Model sw30108 only spins at 800 and when I move it to 1200 when the programme starts it flicks itself back to 800
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Con troll pannel
Posted on Apr 21, 2015
Hi, my machine lets in water and starts spinning as if the spin and drain programme is selected, spins then pauses and repeats the process.What could be faulty?
Hi, mine does this sometimes when it is out of balance, sometimes it will keep doing it for 30 minutes before I open it, move the clothes around and rebalance. It does this to keep from throwing the washer drum off its mounts with an unbalanced load. It tries to go backwards and forwards during the 2 minute pause to mix up the clothes to rebalance by itself - sometimes it just can't get it and needs your help to separate the clothes so it can spin without vibrating.
Hope this helps!
Feb 09, 2016 | Washing Machines
Manual for sw30108
repair clinic dot com.
Apr 19, 2015 | Washing Machines
How do i get to the bottom of a failure to spin clothes i a whirlpool washing machine model awm320 which is an 800 spin model
Is the machine draining properly?
Have you checked the filter on the pump? What happens when it gets to the spin part of the cycle?
Is it knocking?
Does it go through wash cycle properly?
W
Nov 23, 2014 | Washing Machines
My clothes dryer doesn't spin by itself
Motor capacitor, it gives the motor a little extra kick it needs to start
Sep 17, 2014 | Dryers
Why is my Bosch 1200 classic spin light flashing and won't machine won't spin
They aren't very complicated machines. Unplug and remove the back. Look for trapped clothing, broken belt or something that seems out of place. If it all looks normal you could have a bad circuit board (but if that's the case the machine should throw an error code) Cheap on EBay and easy to replace. Mine was $45 and took less than 10 minutes.
Jul 21, 2014 | Bosch Washing Machines
Fills with water correctly, will not go to next cycle
Hi ,, ok lets try some fault finding,,, try putting the washing machine on a no or low temp programme like wool,, or even the fill empty spin , see if it moves then,, if the programmer moves through then spins, i would assume the thermostat is broken,, if it moves through but does not spin , it may be the heating element,, if it does not move at all in any programme i would assume the programmer has a problem
Nov 14, 2013 | Whirlpool Washing Machines
Wixe 127 how do you get max spin 1200 on spin cycle can only get 800 down to off?
It can actually depend on the programme you have selected.
You have to select a programme that will accept a 1200 spin, as not all programmes do.
Hope this helps.
Dec 16, 2009 | Indesit Washing Machines
Bosch Classixx 1200 - Drum not turning
It could be the motor itself (is there any overheating smell from the motor) or it could be the capacitor which controls the motor. I had a similar problem and it turned out to be the motor brushes. I replaced the brushes and all was OK.
The only other thing that could be wrong especially if it overfills with water is the water level switch (this is a pressure switch on the side of the washer) You can easily check this by removing the hosepipe to the switch and blow gently into it, you should hear a clicking sound) This might be the clicking that you heard so it is probably Ok.
Aug 08, 2017 | Bosch Washing Machines
Washing programme won't move from final spin
some **** or something is stuck in the drum. u'll have to get it repaired.
Jan 28, 2009 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
