Question about Garden
Cuts out every two min - Garden
Heater fan runs for a few min then shuts down
Check the afc Automatic fan control is shut off too soon .
Apr 29, 2017 | Vulcan Heating & Cooling
1993 chevy cavalier 2.2 engine cuts off when cold or hot
Someone will need to check it over when it fails to start. You need to know if it is not getting fuel to the injectors or spark to the plugs.
Jul 28, 2013 | Cars & Trucks
Dehumidifier run for about one or two min, then cut off.let it set for a min. turn unit off then back on then it run for the one or two min. then cuts off.
More than likely, the humidity extraction setting is set to high. Lower it to 35% or if you have manually controlled (No LED Screen) unit, set the control knob to Maximum.
Hope this helped you.
Jul 12, 2011 | Goldstar Dehumidifiers
My son is trying to get the free online gaming but keeps being asked for the wep code and is getting very frustrated with this now does he need a separate router to the one which is for my computer and...
...Set up the IP Address. Or if on a router make sure all the plugs are in then cut it off for 3 min (The Ps3 too) then on the router somewhere look for "reset" reset it. now cut the router back off for 3 more min.(never cut ps3 on) then after 3 min online! :)
Jun 19, 2010 | Sony Playstation 3 (PS3) Console
I can cut for about 4 min. then Cup Error
look at your duty cycle 40 % duty cycle is 4 min 10 min sraight is minimum 100%, but good machines weld for 3 or 4 shifts till they get turned off
my 2 cents
Feb 25, 2010 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
CONSOLE RUNS GAMES BOUT 10 MINS CUTS OFF RED
Make sure the fan is running and make sure its clear of any dust and / or obstructions, if its cutting out after a certain period then its oveheating.
jonno
Nov 02, 2009 | Sony Playstation 3 (PS3) Console
Magnavox tv
the automatic code is actived.
Nov 09, 2008 | Philips Magnavox 42MF521D/37 Television
Sony KV32s22
Hi: Sounds like it might be an overheating part, and the short is shutting of the set. Or it could be an intermittent connection in the pc board. Either case it would have to be repaired by a expert.
sorry.
Mar 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
