Purchased this TV two days ago and initially had no issues, connected to my Sky wi-fi. Suddenly after a few hours it start flicking up on screen, dongle removed, then dongle connected.... Went through various settings, disabled wired connections, made no difference, disabled and reset wireless networks, now because the error message is constant I am unable to even search for my wireless network to connect to again, thought a reset might help?
thats the only thing i could find,,so i hope some one else can help you out,good luck.thats the only thing i could find,,so i hope some one else can help you out,good luck.
You can't post conmments that contain an email address.
It seems like the Wi-Fi module on your Memorex HDMI Mirror may be faulty or malfunctioning, preventing it from broadcasting a Wi-Fi signal. Here are a few troubleshooting steps you can try:
Make sure your Memorex HDMI Mirror is within range of your Wi-Fi router. Move it closer to see if it picks up the signal.
Reset the Wi-Fi module by pressing and holding the reset button on the device for at least 10 seconds. Make sure the device is not connected to the TV while doing this.
Try connecting the Memorex HDMI Mirror to a different HDMI port on your TV to see if that resolves the issue.
Check if there are any firmware updates available for the device. If there are, update the firmware and try again.
If none of the above steps work, you may need to contact Memorex customer support or take the device to a repair shop to have it checked for any hardware issues.
The whole idea of having a Smart Television is that it can connect to WiFi and all that the Internet and Internet programming can offer you. If you want to remove the settings you have now, you can do a Factory Reset and it will take it back to how it was when it was new.
You can use the Comment menu item to add information to your question.
Without knowing the model or whether you have an instruction manual to follow, the following question on FIXYA from some years ago gave some suggestions. Of course, it is unclear if you have wi-fi or not, or whether you can enter a password using a remote control for your tv. You may want to call your internet provider for assistance.
The power cable faulty it seems to be a common problem in Luxor TVs if confident unscrew tha back panel the cable is on right hand side of the TV three pinned connection . Release the connector and replace. Or get s TV engineer . He'll repair £10 or £20 . I had same problem six months ago after replacing cable the TV works perfectly
Since it has an internet connection, I'm sure you could buy a set of connectors that plug into a 110 outlet, one to the ethernet connection on the TV, one to a port on the router. Example:
If you have a SCART socket on the back of the TV (it's an optional extra to basic models) then connect the out scart from your Sky box to the scart on the tv. The tv will sense the scart signal and automatically switch itself to use it as it's input signal.
Do a Hard Reset to this set, and check. If it does not help you, contact the authorized service centre for Sharp. Corrupted firmware too might cause this fault. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
