Question about Sony PlayStation 4
How do i connect a playstation 4 auto to my sharp cd-dvd500
    Master:
  • Sony Master
  • 665 Answers
George, After looking into the problem you are asking about, I have some good news and bad news for you. First, the bad news. While the PS4 and your stereo have the same digital audio port, they are BOTH outs, not in. Meaning, the signal from the PS4 is "OUT ONLY" And the the Stereo is "OUT ONLY" too. Now, the good news. There are ways to connect your PS4 to your stereo system, but they will all involve the audio inputs on the back of the stereo. First, the PS4 no longer splits the Audio and video with the standard "Yellow, White, and Red" cords anymore. This is done exclusively through an HDMI connection now. There are splitters available on Ebay that separate the audio so you can connect to your stereo via the RCA cords. I will include links to all of these below. Second, and maybe the easiest way, is to get a digital audio converter from the digital out of the PS4, to a splitter, then the stereo. Again, I'll put in links. Good luck, and I hope these help.
Mini Composite AV CVBS 3RCA to HDMI Video Converter Adapter 720p 1080p... Digital Optical Toslink Coax to Analog RCA Audio Converter Adapter Cable
Posted on Sep 14, 2015
How do i conect supwofer out put ?
You need a mono RCA subwoofer cable (http://www.amazon.com/Belkin-PureAV-Subwoofer-Audio-Cable/dp/B0001XGR1C/ref=sr_1_5?ie=UTF8&qid=1425294043&sr=8-5&keywords=Subwoofer+cable.
Down where the speakers hook up to the rear of the unit there is a subwoofer output RCA connection. Plug RCA cable in there and run it to the Input of the powered subwoofer.
Mar 01, 2015 | Sharp CD-DVD500 System
Why does my sharp cd-dvd500 shut off when too loud? How do i fix this?
Hi, you like your sound loud like I do-to prevent the stereo from shutting off simply turn the " BASS " control down a little- 1/3 to 1/2 of full should do the trick, write back to let me know if this helped, good luck and thanks for asking FixYa-Prodzilla.
Apr 20, 2011 | Sharp CD-DVD500 System
How do I shut off the parental controls on my Sharp CD-DVD500?
With a disc in the drive press SETUP whilst holding down the SHIFT.
UP or DOWN to PARENTAL SETUP and press ENTER
Using 0 - 9 Buttons eenter the 4 Digit Password ( - - - - changes to * * * * )
You have 3 attempts to enter the password ( Default Set at 0000)
LEFT and RIGHT to change parental level
DOWN to select CODE and the LEFT and RIGHT to select the desired Country Code
ENTER to confirm setting
Apr 15, 2011 | Sharp CD-DVD500 System
What do I need to connect my laptop/wii/dvd player to my Sharp Quattron Aquos Led TV? Please need an urgent answer please?
Hello
1 Press MENU to display the MENU screen, and then
press [=> or <=] to select "System Options".
2 Press [Up or Down] to select "Input Terminal Setting", and
then press ENTER.
3 Press [Up or Down] to select "PC input", and then press
ENTER.
4 Press [Up or Down] to select a specifi c adjustment item,
and then press ENTER to set each item.
5 Press [Up or Down] or [=> or <=] to select or adjust the desired
setting, and then press ENTER.
Adjusting the PC Image
Auto Sync. (for Analog PC Input Mode Only)
For automatically adjusting the PC image.
Yes: Auto Sync. starts and "Now adjusting the image."
displays.
No: This function does not work.
When "Auto Sync." is successful, "Completed" displays. If
not, "Auto Sync." failed.
"Auto Sync." may fail even if "Completed" displays.
"Auto Sync." may fail if the computer image has low
resolution, has unclear (black) edges, or is moved while
executing "Auto Sync.".
Be sure to connect the PC to the TV and switch it on before
starting "Auto Sync.".
OK.
Mar 14, 2011 | Sharp Televison & Video
Cannot connect to game It keeps saying downloading game setting
May be a memory issue try
1- erasing installed game data and reinstalling
2- erasing any ancient demos you may have on your hard drive, uninstalled or otherwise
3- are you signed in to PS Network? If you have a slow connection, sign in before you start game.
4- turn off auto-start (in PS3 system settings)
Mar 12, 2010 | Activision Call of Duty 4 Modern Warfare...
I HAVE A DISC JAMMED INSIDE WON'T OPEN OR PLAY HELP.....
check out internal wiring connection of CD ROM.the loose connection may create problem.
if connections are proper then check whether ur CD ROM working properly or not by connecting to another cpu.
i hv one master soln on it.but u hv to do it very carefully. 1st start pc then take a sharp thin stick & push it softly in lower small space of CD ROM & pull out it gently.
but it only possible if u put the cd properly in CD ROM.
so try it ,it defntly works.
dont forget to feedback me.
Jul 04, 2009 | Sony Playstation 3 (PS3) Console
Unable to eject cd-dvd
unplugging the unit and then plugging it back into the wall outlet.
Oct 04, 2008 | Sharp CD-DVD500 System
Can't turn of Closed Caption
check to make sure they are not on auto
Dec 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sony PlayStation 4 Logo
138 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
