Question about Boating
My boat motor wont charge - Boating
    Problem Solver:
  • 17 Answers
If its an outboard it is probably the rectifier. If you hooked up the battery backwards it will have blow the rectifier. You can check you should have AC coming off the yellow wires and dc coming off the red wire and ground. If your tach does not work that may also indicate a blown rectifier.
Posted on Apr 20, 2015
My 2004 volvo boat motor wont start
Hi Randy.
There is a number of things that could cause a motor not to run,
I'd start with fresh fuel / make sure that it has spark.
The three things that make any motor run ( spark fuel and compression.)
Good luck.......
May 02, 2016 | Boating
I have a 65hp suzuki outboard motor wont start just makes clicking noise and tilt aint working now motor was running season before
try installing a fully charged battery or charge the battery for 24 hours then jump start the boat from a car
Jun 24, 2014 | Suzuki Service Manual, 2 - 65 HP Outboards...
20 hp Boat motor wont turn over
I WOULD CHECK FOR SPARK . perhaps there is a kill switch on lanyard that needs attached .
Jan 02, 2013 | Light Outboard Motor Boat Bass Fishing...
Hi i just bot a bass boat with a 40 hp mercury motor that has ben sitting up for 8 or ten years. so what should i do before i try to start it again because it wont start at all
First know that they have a neutral safety switch which will stop the motor from spinning if the gear is engaged. so put it in neutral first.
Second- will it even go round? take the hood off and try to spin it by hand. Just to see if it is free. If it is stuck, check the lower unit oil for a lot of rust and water. That will stop it too.
Next - charge or change the battery,
Take the spark plugs out and see if there is any compression, or are there metal pieces found on the spark plug?
Then- or first- buy a book on your motor and a general book on boating.
Practice un-tying the boat and moving it off the trailer at home so you don't look like a novice at the ramp.
After 5 years the water pump should be serviced- use a garden hose and flush attachment or trash can full of water when running it at home- don't forget to put oil in the gas.
Dec 06, 2012 | Boating
Boat motor won't start. battery fully charged
I would have the battery tested anyway to make sure you don't have a dead cell. Usually even with a weak battery the starter will try to engage the flywheel on top of the motor.Besides the battery check the fuse located on the motor. If all is good then you can remove the starter for testing and possible rebuilding.
Jul 07, 2012 | Nitro Boating
Starter motor wont work evinrude 50hp 2cyl
Sometimes there is a switch which prevents the starter from working in gear. This switch could be out of adjustment. Otherwise you need to check for a bad relay by jumping the one you can find and seeing if the starter will turn. Check the grounding on the motor too.
Feb 01, 2012 | Boating
85 horse boat motor
check the spark plug and check the fuel filter. if still no response check if there is spark comming out of the spark plug
Sep 22, 2009 | Boating
Outboard motor charging systems, do they exist or do i need to periodicly charge the battery for my boat
Look at your ID plate and get the model number of your motor. Then contact the Johnson dealer and see if your model comes with a charger, be it alternator or magneto. Many use systems similar to riding lawnmowers and they do not need charging.
May 18, 2009 | Boating
Mercury outboard over charging
Your motor is fine. It needs to put out more than 12 volts or the battery will not charge. Most alternators put out between 13 - 17 volts, so this is well within the range.
May 09, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
90 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
