Question about DeLonghi Magnifica Coffee Makers & Espresso Machines
The quantity selector has stopped working. The machine carries on pumping about twice as much water as needed.
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 154 Answers
Well I can't say I understood but two things I can say try descaleing to clean the flowmeter if not I would change the flowmeter
Posted on Mar 31, 2016
2 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: Ventilate shows, nothing works
There is an air lock in the hydraulic line of the machine, thats why it is calling for ventilate, if hot water valve is open and it is still calling for ventilate, then it is possible that the valve is blocked, it might be at top of the wand or at the tap rod assembly.
Posted on Jul 29, 2009
My Saeco Xsmall stops before brewing the coffee
1- The grind fineness setting is too fine. Pump is not able to pump through the compacted coffee grounds.
2- The machine is not descaled. The Calcium deposits in the hydraulic system have reduced the pump pressure. The partially clogged water passages can generate a back pressure to reduce pumping pressure. Was the machine descaled in the past two or three moths? If yes, what was the descaling product used?
3- The pump may be air locked and not able to pump water.
4- Oily beans may have been used. Oily beans are poison for the all fully automatic espresso machines. This clogs the grinding chamber or the grinder outlet. This model is made in Romania made in 2006 or after. This machine has a Ceramic Burr grinder 2006 which is a huge problem to clean adjust beans quantity per shot of espresso etc. etc. Occasionally it will dump dry coffee grounds when the quantity of beans powder is insufficient.
Based on the above details, you can figure out what is wrong and fix it. See the exploded parts diagram included, for help. Services Unlimited Inc Parts Guru Since 1988
Dec 29, 2016 | Saeco Coffee Makers & Espresso Machines
WHirlpool wtw6600
HI,
Unplug your washer and open up behind, you will see a thin tube coming down from the control panel (pressure switch to be precise) to the waste area below. Disconnect this carefully from the top, blow into it, air should pass through it should not be clogged; refit carefully. Before refitting, fit a similar tube to the pressure switch & blow - you should hear a click; if not there should be a problem with your pressure switch. Anyway refit your old tube & try the machine.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Tip
The washing machine is under filling water?
This problem is due to fault in the Water-level switch in washing machine.
The Water-level switch is the part in the washing machine that senses the filling water in the tub. When the water reaches to its required quantity the Water-level switch sends the command to stop the water supply. But if the Water-level switch is faulty. It will sense the wrong quantity of water in the machine. And makes the water supply stop bit early then required. So washer does not fills with required water .The Water-level switch is located at the bottom of the outer tub in the washing machine. Many a times removing and reconnecting the switch makes it proper. in other cases it needs to be replaced.
These will help. Thanks
on Mar 18, 2010 | Washing Machines
Stop a whole litre of water going through each time i put a pod in.
The way to program the quantity of water is to press & hold the button you are programming until the amount of water you want is in the cup, then release it. Next time you make a cup with that same button with a single press this time it should cut off with that same amount in the cup. If that doesn't work then take it back, that is what a guarantee is for.
Jan 25, 2015 | Krups Coffee Makers & Espresso Machines
Water led blinking twice
If your machine has the CM3 Universal controller on it and the red light is on at the Diagnostic water then you have a water fill problem.
1. Check the water filter to make sure it is not stopped up, if so then replace it.
2. Check to make sure the water supply line is not kinked.
3. Check the water supply valve remove the supply line to it after you shut off the water supply there is a screen in the back of the valve make sure it is not stopped up.
4. Check the water fill valve, First turn the machine off now push the Freeze tab with a meter check the solenoid on top of the valve to see if you are getting power to it withe the water hooked back to it and on, if no power to solenoid then check the sump water sensor and replace it. If sump is full of water check water pump see if you have power applied if you do then replace pump. At any time did you replace the Service controller? and if you did, did you set the selector switch on the side of it to the correct Model- Program that is on the back of it? With out the model number i don't know if you have a CM3 machine or a PRODIGY controller.
Mar 11, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
At first my Miele CM5000 worked perfectly. When I pressed the espresso button, a perfect espresso would come out- the machine dispensed the correct amount of liquid then stopped automatically. Now, the...
If the espresso coffee outputs too much water and doesn't stop, there is an easy fix. The quantity adjustment for the machine is off. After looking through the user manual, I found out that you could press and hold the espresso button, and then follow the on-screen instructions where you can specify the quantity poured.
Aug 03, 2013 | Miele Cm 5000
For wd802co the machine is full of water and the cycle is work for wash but when the cycle for rince or spin is comming the selector start tu turn at each cycle and he doesnt stop the water stay in the tub...
have you checked the water pump that draws the water out of the machine there maybe an obstruction like a sock or something. Make sure the pump is turning freely there maybe a blockage there. Also check the exit hose as well. Gain access from the rear.
Aug 23, 2010 | Splendide 2100 Vented Washer-Dryer
Intermittent water on floor
Check the inlet valve hoses, even if inlet is at the back, the water may drip down and flow on the front part on the machine. There you also have the PUMP, a faulty pump may leak intermittently.
Here you get all diagrams and parts for your appliance.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
Bunn commercial coffeemaker will not give reliable quantity
Hello. First , I don't find your Model at Bunnomatic.com, and I have worked on Bunn machines for over 21 years, and don't recall a unit by the Model information you provided. However, from your description, it sounds like you have one of these, single units, here:
http://www.bunnomatic.com/pages/techdocs/manuals/satbrew.html
scroll down for the parts/service manuals. The problem you describe has 3 possibilities, one is a water pressure/flow problem, caused by a clogged filter, or too small a supply line with too many units all on the same pipe, try only brewing when nothing else is drawing water. Second is scale build up at the tank fittings for the brew solenoid, build up in the hoses, tubing, solenoids, etc. all of which require cleaning. Third is an actual problem with the timer, or the setting switch. It is always cheaper, if you can do the work yourself, and check the first two items, then you can move to an actual part problem. If you have further issues, just ask.
Hopee that helped, and thank you.
Mar 27, 2009 | Bunn Coffee Makers & Espresso Machines
My washer will not stop filling with water and overflows
Turn the washer on and let the water run, while the water is running unplug the power cord if the water stops the inlet valve is ok but if still running the valve is bad and need to be replace if the pump is good you need to test the water level switch, if faulty need to replace.
good luck
Mar 17, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Coffee Makers & Espresso Machines Logo
63 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
