Question about Noritz Water Heaters
Where is the filter on the Noritz n-063S-01?
Where is the filter? Can I get a manual - can't find mine?
3 Suggested Answers
snap101
  • 117 Answers
SOURCE: change temperature on noritz N-063S
the only way you can is to pull the jacket off and find the right plug ends to put together to bump the temperature up.you will see them they are all labeled. the controller is alot better to have especially because it will tell you if you have any problems with it before it freaks out and kicks the bucket!
Posted on Aug 01, 2009
senor8
  • 73 Answers
SOURCE: will not try to lite
1) First make sure you are getting power into the unit.
2) Then check for any visible water inside the unit which might indicate a leak.
3) The third possibility is the flow sensor being stuck. Try opening a large flow of water (bath tub, two sinks and shower) and see if the unit fires. Otherwise you may want to contact a servicer to clean this component.
Posted on Jul 30, 2010
Why won't my noritz tankless water heater come on after a power outage
reset circuit breaker fully off the on
power outage can call surge
check fuse on circuit board
Jul 13, 2014 | Noritz 6.3 Gallon Residential Tankless...
The Noritz HW Heater has been tripping out some (usually whenever the shower is running, and someone turns on cold water). LED flashing three times. Any Ideas
This is probably a 16 error code. This code indicates the outlet water spiked above the set temperature for an extended period. It usually means the heater needs to be descaled or the manifold pressures need to be adjusted.
Mar 10, 2011 | Noritz 6.3 Gallon Residential Tankless...
I have a Nortitz natural gas water heater, model #N-063s-1. Acouple of days ago it stopped heating the water. what can I do myself to fix this matter. Thanks, lynnatheana@hotmail.com
There are many reasons a tankless heater will stop heating water. The first thing I would look for is a flashing red light on the burner indicator. The flash break down goes as follows
continuous blinking - typically means ignition failure or the unit is overheating; look for visible water inside the unit, have your gas pressure checked, or check the flame rod/igniter for buildup of debris
three blinks - typically indicates 16 error code; typically resolved by performing a descale
4 or 5 blinks - exotic error codes; for these you should definitely contact Noritz tech support
If there is no flashing light, first check your filter for debris. If the filter is clean, your flow sensor is probably stuck. Again I'd recommend contacting Noritz tech support to help you clean the flow sensor.
Jul 31, 2010 | Noritz 6.3 Gallon Residential Tankless...
For a noritz N-06315 do I need an aux drain pan if it is installed above a living space
It depends on local code, no all cities/states require drain pans, but it is always a good idea if you don't want to deal with water damage.
Jul 18, 2010 | Noritz 6.3 Gallon Residential Tankless...
Will not try to lite
May 27, 2010 | Noritz 6.3 Gallon Residential Tankless...
I have a noritz water tankless heater and hot water stopped. Red light blinking three times. Need help.
Three flashes typically indicates the unit is overheating due to scale. I'd try a descale initially and see if that remedies the problem.
Dec 27, 2009 | Noritz 6.3 Gallon Residential Tankless...
Water does notget hot enough
Have you tried to turn to temperature up higher? The units come factor set at a low water temperature and usually need to be adjusted higher after installation.
Down load this manual and follow the instructions on pages 11 or 12 depending on whether or not you have a remote control. My gues is that you do not have the remote.
http://www.noritz.com/u/products_files/owner_s_guide__n_0531s_0631s_series.pdf
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 08, 2009 | Noritz 6.3 Gallon Residential Tankless...
Change temperature on noritz N-063S
Jul 31, 2009 | Noritz 6.3 Gallon Residential Tankless...
Trouble light bilnks 3 times pause and then repeats
You have a 16 error code, abnormal output temperature. I recommend performing a descale to remove hard water deposits in the heat exchanger. This should resolve your issue.
Jan 28, 2009 | Noritz 6.3 Gallon Residential Tankless...
Water Heaters Logo
60 people viewed this question
Top Noritz Water Heaters Experts
gizmonix
Level 1 Expert
jasbo
jasbo
Mack Baxter
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
