Question about Craftsman Garden
How to install a new blade for my 10 inch electric chainsaw - model 358-34010
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
Loosen the chain adjuster and remove the bar bolts. Remove the side cover. Remove the existing chain. Thread the new chain over the sprocket making sure the drive cogs are engaging the sprocket correctly, then thread it over the end of the bar ensuring the drive cogs are inserted correctly in the bar groove. Install the bar/chain onto the bolts aligned with the chain adjustment pin and install the cover. Snug the bolts and tighten the chain with the guide bar tip elevated. Once you are satisfied with the chain tension, tighten the bar bolts and....... VOILA.... you are done. Head for that pesky neighbors tree that drops leaves in your yard.....
Of course, make sure the chain orientation is correct !!!! I have seen them installed backwards on the shelf in the big box stores....
Posted on Apr 21, 2015
    Scholar:
  • 35 Answers
I helped a friend do this back in college a few times. I thought it was really cool to see the way chainsaws actually worked. It was even cooler when I got to see him actually use the chainsaw to cut down a tree. It's really kind of amazing how the process of something like this works. I hope that more people will look closely into their options with things like this. That way they'll be able to do the best thing for themselves.
http://www.cleancuttrees.com.au
Posted on Aug 28, 2015
I am trying to chng 10 inch saw blde on model Ls1 03 0 I do
Its easy there should be a wrench on the saw that fits the bolt that holds the blade on and there is also a button on the shaft houseind that when pushed will lock the shaft so the blade will not turn. the olny tricky part it the bolt turns in the oppisite deriction as a normal bolt so you need to turn it clockwise to loosen it. Hold back the blade gaurd push the button loosen the bolt look at way the washers go on as you take the old blade off when the new blade goes on make sure you put if faceing in the right deriction there will be arrows to show you witch way it spins and install in reverse order
Dec 22, 2010 | Makita Garden
I have a 16 inch chain saw and want to buy a new chain saw blade does anyone know what other manufacturer's blade will fit
Oregon mfg. makes a full line of replacement chains and bars (blade). Check with home centers, hardware stores, and saw dealers. Bring full details of the saw with you, or the saw itself. Good luck!
Jun 03, 2010 | Desa International Remington 12 Electric...
What lubricant oil is used on the blade of a Wen electric chain saw?
I have a Wen 2000 10" electric chainsaw and just ordered a new chain, , but does it need oil poured inside? I have no manual. what kind and how much? can it be over filled, there is a black screw off knob that appears to be for oil?????thanks Kim
Apr 02, 2010 | Electric Chainsaw Sharpener
How do i change the blade on a 10 inch ryobi table saw
There should be a removable plate next to the blade in the table top. two wrenches of the correct size, one for balde nut and one for the shaft,Hold the shaft and turn the nut to remove. reverse procedure to put back on.Chibasset
Oct 31, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
I need a new 10 inch blade
A new chain can be fabricated by a local chainsaw shop. A new bar requires a model number to answer, a make couldn't hurt. Tag; you're it.
Lou
Oct 22, 2009 | Remington Electric Pole Saw
Remington 14 inch electric chainsaw replacement blades
You can 14SC available online at www.masterparts.net you also can contact them toll free at 800-446-1446. They ship parts out very fast.
May 25, 2009 | Desa International Remington 14" Electric...
Ryobi battery chainsaw 10" - How do I tighten the chain?
loosen the two nuts that hold the chain cover on. Once they are just loose, then use a flat blade screw driver to turn the slot that you see right next to the base of the chain. Once the chain is tight, retighten the two nuts.
May 23, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
14 inch electric chain saw throws chain off
If a new chain ::
make and model is important here, as are guide bar length
a particular chainsaw, may be available with 12,14,16,18,20,22,24,26 inch guide bar,
likewise different saws (even from different makers) use the same size of chain
a chain for this saw may be sold in a variety of lengths or
may be sold in the longest length only and require links removed to suit smaller bars.
back to the store, with the saw, for confirmation
If an old chain::
stretched way beyond safety, replace
Sep 27, 2008 | Remington Electric Chain Saw
Garden Logo
115 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
