Leaking from the hoses in and out take - Computers & Internet
    Genius:
  • 1,552 Answers
Telephone your Internet Service Provider's "Help Desk", and get them to check your connections.
Posted on May 11, 2015
How to repair power steering leak?
You need to first diagnose what is leaking. Most power steering leaks are in the pressure hose but not always. Pressure hoses will have screw on fittings and return hoses will usually just have spring clamps or screw type clamps on the end of the hose. Pressure hose most likely, return hoses 2nd, failing rack and pinion assy 3rd and pressure pump last. If its leaking from the bellows on the end of the rack and pinion the you will need a reman unit. Presure pumps are also remanufactured if thats what you need. hoses are replaced with new hoses or standard return hose for the return line.
Jul 12, 2014 | 2001 Ford Windstar
Leaks water
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Sep 30, 2012 | Washing Machines
Leaks from underneath
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Sep 30, 2012 | Kenmore Elite Washing Machines
Power steering pump/hose leaking
tighten the clamp at the end of the hose. wipe hose off, add fluid see if it still leaks? the oil on the hose could be running down the hose from the loose hose clamp?
May 08, 2012 | Volkswagen Vehicle Parts & Accessories
My rad keeps leaking antifreeze in 2 areas,one in the back one in the front beside the rad.how many hoses to i buy ? also my power steering fluid leaks.do i have to buy one hose or 2 hoses?
time out! is the hose really leaking or is it the radiator itself? no sense replacing hoses to stop a radiator leak. if it is a hose, there is an upper and a lower. your power steering could be leaking at the rack, or a hose (there are 2, a pressure hose and a return hose), or the pump, or the fluid resevoir. you must be absolutely sure where it is leaking before you buy parts unless you are filthy rich, and if you are, you can adopt me real cheap
Jul 07, 2010 | 1992 Mercury Sable
Can thee hose be fixed if it has a leak.
If the leak is on the OUTBOUND side that is towards the Nozzle, it CAN be repaired but for safety I would strongly recommend a new hose. Main reason being that the pressure generated in that hose will blow MOST joints you put in there.
If it is the input side then just get a hose joiner and install it.
Feb 07, 2010 | Karcher Hose Reel
I have a water hose leak and can't find where the end
Cooling system leak is misanderstending of what is leaking ?That it is you can fing by coolant vapoure or leake product like salt ,hose is moste likely must repair whitout replaising usin high temperature silicone .
Aug 08, 2009 | Nissan Quest Cars & Trucks
Leaking wash machine
Depending on where exactly the leak is coming from, it could be a drain hose, drain pump, or tub seal. If this is a top-loader, here's how you can tell:
1. If the leak is coming from the BACK area under the washer, this can be caused by a leaking fill hose, dispenser hose, drain hose, or fill valve.
2. If the leak is coming from UNDER the center area of the washer, this could be your tub seal, a crack in the tub, or an air dome hose leak. NOTE: If the air dome hose is leaking, the washer will fill continuously and not turn off.
3. If the leak appears to be coming from the FRONT under the washer, this could be your drain pump, or drain hoses.
Posting a model number, could assist with determining how your washer is configured. I suspect you may have a drain pump leaking as this is the most common cause, but I want to be sure.
Apr 27, 2009 | Washing Machines
My Whirlpool ultimate care is leaking under,I did check the hoses and they are okey. What could be the problem?.
Can you describe where the leak may becoming from? For example, near the front, from under the washer, or near the back.
If you notice a pool of water coming from under the washer near the FRONT, this is commonly caused by a leaking water pump. Since these pumps are sealed units and are considered non-serviceable, it must be replaced. They cannot be resealed or "fixed".
If the leak appears to be leaking from under the washer near the CENTER of the tub, either the tub seal is leaking or the air dome hose may have come loose. If the tub seal is leaking, it also must be replaced. If the air dome hose comes loose, however, the washer will never fill up all the way and will continuously run. This will cause a flood rather than a drip.
If the leak is coming from the REAR of the washer, this can be caused by cracked fill hoses, loose fill hose connections, a leaking drain hose, or a fill valve hose leaking.
Since you said you checked your hoses, I suspect a water pump, or something loose. Can you please confirm your symptoms and let me know?
Apr 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Computers & Internet Logo
446 people viewed this question
David Payne
David Payne
