Question about RTO W4 A.O Smith Gas Hot Water Heater Draft Inducer
My water heater makes a loud boom sometimes when it starts up. It has a electric ignitor.
I have a baxi combi he 80 plus and after more than ten visits from our local housing association plumber it still when starting up clicks and clicks for 4 to 5 secs, repeating itself until there is a large...
Well its not right should not lighting with a bang or boom Its not lighting on the first stage pilot only and it sounds like you are getting full gas . In 10 visits I would ask them to call B gas or Baxi to fix this as this guy cannot .
Dec 29, 2017 | Water Water Heaters
I have a 20 year old Ruud gas water heater with a power vent. The model is PVP 40-1. Sometimes it will not heat water. The power vent is running but neither the ignitor or the burner is. If I turn off the...
My guess is the ignitor needs replacing (old and has built up too much internal resistance). Even though it still works at times, I would suspect it first, even if it glows during an ignition cycle.
Dec 07, 2014 | Water Water Heaters
I can not get my heater to work. My gas is working because my range lights and my water heater is working.
Make sure the electricity is turned on, most new units have an electrical ignitor which must be turned on and heat up before it will allow the gas to come on.
Oct 19, 2014 | Water Heaters
How can I check my Suburban water heater?
check the gas pipe carefully spiders like to make home in there and clog it
Jun 05, 2014 | Suburban RV Hot Water Heater 12 Gallon Gas...
Loud noise filling water
Probably heat trap nipples, or other constriction in pipes.
http://waterheatertimer.org/New-water-heater-making-noise.html
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment and say what you find
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 24, 2013 | Water Heaters
Water heater makes loud noise when burner is on
I would check the metal door on the bottom near the burner, sometimes they come loose and vibrate. If not that then I would suspect the chimney liner inside the tank, I have seen them corrode and start vibrating when the gas is running
Jun 09, 2012 | American Standard 40 G Natural Gas Water...
Trying to find out if my new hot water heater is shot
The red button you pushed on the hot water heater was probably what is called a "piezo-electric" ignitor. It's normal for it to make a snapping sound and then pop back out. It sounds like you just lost the pilot light.
That being the case, do this:
Turn the gas valve on the hot water tank to the "off" position - it should be silver in color and down low on the tank. You may have to push it down to do this
Leave it off for about two minutes or so
Rotate the valve back on to the "Pilot" position
Hold down the pilot gas valve - it should be red and immediately to the left of the main gas valve.
While holding the pilot gas valve down, push the other red button to the right of the main gas valve - this is the piezo ignitor - push it several times in a row quickly
The gas pilot light should light
You can stop pushing the ignitor now, but continue to hold down the gas pilot valve (the one just left of the main gas valve). Let this valve up after about another 20 seconds or so.
Now rotate the main gas valve to the "on" position
Listen carefully - you should hear the main gas light and feel heat at the water heater flue outlet on top - don't touch it with your hand - you could get burned
If no luck, repeat the process until the heater re-lights
TIP - the instructions for re-lighting the pilot should be written on the heater
Just a potential diagnosis - the thunder clap, if as close as you describe, may have been intense enough to create what is known as a "draft inversion" that may have snuffed out your pilot light. The air pulse came down the flue pipe.
Apr 08, 2009 | American Standard Water Heaters
RTO W4 A.O Smith Gas Hot Water Heater Draft Inducer Logo
122 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
