Question about Aqua-Pure Filter Cartridge, 0.5 Microns, 0.6 GPM - AP-DW85
Leaking from the intake and out take
Changed filter and now leaking from both in and out takes of water
What else can cause this leak
there is a plunger inside them takes o rings too
May 02, 2015 | Refrigerators
Soloniod faulty
check the filters
at the intake the solinoids {water intake valves}
there is a small filter
you need to turn of the hot and cold water
like under the sink
take off both hozes hot and cold
then take out the filters at the machine intakes
and clean them
you can take out the filters
using flat nose plyers to gently pull them out
clean them out from brown crypto spyridion carcus
and other rubbish
you can leave the filters out and run thru the whole machine on like 30deg with a calgon tab
does help {not scotland no lime here }
then place the filters in the intakes again
or replace the valve if it leaks water after cleaning
then the spring in the valve of the valves solinoid coils isnt so good
and needs replaced
but can just be a blockage
above all if its a new machine you just got
perhaps it been in a low presure area so the valves will be
low presure hot and cold
usually its just the hot that is low presure
so you need to check the cold water is getting plenty on like 2 -3 bar presure...
Mar 05, 2015 | Washing Machines
F-750 with a cummins lacks power ,changed fuel filter several times
Could be a lot of things. Is it smoking excessively. Could be a clogged air filter. Bad turbo. Intake leak leaking boost pressure. Bad injectors. Failing fuel pump. Does it misfire?
Sep 22, 2014 | Cars & Trucks
Why wont my steelcraft 13 gallon 5hp model ta25 build up no more then 20 pound of pressure and all i did was change the oil?
Check all connections for air leak including the water drain valve with soapy water. If no air leaking from connections, spray soapy water on head area where head attaches to the cylinder checking for gasket leaks. If no leaks are found, most likely problem is in the head /valves /internal gasket leak. If head gasket or valves are leaking, you will notice that air seems to blow out of the intake filter (normally there is good suction at the intake). Good luck
May 16, 2014 | Air Tools & Compressors
My 2003 1450cc fuel injected Harley Davidson softail won't idle.. Starts every time and runs fine but once you let off the throttle it dies.. please help?!?!
This could be an intake leak, fuel injector leak, oil sumping issue or the IAC is not working correctly or TPS not reading correctly. It could also be a cable misalignment issue. Check oil level if lower than normal you could have a sumping issue so if you have loss of power you have a sumping issue, to check for intake leak pull air filter off and spray either soapy water at intake seals or starting fluid at seals if there is a change in idle change seals, with air filter off cycle ignition 5 or 6 times and watch to see if the injectors are leaking. After that open throttle plate and turn ignition on and watch to see if the IAC pintle is moving if not replace stepper motor.
Aug 18, 2013 | 2003 Harley Davidson FXST Softail Standard
I have 2004 ford taurus that has a #4 misfire I have changed plugs and wires also changed injector checked compression. changed coil and fuel filter and tried a cam sensor... THE PLUG IS VERY WET whats...
What kind of wet? Is the wetness gas, oil, or water? There are different types of fouling possible with reading the color of the old plug being a good indicator. Is the compression within limits?
Check your intake manifold by taking it off and comparing the ports going into the head. If the intake port on #4 cylinder is wet there may be a problem in the Intake. You will also be able to look at the intake valve stems on most motors. The newer designs have the water going into the block directly so the Intake contains no water.
You could have a bad oil seal on the valve stem. You could have a head gasket leak. Even some oil rings can still sling oil and if the power rings are good, it still will compress and give good readings.
You need to run the motor again and try wiping the plug again to see what kind of deposit is on it.
Aug 11, 2011 | 2003 Ford Taurus
My 2002 sport trac stalls or runs ruff at low rpms, r there any easy fixes?
You might get some relief with a free scan at Autozone or Oreillys. Sometimes the diagnostic computer in your truck will have some info and not set a trouble code.
The usual tuneup stuff like clean oil,air filter,PCV valve, gas filter should be looked at first. Do an intake manifold test with a water bottle. Spray a stream of water around the joints of the intake manifold (with motor running) to find leaks. A leak will change the Rpm or stall it.
Check your sparkplugs for condition or replace them. A dirty EGR valve may not close tight, sometimes taking off the Airhorn and cleaning the intake manifold directly under the airhorn will help. Replace the gasket for the airhorn. Clean EGR opening.
Thats about it for quick cheap fixes. A TPS throttle position sensor is inexpensive and may help if all else fails.
Apr 21, 2010 | 2002 Ford Explorer Sport Trac
2009 Chevy Traverse Intake Pluem Full of creamy foamy water apon removal
It it water or anti-freeze?
If its water then somehow water was sucked up through the air intake. Check the filter box for leaks. If no leaks in the filter box then check all connections from the air box to the intake plenum.
Jan 24, 2010 | 2009 Chevrolet Traverse
I just change my water filter on my whirlpool conquest refrigerator because there was no water getting through and the filter indicator said it needed to be changed. I changed the filter but the water...
1. did you let the water fill the filter it takes about a cup and a hlf on some let it run s asec
2. check to make sure you have water to the machine is it clogged at the intake
Oct 05, 2009 | Refrigerators
1997chevy expresss van leaking water pump and intake gasket leak
you need get the water pump change. seal broken and it is probably stop working.
check the thermostat when you at it. it probably need change too.
Nov 12, 2008 | 1997 Chevrolet Express
Aqua-Pure Filter Cartridge, 0.5 Microns, 0.6 GPM - AP-DW85 Logo
439 people viewed this question
Top Aqua-Pure Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Aqua-Pure Measuring Tool and Sensor Expert? Answer questions, earn points and help others
