Question about 2002 Ford Explorer - 4-door SUV, with light sensor - Ltd. Edition Dashboard Cover
Front inside cabin light & under outside mirror light wont turn off when locking the car
I have a 2004 chev Express box van and my tail lights wont work every blinker works just not the lights both sides replaced bulbs still nothing
Fuse Usage 1 Climate Control 2 (HVAC) 2 Compass 3 Ignition Switch, Theft Deterrent System Module (PK3) 4 Upfitter Courtesy Lamps 5 Climate Control 1 (HVAC) 6 Empty 7 Instrument Panel Cluster 8 Audio System, Chime 9 Auxiliary Park Lamp 10 Auxiliary Trailer Back-up Lamps 11 Remote Function Actuator, Tire Pressure Monitor (TPM) 12 Climate Control (HVAC) Controls 13 Trailer Park Lamps 14 Front Park Lamps 15 Taillamps, Back-up Lamps 16 Empty 17 Steering Wheel Sensor 18 Outside Rearview Mirror Switch 19 Empty 20 Empty 21 Rear Defogger 22 Outside Rearview Mirror Heater 23 Empty 24 Empty 25 Cargo Door Unlock 26 Rear Door Lock 27 Front Door Lock 28 Rear Passenger Door Unlock 29 Upfitter Park Lamps 30 Front Passenger Door Unlock 31 Driver Door Unlock 32 Airbag System, Automatic Occupant Sensing (AOS) System 33 Right Rear Park Lamp 34 Left Rear Park Lamp 35 Upfitter Auxiliary 2 (J-Case) 36 Upfitter Auxiliary 1 (J-Case) 37 Rear Blower (J-Case) 38 Empty (J-Case) 39 Run (High Current Micro) 40 Park Lamps (High Current Micro) 41 Empty (Mini Micro) 42 Upfitter Auxiliary 2 (High Current ISO Relay) 43 Retained Accessory Power (RAP) (High Current Micro) 44 Rear Defogger (High Current Micro) chevrolet-express-fuse-box-floor-console-fuse-block-247x300-3m55w415sdhfmumhyuzqkab2-3-0.jpg
Jul 27, 2017 | Cars & Trucks
I have heavy condensation daily inside on my windows in the morning. What causes this? How can I fix it?
It is caused by water vapour in humid warmer air inside the vehicle condensing on the very cold windscreen. As long as the interior glass surface is much colder than the inside air it contacts you will get condensation forming on the inside surface.
2. If you equalise the temperature of the air inside the vehicle with the outside temp for 5 minutes before locking up your car you will minimise condensation, as will garaging it. If you drive around with the heater on full on a freezing cold day, stop the car and lock it up exposed, you are going to get condensation, especially if you have used the recirc control to block the outside air from entering the climate control system in the cabin while driving.
3. If you are having this condensation issue set the air controls on the car (before you turn it off and park it) so that outside air can flow in through the cabin venting system. When you drive around constantly with just interior air circulation and no outside air entering you are going to get a build up of humidity.
Dec 27, 2015 | 2008 Volkswagen Jetta
Passenger door can be opened from inside but not from outside...how too fix???
Remove the door lining and look inside by the lock. There is a linkage that has come adrift. To remove the door lining, remove handles, escutcheons, and arm rests. Using a wide blade screw driver gently pop the plastic rivets that hold the lining to the door.
Dec 02, 2015 | Cars & Trucks
Remove outside mirror on 2012 chevy traverse
You need a special puller for the inside door panel. Have to go to an autoparts store for it. Then you take out all the screws on the door panel. The you use the puller on the bottom and sometimes the sides to LOCATE and REMOVE the fasteners..Lift the panel up and away from the door. Careful about any wires that might be connected to switches. Unplug those if present. You will now be looking at a sheet of sound deadening material that has a tar like substance on it. You cannot really save this and it is messy. remove it and then you can see the internal door and window parts. Be careful because the parts are sharp. Long sleeves and gloves are recommended. See if you can reach in under the window and feel for the bolts. If you cannot then the window has to be removed. Locate and remove the glass retainer and remove the window. Then remove any bolts holding the window mechanical parts. Then you should be able to get to the bolts for the mirror.
