Question about Measuring Tools & Sensors
WHAT PLUG GOES IN THIS ENGINE?? It is a very simple question....
Indica 1.4 not firing cylinder number 3. What's e fault wen it's idle they is check engine light but wen Its moving it goes off
Need to know if the vehicle has an ECU which should record any fault - a simple test would check spark plug and quality of spark by earthing the plug to the engine - if its ignition related (ht lead) there will be no spark without and with spark plug ==== HT leads can go high resistance so may not work at idle but improve with increased engine speed. So do the simple test using insulated tools pliers/screwdrivers
May 20, 2017 | Cars & Trucks
Top dead center
very simple remove the spark plug, on the right side of the engine there is a case cover, remove it, there is a flywheel there, put a screwdriver gently into the spark plug hole ,rotate the engine slowly by hand, the piston will travel up and then briefly stop and go back down , the piont where it reaches the top is tdc, make note of any marks on the flywheel this is a timing mark, that goes with tdc for the piston.
Jun 06, 2013 | Motorcycles
The door ajar light is on, but all the doors to the van are shut. The sensor beeping is always activating when I'm briefly stopped, and accelerate upon starting again...the beeping will not shut up un
You will note a simple contact switch on the door sill. It has probably jammed, dislodged, or is broken by someone kicking it upon entry/exit. Realign it and see if the warning light goes off when you press the switch in (simulates door closed). If it goes "off", you're home free. If it doesn't you will have to order a replacement switch from the dealer. They are easy to replace by carefully prying away the rubber grommet and sliding the switch out... there should be a simple wire plug for it... unplug it and plug in the new one. Note the grommet position so you don't have to take it loose again to friction the grommet in properly. Test it with your finger pressing it down again, engine "on", door open. Should cure your problem. Good Luck
Oct 05, 2012 | Cars & Trucks
How do you install a voltage regulater on a 2001 FXDWG?
It's simple, unplug the plug at the front of the engine and disconnect the wire that goes to the positive side of the battery. Unbolt the old one and replace it with the new one. Reconnect the plug and run the long wire to the positive side of the battery. No problem.
Steve
May 13, 2011 | 2001 Harley Davidson FXDWG Dyna Wide Glide
Car battery is dead. I have a Black and Decker Simple Start car battery recharger. I can figure out how to plug the outlet part into the wall but I do not know what to do about the part that goes onto...
You should have 2 wires with clips = one red that you clip on the Positive [ + ] post of the battery, this may be marked red on the cable. The other black clips to the Negitive [ - ] post of the battery.
Don't plug in the charger untill you clip the wires to the battery, make sure the charger is set to 12 volts. If your cherger has a cigar lighter wire just plug it in to the dash port.
May 09, 2011 | Honda Odyssey Cars & Trucks
Need coil to sparkplug wiring diagram
looking at your motor from the front wheel ......coil on left side bottom tower wire goes to first plug
on left, top tower wire goes to the last plug on right.
right side coil bottom tower wire goes to left side no# 2 or 2nd plug in . The right top tower wire
goes to 2nd plug from right, I hope that is what you were asking . I do not have picture but this
is simple enough. Ok Good luck
Nov 29, 2010 | 1994 kawasaki ZX-9R Ninja
Engine wont idle and it cuts out at 3800 rpms also a whine noise under the hood
your problem is the mass air flow sensor tha is connected to the airbox, it is the part that is plug in just before where the air filter goes. this part is about 80.00 and u have to remove the airbox three screws. very simple.
Jul 25, 2010 | 1999 Toyota 4Runner
How to connect the spark plug wires to the distributor cap on a 1999 mitshubishi galant 3.0 engine
Here you go. As the firing order is 1-2-3-4-5-6 it is simple. Just connect #1 to the #1 location as noted on the diagram, then to the #1 plug, and then as the distributor is rotating clockwise the #2 plug wire goes to the next connection which will be #2 in line and so on. d49a874.png
Diagram curtorsey: about.com
Apr 07, 2010 | 1999 Mitsubishi Galant
Suzuki GN125 engine oil drain
The spacer goes in first then the spring. What you removed was the detent for the shifter
Apr 11, 2009 | 2001 Suzuki AX 100
1993 Ford F150 smoke coming from spark plug
If it's on the outside of the hole, it could be as simple as a gasket leaking from above or near. Oil on new spark plug electrode area, is something to be concerned about. Is the engine running o.k. now? What engine is it?
Jan 05, 2009 | 1993 Ford F150 SuperCab
Measuring Tools & Sensors Logo
104 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
