Hi e9 error code on a defy laundromaid electrlogic 1300 change the pressure switch,cleaned all pipes nd filter stil a e9 error code dus any 1 know hw 2 fix it??? Plz tel me
5 Suggested Answers
SOURCE: I have a Defy Laundromaid
I have a Defy Laundromaid 1300. I was getting an E9 message.How can I solve this?
Posted on Sep 21, 2010
SOURCE: I have Defy Laundromaid
Hi, I get an OD (wording) on my machine after washing-dosnt rinse or spin... what can that be???
DEFY LANNDROMAID 1300M!!!
Posted on May 08, 2011
Chesc
  • 59 Answers
SOURCE: Defy - 13KG Laundromaid 1300
Here's a solution I've gotten from one of the experts..
"Clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!"
Hope this helps.. Good luck! :)
Posted on Jun 09, 2011
aa1qt
SOURCE: Hi my washing machine works perfectly fine but
first make sure your cycle knob is not in the soak position. Then manually advance knob to the spin cycle. when it spins it should alternate draining water as it spins every few secounds,then it will spin up faster and finsh draing steadily.if it won,t drain during the spin mode then your control knob timer is bad. will it automatically go fron wash to end of cycles on its own with the knob moving on its own from wash to end of all the cycles if not then when it gets to spin or rinse it reaches a bad spot in the cycle advance timer not allowing the draining to be switched on as it advances thru the cycles.
Posted on Nov 26, 2014
Defy Laundromaid electrogenic 1300 drum doesn't
Possible blockage in the waste pipe stopping it from draining quickly enough or lack of water pressure getting in.
Sep 27, 2014 | Washing Machines
How do you fix Error Code OE on defy laundromaid electrologic 1300 ? Machine washes, but when it should start to spin, nothing happens - it's just making a noise for a while, no water releases and then...
If draining is not completed in a specified time limit the fault code OE will be displayed.
Check the drain hose is free (not kinked or deformed) and check there is no dirt in the drain filter.
The filter is located behind a cover on the kick-panel at the front of the machine.
May 01, 2014 | Washing Machines
My defy laundromaid electrologic 1300 suddenly stops spinning and gives a ue error
I had the same problem: E9 error when switching the machine on. This indicates something is wrong with the pressure switch. (or connection to the pressure switch). When you open the top cover at the back of the machine it will be in the right hand corner (when looking from the back of the machine). This is a round device with a clear tube coming in at its bottom and a three wire connecting plug at its side. When unplugging I found one of the pins corroded (green tarnish). After cleaning it off with some steel wool the problem became intermittent - indicating the connection is not too sound. Just bending the pin slightly did the trick causing it to soundly make contact inside the plug. Problem solved!!
Aug 03, 2012 | Washing Machines
Defy - 13KG Laundromaid 1300 - Top Load Washing Machine Model: DTL125 Serial number: KW077E1620687 Error: E9 please help
Jun 09, 2011 | Washing Machines
I have a Defy Laundromaid Electro Logic 1100 washing machine and it is now giving me an E9 error. What could be the problem?
Error E9 means a problem with your water pressure sensor. Check the sensor by pulling the hose attached to the bottom part of the tub and blow on it and test the terminals of the sensor if it will close or open.
Hope helps.
May 28, 2011 | Washing Machines
I have Defy Laundromaid 1300. I was getting an E9 message.
Sep 21, 2010 | Washing Machines
Washing Machines Logo
112 people viewed this question
Top Washing Machines Experts
