Question about Maytag Dryers
I get code E6 and my Maytag dryer keeps stopping
I keep swicthing the electrical fuse panel to turn the code display om and re-starting the dryer. It runs for a few seconds and turns off. It has done this on several occasions and it has re-started for me but this time it will only restart for a few seconds.
  • Jorge Rendon
    Jorge Rendon Apr 26, 2015
    The 6E error code on this dryer part of this pretty decent stacked laundry unit means there’s a temperature control problem. Le Manu?l identifies three suspects: thermistor, wire harness, and control board. Read more: Maytag SE1000 Dryer Flashing Error Code 6Ehttp://fixitnow.com/wp/2008/05/03/maytag...
  • Jorge Rendon
    http://www.applianceaid.com/maytag-se100...
  • Maytag Master
  • 5,323 Answers
BAD MOTOR WINDINGS OR DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
I get code E6 and my Maytag dryer keeps stopping - get-code-e6-maytag-dryer-keeps-stopping-2twpke0famvgldalck04zdql-3-0.jpg
Posted on May 05, 2015
  • 351 Answers
SOURCE: I have a Maytag Neptune
its a motor problem check to see if theres a capacitor that starts the motor it may be burnt out it will have 16uf etc on it or the motor itself could be faulty if its covered in lint they over heat.hope this helps.
Posted on Mar 07, 2008
SOURCE: dryer will not turn on
i've had my maytag dryer since 2002. it just stopped in the middle of a cycle. i think it's the motor. isn't maytag guaranteed for life???
Posted on Mar 14, 2008
Illeagle
  • 525 Answers
SOURCE: Maytag MDG7600AW Gas Dryer heat starts and then stops
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance. Clicking on the underlined links will take you directly to that page.
If your dryer doesn't heat properly, check this: Venting restriction: Disconnect the dryer temporarily from the vent. If the flame stays on for a longer period, you may have an air flow obstruction to the outside. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Also, in your case, the coils may work fine initially, but heat build up can cause the coil(s) to malfunction and when they cool down will work again.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3479&PPStack=1
This link will help you with disassembly and diagnostics diagrams.
http://www.repairclinic.com/0100_17.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
rtillx4
  • 11 Answers
SOURCE: dryer won't run
I would say that maytag has a problem with lint collection. That is why so many thermal fuses blow and why so many people just bypass this "saftey" device rendering it more dangerous.
I would advise anyone with this model Maytag dryer to pull the front body panel and clean the lint out and then replace the thermal fuse.
Posted on Dec 16, 2009
SOURCE: Maytag 3000 Series front load gas dryer
wrinkle prevent does not seem to work! should sensor light b lit up?
Posted on Mar 21, 2011
How do I fix my cycling dryer.
so you have not done any work on the electrical system at all changed anything or anything like that do you have a model number Appliance 911 Sea Breeze
Nov 15, 2015 | Maytag Dryers
Clean Lint Filter Light Keeps Dryer from starting
Evidently the fuse blew for some reason.
Keep the dryer unplugged from power for one hour or so. If it still does start, you will have to take apart the dryer, check the fuse, check the thermal fuse, and test the wirings inside.
If you need to call arepairman use the number listed on the owner manual.
Oct 06, 2008 | Frigidaire FGQ1442ES Gas Dryer
Neptune dryer won't start. keeps trying and stopping. flashes PF on the display
neptune dryer has 8.8 on display and won't clear. How do you clear this?
Apr 03, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer won't run
thermal fused are one time fuses / maytag want's you to correct the problem that causes this . so dryer is safe. hi heat caused it to fail . so either the fan is not going or there is a restriction causing no air flow . try running the dryer off the vent if it works ok then clean the vent ,, hope this helped . pls leav feed back mm
Dec 14, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Dryer Has No Power
i am sorry to hear this, mdg model number means that you have a gas dryer, you have a fuse and thermastat that needs to be replaced which is beneath the top behind the drum, you will see a short element, a blue thermastat and 2 white wires that goes down to a fuse.
when you buy the fuse, it comes as a kit, the thermastat and 2 fuses, one of the small fuses you will not use because one if for an electric dryer, so look at your fuse and notice a dot, i do believe your dot will be yellow...
so lift up the top and you will see these parts
Aug 23, 2009 | Whirlpool LGB6300 Gas Dryer
Maytag dryer MDE6000AYW keeps blowing the fuse in the panel box, what is wrong? I reset the fuse in the panel box and turn the dryer right back on and it will start right back up. It may or may not blow...
Bad breaker in the panel box.Loose wires at the breaker. Loose connection in the wall outlet. Loose connection at the dryer cord terminal. Bad cord.
One or more of the above.
Jul 05, 2009 | Maytag MDE6000 Dryer
Maytag dryer
• Be sure the door is latched shut.
• Be sure the power cord is plugged into a live electrical outlet.
• Check the home’s circuit breaker and fuses.
• Press the START button again if the door is opened during the cycle.
If everything checks out ok with the above check list, you may have electrical motor issues. I would run a break point test on the motor and the control panel as well. (You will need a Voltage needle to perform a break point test.)
Feb 22, 2009 | Maytag LSE7806A Top Load Stacked...
Bravos Dryer blinking start button
Manual says it could be a number of things, and you should have a copy of the manual since you've only had the dryer 3-4 months. If not, go to the Maytag website and download.
Some things to check -
1) Press Start/Cancel if dryer was stopped in a middle of the operating cycle.
2) Check that one of the two breakers has not tripped or fuses blown (if an electric dryer) in your breaker panel.
Please reply the flashing code number so that I may can help you further.
Jan 19, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Neptune Dryer Time keeps going forever
your problem is most likely an issue with the start button. if it is stuck, the dryer will keep running even though it has passed the off position. your start switch probably needs replaced. Joe
Nov 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
93 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