Jun 07, 2015 | 2012 Chevrolet Traverse
1999 Mazda millenia Electrical issues
the first thing to do is to remove the wires your sister conected, tape them seperately, these wires are power and ground wires and power the light in the visor mirror , they can not touch, so make sure they are apart and not touching any metal surface, tape them, one at a time.
there must be a blown fuse, did you check all the fuse boxes? there is one inside and one under the hood. start with this .
May 05, 2013 | 1999 Mazda Millenia
Door open indicator light stays on , automatic door locks go on & off while driving and dome light and outside mirror lights wont go off after the car is turned off
i would hazard a guess and say that wires in the rubber boot from the door pilar to the door are damaged or the connection block in the door pillar in this the terminals are corroded or something similar
Nov 22, 2011 | 2002 Mercury Sable
Need a diagram for installing a drivers side electric power mirror on a 1995 mercury villager van
here's 1996, all I have. Please rate.
Mirror, Power — Outside Rear View NOTE: This procedure applies to both RH and LH power outside rear view mirrors.
Removal
  1. Remove the front door trim panel (23942). Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws and the outside rear view mirror mounting hole cover (17K709) from the front door (20124).
  1. Remove the wire clip.
  1. Disconnect the power outside rear view mirror electrical connector.
  1. Remove the three power outside rear view mirror bolts and the power outside rear view mirror.
Installation
To install, reverse the removal procedure. Tighten the three power outside rear view mirror bolts to 3-4 Nm (27-35 lb-in). Glass, Outside Mirror
Removal and Installation
Refer to the glass replacement procedures in Manual Mirror for power outside rear view mirror glass (17K707) Trim Cover
Removal
  1. Remove the front door trim panel. Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws.
    Remove the outside rear view mirror mounting hole cover.
Installation
To install, reverse the removal procedure. Mirror Control
Removal
  1. Use a small flat-blade screwdriver to pry the power outside rear view mirror control switch from the instrument panel (04320).
May 13, 2010 | 1995 Mercury Villager
Lennox electric furnace wont cool house. model cb-30m-46. dual zone. honeywell control panel. cool light lit and purge light flashing.
check the outside unit (condenser) see if the fan and compressor are running. the compressor humms and you should be able to hear it. if it is running check the inside unit's coil to see if it is frozen or dirty. if it is frozen or extremely dirty then you have restricted airflow to the inside unit. Sometimes checking the coil is near impossible, i use an inspection mirror and headlight flashlight, then i wedge a chisel under the front of the drainpan (CAREFULLY! its plastic usually) so i can get my mirror in there and see whats up. On a furnace the coil will be on the very top and have 2 copper pipes running into it with one of them being insulated. hey also a dirty filter or prefilter can cause freezing.
Oct 09, 2009 | Heating & Cooling
Electrical Problem
you need to go to the dealer and have the body control module checked and replaced. The bdc mod controls everything pretty much inside cabin. The dealer can put it on the scanner and check. But with lock , windows , dash lights the body control module is bad. you have to get from the dealer because they have to program it for your jeep. and they are not that exspensive they go out all the time in jeeps.
Jun 04, 2009 | 2004 Jeep Grand Cherokee
Inside cabin lights stay on
check the relay for the interior lights ... sounds like it is stuck on
Robert
Apr 21, 2009 | 1992 Buick Roadmaster
2002 Ford Explorer - 4-door SUV, with light sensor - Ltd. Edition Dashboard Cover Logo
24 people viewed this question
Top DashMat Vehicle Parts & Accessories Experts
Todd Arndt
Todd Arndt
daf62757
Level 1 Expert
Are you a DashMat Vehicle Part and Accessory Expert? Answer questions, earn points and help others
