Question about Welding Tools
2 wires from selinoid in the tweco adapter kit where to attach
    Problem Solver:
  • 12 Answers
How can someone answer that question without knowing what welder this is for and the voltage of the solenoid valve in your adapter kit???
Posted on May 01, 2015
Why does my gmc denali loose radio reception or signal when i start my motor
when you turn your key from on to start it uses the power that would normaly play the radio to help activate the selinoid
Aug 24, 2013 | Yukon 2008-2009 Gmc Yukon Denali Nav/dvd...
Toro lawn tractor starting problem
both of the small wires to the solenoid go threw safety switches start with the one on the clutch/brake pedal
Jun 09, 2012 | Garden
I have a clarke 125en mig welder model we6526, im needing a new gun .what product would match this
Hi:
There is no adaptor in the market for it, but there is one web site that offers an adapter for 45.00 bucks and then you can buy a standard mini tweco gun, which you can find at any praxair location ( www.praxairdirect.com). Here is the link for site offering the gun's adaptor: http://shdesigns.org/Craftsman-12x36/tweco.shtml
Good luck.
Jun 29, 2011 | Clarke Power Products Clarke 130EN...
I need clarke mig welder partes for the gun on a 130en. I can't find them any place, can you help me find them. Thank you.
Hi:
It will be better to adapt a new gun. Go to your nearest Praxair (www.praxair.com) store and ask for a tweco mini gun with a clarke adapter. Tweco accesories are available at ALL welding stores and it's a cheap gun also.
May 24, 2011 | Clarke Power Products Clarke 130EN...
Looking for a replacement gun for my old solar mig welder
Buy a Tweco mini gun part# 1000-1133 and an adapter part# 2500-2140, and that will solve your problem. Tweco parts are available at every Praxair location.
Get rid of the solar gun.
Dec 07, 2010 | Solar Mig Welder Welding Gun Liner Parts...
Need a new torch assy for my clarke 130.
Go to your nearest Praxair store and ask for a tweco mini gun with a clarke adapter. Tweco accesories are available at all welding stores.
Dec 02, 2010 | Clarke Power Products Clarke 130EN...
I have a older centrey 80 mig welder that i am trying to find a new lead and gun assmbly
Century parts are a pain in the **** to find, try to adapt a tweco #1 mini gun on it, you will find parts for it at any welding store. It will cost you around 150 bucks
Nov 14, 2010 | Welding Tools
Replace stereo
If you have the stereo, the easiest way will be to get a Haynes repair manual on your vehicle so you have directions for opening the dashboard, if you haven't figured that part out. Next you'll want to go to walmart or some retailer that sells adapter kits and pick up an adapter mounting kit and wiring connection. This will allow you to use the original wiring harness with your new radio. The adapter for the radio it self may not be needed so check first. If the New radio has a cover plate attachment it may not need an adapter. Most Chryslers do need one and some of the imports but not all. Good Luck
Feb 21, 2010 | 2001 Kia Sephia
How to remove Panasonic cq-c1301u unit from car
This is an interesting question. As to the fact that you didn't mention what kind of car you have, I can't give you exact instructions, but I can give you approximate instructions. Read all Instructions b4 you do anything and detach battery b4 working on system!!!!!!
1. Most car's require you to remove a dashboard panel, of not the whole thing. (on a side note, the panel on my jeep that has to be removed just pops out).
2. Next you need to unscrew the adapter kit from the car. A lot of older cars put Double DIN headunits into their cars, These are the larger sized headunits. Most after-market systems require a plastic adapter to allow them to fit into the larger space. As long as your new unit is the same size as the older unit, this piece can be reused.
3. Then you must remove the old headunit from the adapter. Most are either screwed in or have pressure pins that hold it in place. Either unscrew or carefully push down the pressure pins until you can remove the old headunit.
4. If you have already purchased the wiring kit, if necessary, then continue onto next step, otherwise purchase appropriate wiring kit for your headunit and car. Do not open wiring kit until you are ready to hook up your new headunit!!!!
5. Find new wiring kit, detach old wiring kit, and hook up new wiring kit according to included instructions. For best reliability, I recommend using wire nuts as electrical tape isn't as relaible and can come apart after a while. If you need to save space and can't use wire nuts, I recommend liquid electrical tape. Let this dry before you go any further.
6. Attach new headunit to adapter and then attach wiring kit to back of the headunit. Make sure to attach radio cord to back of headunit. Push adapter and headunit back into place, adjusting wires as necessary. Screw adapter back into place.
7. Re-attach dash panel back to car, reattaching screws where and if necessary and reattach battery. Power up car and test system.
8. Listen away.
If you cannot get this to work, most places like Best Buys and Circuit City have professionals that have the necessary parts and expertise to exchange headunits in cars and can do this for a small fee. Just replacing a headunit should be relatively cheep. Adding other components as well would be more expensive.
Mar 25, 2009 | Panasonic CQ-C1303U CD Player
Trailer wiring diagram
Either buy an adapter that will go into your existing harness, usually up under, near rear bumper, you pull connector apart & put adapter in line, then you plug new flat4 into it. Otherwise I would pull inside covers of both tailights, use a 12 VDC light tester, and probe wires at right signal for flashing with blinker,and attach Green wire, from flat4 to it. Do same on left side & attach yellow flat 4 to it. Turn off blinkers, and just put your running lights on, Find wire with power on either side when running lights on, and attach brown flat 4 to it. Now find some clean metal in the area and attach white wire (ground) to it. Put inside covers back on & your done.
http://www.etrailer.com/faq_wiring.aspx
Nov 13, 2008 | 2000 Dodge Caravan
Welding Tools Logo
212 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
