Question about Garden
How do I bypass the blades disengaging when I go in reverse. I know I shouldn't but I want to.
    Sergeant:
  • Garden Expert
  • 187 Answers
Bypassing the reverse switch. No No No
I am a professional mower, I hate that safety switch. Of course, I mow without it, but don't try this at home. Only professional mowers on a professional course, mowing government sponsored safety grass, can assume this liability. WARNING, WARNING, WARNING. There now I got all the warnings out the way, I cannot tell you the very obvious secret, so you are on your own.
I can tell you, on a Hydro Tranny (you know the automatic transmission) there is a switch on the transmission case (called the RIO Switch). This is the last device controlling the ground path that kills the engine. This switch is normally open. If the reverse linkage does not push the button on this switch, thereby closing the switch and completing an internal ground path, the engine will not die when you are mowing in reverse. Say for instance a stick you ran over knocked this switch crooked, or completely out of its holder and it was just hanging over by the frame (you know, accidentally caught on a wire tie), why then every time you tried to reverse with the blades running, you wouldn't be safe cause the blades would just keep spinning. My professional advice: You should get that looked at right away.
Posted on Apr 19, 2015
  • rodney bartholomew Apr 20, 2015
    Nice..gotta watch the sticks.got it..that's good.mark one in your column. Love It..
  • 1,169 Answers
Hint: It is the reverse switch that needs bypassing.......
5 Suggested Answers
  • 3 Answers
SOURCE: Mower will not disengage
this is because your belt that drives the blades is to tight i suggest getting a looser belt
Posted on May 10, 2010
  • 2239 Answers
SOURCE: blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Posted on Jun 24, 2012
  • 6468 Answers
SOURCE: lawnmover blades engage when shouldn't
on the linkage to tighten the belt one of them is adjustable look for a rod with a lock nut on it
Posted on Aug 24, 2012
  • 2239 Answers
SOURCE: blades disengage when in reverse even if ign. switch is in safety bypass
Faulty micro switch on the gear shift lever, or the switch is not contacting the activating bracket, or the wires have come adrift.
Posted on Dec 15, 2012
While mowing the blades disengage and engage ?
your battery might be going bad if the unit has an electric PTO clutch
Nov 15, 2015 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
Why won't my riding lawnmower shift into reverse?
Some mowers will not allow you to shift into reverse with the blades engaged for safety reasons. Try disengaging the blades then shift into reverse.
Aug 22, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blades disengage when in reverse even if ign. switch is in safety bypass
Dec 13, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Lawnmover blades engage when shouldn't
Aug 23, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Blade engagement lever won't disengage
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Hi...I have a 2005 Cub Cadet 2042. With the switch in ''normal'' and the PTO engaged, when going forward cutting the grass the PTO will disengage for no apparent reason. You have to push the PTO knob in...
In the cub cadet, the PTO power is maintained via a latching circuit that includes a reverse switch and a reverse relay. Locate the reverse switch that senses whether the tractor is in reverse -- either it's come loose, become misadjusted, or it's failed, or the wiring and connections are loose. You could bypass the switch to confirm this as the problem.
Jul 10, 2010 | Cub Cadet Garden
May 10, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Blades run in reverse and only for a short distance going forward
ok when was the last time you had the hydrolic fluid changed ?
or the oil for that mater ?
oil breaks down
you wouldnt cook your french fries in year old oil but you will cook your tranny with it in a cub or mtd machine 100-120 hours max for the fluids in an mtd b4 they start to loose texture or viscosity ( sound it out)
hydro pumps di die mtd has 1 monster that is quite expensive also have you changed the filter on the rear axcel lately or is it full of nut butter and in bypass mode
100 hours doesnt seam like much but for a tractor it is
service service service
Jul 25, 2009 | Garden
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Garden Logo
82 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
