Question about Pool & Spa
Leaking from the in and out take - Pool & Spa
  • 1,631 Answers
If pipes going into pump and from the discharge of pump, are leaking, then reseal the thread with new Teflon tape and silicone sealant. If unions, then replace o-rings.
Posted on Apr 20, 2015
What is a P2404 code mean from a suzuki sx4
Trouble Code: P2404 (2.0L L4 VIN 5 Automatic CVT)
Evaporative Emission System Leak Detection Pump Sense Circuit Range / Performance
Number of Trips to Set Code: 1
Trouble Code Conditions:
EVAP vent valve stuck open: EVAP leak check pressure is lower than -0.14 kPa even if EVAP vent valve is operated from OFF (OPEN) to ON (CLOSE) with EVAP leak detection pump ON. EVAP vent valve stuck closed: EVAP leak check pressure is unstable (difference between maximum and minimum is 0.36 kPa or more) when EVAP vent valve is OFF (OPEN) with EVAP leak detection pump ON. EVAP leak detection pump stuck OFF: EVAP leak check pressure is higher than -0.14 kPa even if EVAP leak detection pump is ON. EVAP leak detection pump flow high: Reference pressure of EVAP leak check pressure is lower than specified value (depending on BARO) EVAP leak detection pump flow Low: Reference pressure of EVAP leak check pressure is higher than specified value (depending on BARO).
Possible Causes:
  • EVAP leak detection pump (in EVAP leak check module) and/or its circuit
  • EVAP vent valve (in EVAP leak check module) and/or its circuit
  • EVAP leak check module and/or its circuit
  • ECM
Jul 11, 2014 | 2010 Suzuki SX4
My 2001alero has been leaking oil. I was driving down the road and it didn't have any power. Ipushed the gas pedal to the floor and the car didn't Rev up at all and it acted like it wanted to shut...
Click this link below for oil leak and rev issues:-----http://repairhelpcenter.blogspot.in/2012/02/car-has-oil-leak-and-shuts-off-at-rev.html
For oil leak problem,click the link below.This are direct hel links to troubleshoot the problem :-----
Common Causes of Car Oil Leaks?http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html
Troubleshoot Car Oil leak?http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html
leaking oil from oil pan?
http://howtobyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html
Car Turns OFF due to low oil pressure warning light?http://schematicsdiagram.blogspot.com/2011/12/car-turns-off-due-to-low-oil-pressure.html
leaking oil from timing cover?http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve cover gasket?http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Oil leaks from air filter ?http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
Rear oil seal leaking?http://schematicsdiagram.blogspot.com/2011/12/rear-oil-seal-leaking.html
This will help.
Feb 13, 2012 | 2001 Oldsmobile Alero
Antifreeze is leaking on the passenger side of the car behind the engine where could the leak be coing from
For this types of problem,check the help link provided below.Click the link below to go through its troubleshooting procedure:-----Antifreeze leaking from front of engine near Air intake? http://technoanswers.blogspot.in/2012/02/antifreeze-leaking-from-front-of-engine.html
----------Antifreeze leaking from freeze plug on throttle body? http://technoanswers.blogspot.in/2012/02/antifreeze-leaking-from-freeze-plug-on.html
---------How to locate the vacuum leak? http://howtobyme.blogspot.in/2012/01/how-to-locate-vacuum-leak.html
-----------How to Perform Car AC Leak detection Test? http://repairhelpcenter.blogspot.com/2011/11/how-to-perform-car-ac-leak-detection.html
------------Common Causes of Car Oil Leaks? http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html----------- Troubleshoot Car Oil leak? http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html
-----------The plastic housing which goes to the upper radiator hose is cracked and leaking?
http://schematicsdiagram.blogspot.com/2011/12/plastic-housing-which-goes-to-upper.html
Radiator leaking? http://repairhelpcenter.blogspot.com/2011/12/radiator-leaking.html
-----------This will help.Thanks.
Feb 08, 2012 | 1997 Buick Century
I have mazda 6 2004....earlier i have radiater leak...then i repaired...then again it started heavy fuel consumtion...and chek engine indicator appears on dash board...i have engine oil leakege also..
FOR oil leak issue and other problems you mentioned check the following help links:---
consuming more fuel? http://repairhelpcenter.blogspot.com/2012/01/toyota-tercel-consuming-more-fuel.html--------- How to maximize fuel economy on your vehicle? http://schematicsdiagram.blogspot.com/2011/11/how-to-maximize-fuel-economy-on-your.html
Check Engine Light On car? http://schematicsdiagram.blogspot.com/2011/06/check-engine-light-on-car.html
Car oil leak?
Oil leaks from air filter on ford?http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
---------This will help. Thanks.
Jan 27, 2012 | 2004 Mazda 6
Why is my car leaking oil
its common for some automakers to leak oil, run badly, break often, & otherwise be a plain hassle............I would suggest reading consumer reports before buying new or used cars.
Jan 23, 2012 | 1996 Volkswagen Jetta
Leaky transmission fluid. possible reasons?
TRANSMISSION LEAKS COME FROM TRANSMISSION OIL PAN GASKET LEAKING.OIL COOLERS LINES LEAKING.LEAKING AT TORQUE CONVERTER FRONT SEAL.TRANSMISSION SPEED SENSOR SEAL LEAKING.FRONT AXLE SEALS LEAKING AND LEAKING AT TRANSMISSION COOLING LINES TO RADIATOR.CHECK ALL YOU WILL FIND LEAK.IF YOU HAVE FAST LEAK OR PRESSURE LEAK.WITH CAR RUNNING IN PARK EMERGENCY BRAKE APPLIED LOOK UNDER CAR IF YOU SEE FLUID LEAKING OUT IN LARGE QUANITIES.COOLER LINES LEAKING OR TORQUE CONVERTER FRONT SEAL LEAKING.IF YOU HAVE SLOW LEAK THE LEAKS HAS TO BE AXLES SEALS OR PAN GASKET LEAKING OR VSS SENSOR SEAL LEAKING.
Aug 03, 2010 | 1998 Pontiac Bonneville
Pool & Spa Logo
47 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
