Question about Tools & Hardware - Others
How to remove the finish nails from chamber?
Insterted 18 gauge finish nails when realized it needed 16 gauge and now i cant get them out
  • 10865 Answers
SOURCE: Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
Posted on May 20, 2009
mrhappyface
  • 205 Answers
SOURCE: craftsman 16 guage finish nailer. shoots 2 nails at a time. what
wrong gauge nails or wrong head type nails check that the magazine is not loose
Posted on May 29, 2009
  • 131 Answers
SOURCE: Porter Cable 2 inch brad nailer piston does not return
Sounds like the cylinder check seal. That`s the o`ring on the outside of the cylinder sleeve. With little holes in the groove. You have to remove cylinder sleeve to get to it.
Thanks,
Jeff
Posted on Jun 24, 2009
  • 8 Answers
SOURCE: nail gun wont fire
First - the air pressure has to be high enough - check the regulator on the tank to make sure it is delivering in excess of 60-70 psi (which I am sure you have already done).
If you have dry fired these guns (i.e. shot them off with no nails in them while you were lubricating them maybe) the mechanism inside could be damaged. I had that happen to one of my nailers (same brand). That was when I learned not to dry fire them...
Since both of them are not working though I would be more inclined to look at the air supply first.
Posted on Sep 10, 2009
rowdy45176
  • 2176 Answers
SOURCE: looking to buy a manual for a porter cable nail
Go to Dewaltservicenet.com and type in your model number the manual is 13 pages long. If I have helped you with your request would you please rate this response accordingly. Thank you
Posted on Oct 10, 2009
Bostitch troubleshooting
Are you using 18 gauge or 16 gauge nails?
Aug 17, 2014 | Stanley Bostitch FN16250K - 2 16 - Gauge...
BOSTITCH 1664FN 16 Gauge is spitting out 2 nails, stuck together, at once. I cleared a Jam by opening the nose door. I thought there was a piece of metal strip in there. Now it's not there. Is this...
There is not enough room in the nose of the gun for two 16 gauge nails. Most likely 18 gauge nails are the problem (thinner). If nails are correct, tip of driver must be damaged allowing the driver to hit part of the next nail. The driver should be slightly tapered on the side that faces the rails so that the driver will hit first nail head and gently shove the rest of the nails back into the rails out of the way. I dont believe that you have any missing pieces. If nails are correct, remove head and pull out the driver and check for damage. Hold the tip of the driver against nail head, should be slightly thinner than head of nail.If the driver is not tapered slightly on the side that faces the nails, maybe you should sand it a little so the driver will not hit the second nail. Goodluck
Sep 25, 2011 | Stanley Bostitch SB1664FN 16 Gauge...
It wont shoot nails. It releases air by the trigger but no nails come out. Please help I am in the middle of a job. Emergency.
It may already have a nail jammed in it. You may have to take off the front face that holds the firing pin. There should be one or two screws in front just above where the nails come out. If you remove these there will be a plate that comes off and then you can remove a jammed nail. Look first to see if there is a jam before doing this. Also maybe you have the wrong guage nails or maybe you don't have proper air pressure. Hope this helps.
Apr 25, 2011 | Dewalt D51256K 16 gauge finish nailer kit
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
When i put the battery in the light comes. on but when i push the nose down the light just flashes. checked to see if a nail was jambed i cant see any thing wrong can anyone help?
Four flashes is a low battery, multiple flashes indicates a jam.
It may be hard to see - or the driver is stuck. Remove all nails and check again - see silver? It's either the driver (push it back up) or a nail (remove it with pliers.)
Jan 20, 2011 | Dewalt DC616kn 18 - volt 16 - gauge...
Dewalt cordless nail gun fires but doesn't seem to feed the nails very well, alot of misfires.
Try another brand of nails -- maybe your gun doesn't like those. Also, blow any dirt out of the nail magazine.
Sep 25, 2009 | Dewalt DC616kn 18 - volt 16 - gauge...
I have paslode finishing nail gun , i cleaned it, not working now
The smoking is normal for a few times after cleaning ,but you might have put to much oil drops in chamber and piston chamber is getting a "vapor lock". Try recleaning with degreaser. Also have you forgotten to set the depth gauge at front of nose.
Please Rate jj505 Thanks
Mar 23, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Dont know what nails to use on my makita brad nailer
is that a model AF505? if it is, your problem may be the gauge. make sure you use 18 gauge nails, he 16 gauge are too big and will jam in the gun.
Feb 26, 2009 | Makita Brad Nailer Finish Nailer...
Craftsman 16 guage finish nailer. shoots 2 nails at a time. what
Jan 09, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
I have the above dewalt gun just its battery powered, and it doesnt fire the nails
if the nailer is for 18 guage nail use 18 gauge nail if not 16 guage will jam. if it is not the problem is the profile return asyy may jam in side.
Sep 18, 2008 | Dewalt DC616kn 18 - volt 16 - gauge...
Tools & Hardware - Others Logo
19 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
