Question about Boating
Engine cuts out when tiller arm lifted. Starts and ticks over fine. The tiller arm seems loose could this be the problem.
    Problem Solver:
  • 17 Answers
Sounds like the tiller arm has a Kill switch in the end to shut the motor off. If it does there are two black and yellow wires in there and they are shorting to ground or to each other when the arm is lifted. This would shut the motor off when the are is lifted. The black and yellow wire is the kill wire on most outboards. If it grounds out and the engine will not run.
Posted on Apr 20, 2015
Wont rev, ticks over fine
Sounds like a broken cable to the throttle body.
Check that both cables are intact.
Apr 16, 2014 | 2004 BMW R 1200 GS
2007 MTD Tiller with a 5hp Honda engine
I got to think there may be a loose connection in the ignition circuit. That is where I would be looking.
May 21, 2012 | Yard Machines Garden
Troy bilt bronco model # 12180starts & idles fine. How do you set or fixthe governor . It runs at idle speed all the time. I can force the governor open and it with run fine until I turn loose of the...
clean and lube around butterfly arm and "windvane' under engine cover.most governors are controled by air coming off finns on flywheel also check to see if you have return spring broken or missing
Mar 25, 2010 | Troy-Bilt Pony Garden Tiller
Ticking noise in rear of 650 V star
lift rear end ensure wheel is straight, chain will tick if not running true. next step remove chain and turn wheel by hand, listen for noise, wheel should spin freely when spun, like once or twice around before it stops. sometimes also ticking sound from drum brake is just a loose lever from the brake pedal to drum. pads will not tick. to be really safe, remove wheel and take apart.
Aug 28, 2009 | 2003 Yamaha V Star Custom
Honda FG100 Tiller - Tines wont move
I took the transmission apart and the gears were fine. The friction pads on the centrifugal clutch don't seem to make full contact with the drum. Does anyone know what the thickness of the friction pads are suppose to be? I used some belt dressing on the pads and got some movement on the tines. With no wear on the gears, I guess I'll be replacing the clutch.
May 02, 2009 | Honda Hmantis Mantis Garden Tiller with...
The engine cuts out after it heats up
This seems to be a common issue as of late, i'd tighten up your idle adjustment so you can run at full throttle with no issue. The tiller's oil should be at the lower lip of the dip stick's access threading while the unit is laying face down (gas tank down). Clean up your carb as well and change your plug/filter, if this doesn't work than you're probably looking at some simple carb adjustments, but the fact it dies after 10 minutes of use makes me think it's running either dirty or too rich.
Apr 19, 2009 | Honda 25cc 4-cycle Mini Tiller
Wheels turn, tines don't
These machines have an arm to activate the tines independantly from the wheels, make sure that the tine arm is in the on position.
If not, seems like you have a transmission problem, you'll have to get dirty to fix this one and open up the transmission casing to see if its just the link between the tine arm and tine crankshaft that broke or if its more serious.
Apr 05, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Boating Logo
117 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
