Question about LG CU500 Cellular Phone
Hands free car kit
G,day, I have just fitted a hard wired car kit Model HFLGTU500, everything is working except my speaker & microphone. The yellow wire for the radio mute is the only thing I did'nt hook up, would this be the cause of the problem?
Re: hands free car kit
  1. The microphone socket is very tight. Ensure the microphone plug is pushed in completely on the handsfree Control Unit.
  2. There is a small cable and plug inserted into the top of the handset carrier. This is only a plug holder. The speaker will only work when this plug is plugged into the earphone socket on the side of the handset.
Posted on Feb 11, 2008
0 characters
3 Points
Microphone problem
First u have to check that ur microphone is working correctly or not for this use hands free. If hands free works perfectly then then ur microphone speaker is damage u have to change it.
Dec 03, 2013 | Samsung Cell Phones
I can hear caller caller cannot hear me please help 910i
Your phone's microphone is not working and so it must be checked. See that the is no block to the microphone pores-- the small hole for the voice to be taken to the mic.
IF so use a hands-free to check if the circuit is working. If so the phone has no issue except a fault in the microphone or a connection fault in the hands-free.
You need to remove to check and must attempt only if you are confident.
May 02, 2011 | Sony Ericsson W910i Cellular Phone
Everything on the phone seems to be in great working condition, except, when I make a call, NO ONE can hear me on the other end. The phone worked perfect yesterday, but NOT today. I have had the phone...
there's no way you could turn your cellphone's microphone off,have it check with your nearest nokia wireless center for calibration and allignment.
Aug 21, 2010 | Cell Phones
I dropped my Blackberry Curve and the phone clicks...
the volume button may be stuck in a weird position on the inside. you may want to take it apart and clean the inside and reassemble. if you cant then a local repair shop may be able to do it for you
Apr 27, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Everything works except no one can hear me
If you took the battery out to reset the phone, and it still doesn't work - try plugging in a wired headset.. see if they can hear you when you talk into the microphone on the headset.
If they can, then your microphone on the phone is broken, you'll need to replace the phone. (Under warranty? Insurance?)
Anyway - a headset may get you through your phone calls until you can replace your phone.
But maybe a reboot will solve it.. hopefully.
Mar 22, 2009 | LG VX8300 Cellular Phone
Microphone volume low on sciphone i68
I found a solution but not a final one, during the call turn on the hand's free speaker and the microphone will work fine, you can set the hadsfree speaker to the minimal output so you can use it as the regular ear speaker and the microphone will continue to work well.
Dec 08, 2008 | Cell Phones
Hands free kit microphone problem
please change the headphone jack
Jul 21, 2008 | LG CU500 Cellular Phone
K800i no call volume
A problem with the internal microphone, or the contact between it and the circuit board, more often on the later, cause a condenser microphone is quite rugged. Anyway, it really needs professional attention, but if you're adventurous enough all you need is a T5 or T6 screw driver to open. Clean it, but don't use any liquid.
Again, it's a delicate job, better handled by professional on that field. You might end up losing your phone altogether.
Mar 25, 2008 | Sony Ericsson K800i Cellular Phone
LG TU 550 (australian model)
you have to buy bluetooth headset
and then connect to your mobile
for more information
you can mail me
Jan 06, 2008 | LG CU500 Cellular Phone
LG CU500 Cellular Phone Logo
121 people viewed this question
Top LG Cell Phones Experts
Scott Fryer
Steve Sweetleaf
Steve Sweetleaf
Jeremy Murray
Jeremy Murray
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
