Question about Black and Decker USA Black & Decker LE750 - Edge Hog, 2.25 Hp Lawn Edger. Exclusive Trench N Edge Guide, Tool Free Assembly, Right & Left Handed Auxiliary Handle, Rubber Treaded Wheels, 3 Wheel Design, High Torque Motor, 3 Position Depth Adjustment With Indicator
My black &decker electric edge hog just stopped running when in use. I tried changing outlets and extension cords but nothing
Black and decker lawn hog 18 was working fine last time used but will not start now what,s the problem
while unplugged rotate the blade a few spins to move the brushes if there stuck make sure the outlet is good and try another power cord
Aug 13, 2012 | Black & Decker Black and Decker Mm575 18"...
I have a black and decker 18 in lawn-mower. I bought a haeavy duty extension cord to connect power to the lawn mover. It was working then suddenly it stop and blew the switch. I plug the cord to a...
I would say the outlet/ cord. here is a recommended types and lengths of extension cord, Tim:
http://support.mtdproducts.com/app/answers/detail/a_id/435/~/what-type-%26-size-of-extension-cord-can-be-used-with-an-electric-mower%3F
May 29, 2011 | Black & Decker Black and Decker & Grass...
Stopped. Black and Decker Lawn Hog 18-Inch Electric Lawn mowe
you could check the brush connection on the motor or your switch mat not be making contact
Mar 28, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
The engine stopped running even afetr changing electrical cords and outlets. Can it be repaired?
Yes, but you may find it as cost effective to purchase another. It could have an onboard circuit breaker, or on-off switch bad, and even the motor itself.
Nov 10, 2009 | Black & Decker Leaf Hog Blower Bv4000
Breaker Blower
if its rated at 13.5 amps, then you should be operating it on a 20 amp circuit. Also, you need to use a 14 gauge extension cord, otherwise the voltage drop on the extension cord causes the motor current to rise
Oct 04, 2009 | Black & Decker 19" Electric Lawnhog...
My black and decker leafhog blower/vac smells like something is burning
Black and Decker has issued a recall notice for Type 1 BV4000 because "a loose connection between the unit and an extension cord can create heat, posing a possible fire hazard" Says to STOP USING and call 1-866-853-2138 to arrange for free repair. (Found info by Googling "Black and Decker Leafhog", navigate to Black and Decker website and click "Important Safety Recalls" button at bottom of page.)
Nov 08, 2008 | Black & Decker Leaf Hog 12-AMP Electric...
Black and Decker USA Black & Decker LE750 - Edge Hog, 2.25 Hp Lawn Edger. Exclusive Trench N Edge Guide, Tool Free Assembly, Right & Left Handed Auxiliary Handle, Rubber Treaded Wheels, 3 Wheel Design, High Torque Motor, 3 Position Depth Adjustment With Indicator Logo
584 people viewed this question
Top Black and Decker USA Garden Experts
James
richie46
Ruth summersides
Are you a Black and Decker USA Garden Expert? Answer questions, earn points and help others
