Question about Garden
It stopped running and kicks out GFI outlets/breakers. Will warrenty repair it? I do not have the recipe.If not I have a 400-500 gallon pond with a waterfall. What is the best replacement? And where?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 19 Answers
Even without the receipt, if you know the purchases date and vendor you may be able to get warranty support.
  1. If you paid with a credit/debit card, you have proof of purchase on your bill (if you don't have the paper credit card bill, you should be able to download it at the card's online site).
  2. Many vendors can provide you with a copy receipt although they will almost certainly want to know the date and location of purchase and the method of payment.
    Your best bet is:
  • Call the vendor and ask whether they can provide a copy receipt - some will do this by email.
  • Call the manufacturer, inform them of: the model and serial number from the plate on the equipment; the date and place of purchase. Then explain how the problem arose with the equipment and get their advice on how to proceed. They may ask you to do some tests and report back. (Provided you are certain that the item is still under warranty, if the first representative tries to put you off, ask to speak to a supervisor.)
If you want further advice on this at Fixya, you can provide details here of where you purchased the item and how you paid for it (obviously without providing personal or financial information).
One tip: remember that if you purchased the equipment with a credit card, you almost certainly have a warranty extension benefit on the card - usually double the warranty period up to one year. Check with your credit card provider or look up the benefits booklet they provide when they issue a new card and on their website. If that applies, you have an additional step which is to check the warranty expiration date and then contact the credit card provider's warranty extension service who will advise how to make the claim.
If you want more information or advice on how to test, we'll need the make, model and serial number of the equipment and a brief description of the setup.
Hope this helps and let's hope you can do this through warranty so that you don't have to choose new equipment ;)
Posted on May 15, 2015
5 Suggested Answers
clyde2j2
  • 137 Answers
SOURCE: How do I prime my outside of the pond waterfall pump?
I would take the intake hose off the pump and fill it with water and with the pump running I would hokk upthe intake hose.
I also would if possible have the pump lower than the pond.
Posted on Mar 28, 2009
tommya300
  • 724 Answers
SOURCE: The Ebara EPPD 3MS1 pump will trip the GFI breaker on the outlet
Will the Gound fault socket (outlet) support the current rating of the pump
is the outlet wired correctly where the return wire is in the correct spot and the high and ground is correct not switched around?
Does the pump run in a standard outlet?
Test it with a heavy duty extention cord if no standard outlet socket is nearby?
Is the pump shaft dragging putting an un necessary load on the motor?
Posted on Aug 02, 2009
  • 151 Answers
SOURCE: my beckett 300gph pump trips breaker and works
capacitor,windings failing,
Posted on Dec 24, 2009
  • 9 Answers
SOURCE: Beckett waterfall / fountain pump W1800 pops breaker everytime you plug it in, consequently it won't run.
Sounds like there are too many things running on the same breaker. Try unplugging some of the other things on that breaker.
Posted on Oct 25, 2012
MAZTANG MT-968 stopped after 30 seconds and won't start. What now?
Check your circuit breaker in your house could need resetting.
If you are plugged into a GFI outlet it may need resetting as well.
That happens a lot with GFI receptacles.
Jan 09, 2015 | Maztang Mt968 18 inch 13.5 Amps Electric...
Pump kicks GFI breaker. If I can't get it fixed I would like to find a suitable replacement of a different make.
test Gfi with any other three prong device that you can carry out there an test it with (drop light, vac cleaner,ETC.) , if gfi holds on! replace pump
Oct 24, 2014 | Little Giant Garden
Reset
Hello jerrydj1021 - Often when the breaker trips, it is a mainly because there is too much current running on one circuit. Is the unit plug into a GFI outlet? It is not recommended to use GFI outlets or too many appliances plugged into that one circuit. Try plugging the unit into another direct outlet and see if the breaker trips again. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jun 22, 2013 | Frigidaire 24 in. FDB510LC Free-standing...
