oct 20, 2014 | Sole Fitness Sole F63 Treadmill
Sole f63 error codes
Make sure the safety key is clean and not corroded . Check connections on lower board.
Aug 07, 2014 | Sole Fitness F63 Treadmill
Sole F63 treadmill controls won't work
Stuck button or bad hand switch. Remove covers between hand rails and console disconnect both hand switches should fix it.
Jul 06, 2014 | Sole Fitness F63 Treadmill
My Sole F63 will slow down a few seconds after I start it then I get a low speed displayed on my control panel
please LUBE the deck belt+ rollers bearings too. You must do it evey 150 miles apros. This happen because the lack of maintenance schedule.
God bless you
Jan 21, 2013 | Sole Fitness Sole F63 Treadmill
Sole f63 key
please download the owner manual from www.fitness.manualsonline.com and see the section how to assembly and reverse and proceed according.
God bless you
Dec 17, 2012 | Sole Fitness F63 Treadmill
Sole Fitness F63 Treadmill Logo
192 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
