Question about ZEEPAD 9XN Dual-Core 1.5GHz 512MB 8GB 9" Capacitive Touchscreen Tablet Android 4.2 w/Dual Cams Stylus & Earbuds Red
Will not power up when power is pushed it will turn on but will not do anything else need to return it its junk need adress to return it
  • ZEEPAD Master
  • 3,960 Answers
Please contact the vendor it was obtained from directly. Fixya has no procedures or processes to accomplish this for you.
Posted on Apr 19, 2015
Whats the difference between trash and junk and how can I get rid of junk quickly?
Trash would be anything that you delete that comes from people you get email from. Junk would be like junk mail...unwanted or spam emails. Usually junk/spam email deletes instantly so you cannot retrieve it if you make a mistake. Trash usually deletes in 30 days. Some email servers allow you to change those settings as well
Jul 10, 2016 | Apple iPad Mini
My Tablet has been charging for day and I cant get it to turn on, what do I do?
first try pushing reset buttom
or a hard reset hold power button and tap vol up
Jun 15, 2015 | Visual Land Prestige Pro 7D 7 inch Tablet...
Tablet frozen will not return to home screen
Try to hold the power button down until the tablet reboots.
Jan 12, 2015 | Irulu 7" 4gb Mid Google Android 2.3...
My tablet is frozen what can i do?
You would hold the power button for 10 seconds until the unit turned off or reset. If that does not work please post the make and model of the tablet for further instruction.
Dec 26, 2014 | Tablets & eReaders
Can't use my tablet. Getting error: the process android.process.acore has stopped. Is there anything I can do?
Unfortunately, I purchased the same tablet and found it to be junk as well. I returned it and was sent an M9200...just as bad, so they refunded my money and I still have the terribly, slow tablet. Try resetting the tablet by uncovering the tiny hole to reset it covered by a small sticker on the back of the tablet.
Oct 20, 2014 | Kocaso MID M9100 9 Dual Camera Android 4.0...
It crashes, won't turn on after resetting numerous times
Replace the battery delete apps you don't need and then reset
Jun 30, 2014 | Proscan 10.1-Inch Internet Tablet,...
Screen wont come on
Hi Rita
I would recommend for you to turn the iPad off completely and restart it. To do this you push the power button in the top right until "hopefully the red "swipe to turn off button" appears. If this does not happen we will have to perform a hard reset and the way to do this is to push the power button and the home button at the same time for about 10 seconds. The iPad may restart automatically however if it does now now you can push the power button in the top right and the Apple Logo should appear at the center of the screen.
Now your iPad should start up freshly and come back to life, unless there isn't a further problem.
Dec 07, 2013 | Apple iPad (16 GB) WiFi Tablet PC
Touch screen not working on top inch or so.
Connect it to a computer and download and install newer or alternate software. There are factory resets on most which is typically done by powering off then holding both the power and volume button (can be either up or down). Try holding a combination of home and power or volume and power for up to 2 minutes on some devices. On some devices this puts them in down - load mode and it will need the new rom or flash software which can then be flashed to this device, some devices will at this point give you the option to factory reset, keeping in mind that all saved data will be lost at this point. If you flash the device with the wrong rim you may turn the device into a paperweight or otherwise known as Bricking" Most times a device will need to be rooted prior to installing anything other than the factory Rom. Try searching YouTube on how to root or factory reset your mobile, android, or Apple, RIM (blackberry) devices. Also is how to upgrade to a better android operating system but caution here as it's a critical process that needs to be done correctly and without interruption so a lot of study will be necessary for the novice and be prepared to need further solutions to newer problems that may arise from err or lack of knowledge on the precise procedures.
Dec 05, 2013 | Mach Speed Trio Stealth G2 Tablet -...
My trio stealth g2 won't turn on the battery drained last night so I put it on charge and in the morning I took it off and I pushed the power button and all it said was trio stealth g2 and it thats all...
there are several things u can try to reset it. but i have not seen many of reset and continue to work without having other problems. check out this link first.
http://youtu.be/jcreuqRxK6w
there is a reset on the back of the tablet..l use a paper clip and push the reset button and hold it until it turns off and then push the power and the sound buttons together ..sound button up. if this does
work use the power cord to charge it. if this fails return it with the link i use above..
good luck
chad man
Sep 01, 2013 | Mach Speed Trio Stealth G2 Tablet -...
When I turn on M275 I get power light, hard drive
I have the same M275 tablet and was looking for a solution when I came across your post. I couldn't find a solution so I went over every nook and cranny of my tablet and found my hard drive was not completely pushed in. I pushed it in tried the power button again and it worked! I am shocked because my laptop has been down for a year now. I thought maybe it was a motherboard problem and it was junk. I'm so excited. Anyway all I can suggest is check that the hard drive on the right side is completely plugged/pushed in. I hope that works for you.
Feb 06, 2010 | Gateway M275 Tablet PC
ZEEPAD 9XN Dual-Core 1.5GHz 512MB 8GB 9" Capacitive Touchscreen Tablet Android 4.2 w/Dual Cams Stylus & Earbuds Red Logo
Top ZEEPAD Tablets & eReaders Experts
Frank Russell
Frank Russell
Da Doc
tony wahlman
tony wahlman
Are you a ZEEPAD Tablet and eReader Expert? Answer questions, earn points and help others