Home fuse box breaker issue
Hi Rex,
It sounds as if the upstairs bathroom outlet and the outdoor outlet are on the same circuit. There's a very good chance that these are GFI or "ground fault interrupter" type outlets, as these locations (and others) have required this type of protection for over 30 years. It was a common practice to run a circuit from the panel to one of these locations (or another) and then run from here to the next outlet and then on to the next. Since the GFI outlet could be purchased for around $10 instead of $30 for a GFI breaker, electricians would install outlets instead - both offered the same protection. A "regular" breaker would supply power to this circuit - but the very first outlet would get a GFI type outlet. It would be wired to the LINE terminals and the cable that feeds the rest of the outlets on this circuit would be connected to the LOAD terminals. If there was a ground fault condition, this GFI outlet would trip, but the circuit breaker would remain on. You would locate and RESET the tripped GFI outlet to restore power. The only time the circuit breaker would trip is if the circuit was overloaded. Overloads would NOT cause the GFI outlet to trip.
Now that you understand how it was typically wired years ago (and still a lot of times today), you should check all the outlets outside your home, in bathrooms, basements, garages, and inside your home next to doorways that lead directly to grade of your lawn or deck. These are required places for GFI protection. Press the RESET on any tripped GFI outlet to restore power. If the outlet will not RESET, there is a condition where the hot wire (black, red or blue insulated wire) is in contact with ground, or a device or appliance connected to the circuit has a problem. Unplug anything connected to the circuit and attempt to RESET again. If still unable to reset, open the outdoor outlet again and carefully pull it out and away from the box. Inspected for damaged or crushed insulation and repair / tape as needed. Before reinstalling, try to reset again. If it holds, trip the GFI by pressing TEST button. The RESET button should pop out. Reinstall the outlet and make sure the wires are not crushed or cut. Press the RESET button again. If it trips, you will have to remove the outlet again and take more precautions against damage to the insulation. it is also possible that the GFI outlet itself has failed, in which case it should be replaced.
GFI circuit breakers and outlets are supposed to be tested monthly by simply pressing the TEST button and then the RESET button. Replace any GFI device that does not test correctly if wiring and devices / appliances connected are OK.
I hope this helps & good luck! Please rate my reply - thanks.
Jan 05, 2012 | Hammering
My gfi reset everytime the savio pump plugin
I am assuming when you say GFI you are meaning GFCI, Ground Fault Circuit Interruptor. If the pump is throwing the smaller breaker on th plug than the pump is more than likly drawing too many amps for the plug. Make sure the GFCI outlet is rated for the same number of amps as the pump. That is a good sized pump and when it kicks on it draws a lot of power.
Mar 18, 2010 | Savio Water Master Solids Handling Pump...
When i plug in my kenmore stovetop the other electrical outlets trip, i unplug it and reset the outlets and the outlet works but i can't use the stovetop unless i light the gas with a match now. what is my...
you, or your electrician has pulled power from one of the gfi outlets to power the electric sparker on the stovetop. If you can figure out which gfi that the power was pulled from, open up the box and find the wire that runs to the stove and remove it from the gfi outlet and connect it to the power before it goes to the gfi.
Dec 26, 2009 | Gb Electrical 1 30 Amp Ground Fault...
The pump keeps tripping the GFI. We have cleaned
How long have you had this pump? Have you had it long enough for the bushings and bearings to go bad. Have you added anything else to that line that feeds the breaker. that feeds this pump If you tell me thies things i can give you a much better awnser
Aug 08, 2009 | Savio Water Master Solids Handling Pond...
Aug 02, 2009 | Ebara EPPD-3MS1 PRO-DRAINER Manual Sump...
My pump stopped working after 1 month. It was running loudly then kicked the GFI in the plug and wont reset now.
unplug from gfi reset and plug something else in and see if it works, no then bag GFI, yes then sounds like pump is faulty return to place of purchase i would not recommend trying to fix yourself as some one could get electrocuted in pool if theres any mistake
Jul 07, 2009 | Intex Easy Set 530 Gallon Swimming Pool...
GFI for pump keeps tripping...
no you need to put 60amp breaker in house panel box
Jan 15, 2009 | Beckett Water Gardening Beckett Statuary...
Garden Logo
323 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
