What does overload mean - Audio Players & Recorders
    Top Expert:
  • 2,899 Answers
It could mean too many speakers on the output.
Also it could mean a signal too high or too strong that is "overloads" the amplifier.
All depends what overload is referring to.
Hope this helps.
Posted on Apr 19, 2015
What does oue2 mean on the scale
Best Answer: Most digital scales have this message (OUTZ) and it can mean that your scale has been overloaded or has simply lost its calibration. If the scale was overloaded, then it is probably done for. Sometimes you can try recalibrating the scale using the manual to fix it. If the scale was delivered with this message, then I would call the manufacturer to have it replaced because it is considered DOA. If it has been some time since you purchased the scale though, and it was damaged from overloading, you may be out of luck, as overloading wouldn't be covered by warranty.
Scroll down a few sections on this page to section 4.
http://www.awscales.com/support/faqs
Oct 10, 2016 | Health & Beauty
Where is the reset button on Elna6004 6004, overload message keeps appearing
The message means that the motor is drawing too much current. Could be a mechanical bind or the motor itself is worn out.
Hope that helps.
Aug 19, 2016 | Sewing Machines
What does error code dc mean?
DC error code means: "Unbalanced load". It can occur if the washer:
1. is overloaded (too many clothes inserted),
2. can't balance the load within a few balance cycles,
3. has a damaged balance sensor,
4. isn't regulated properly (vibrates abnormally).
IMHO you just overloaded the washer :)
Jan 19, 2015 | Samsung Washing Machines
Why are the 2 middle LED lights flashing red I checked the manual and it suggests d06 fault what should I do?
This means - Motor Overload.
Wait and when cooled down it should reset.
Check when it overloads again, if at similar times, then it's likely to be motor.
If it overloads at different times then it could be board.
Sep 03, 2014 | De Dietrich Dishwashers
What does overload conditions mean
it means the vehicle has load more than its capacity. consider the weight. not the amount. if the kg is not over then it may be wheels leaking air and punctured
Mar 11, 2014 | 2008 Dodge Caliber
What does overload mean?
It means you have overloaded, ie: forced too much, or, too heavy a load through the machine and rather than burn up, or seize your motor, an overload sensor/ switch has tripped. I'm not familiar with your machine but there is often more than one level of protection in a circuit. Some reset automatically, some have to be reset with a small pin and others might even have a fuse. First, unplug machine and do a visual to identify and remove any obvious sources of the jamb. Second, plug it back in and start with a lighter load.
May 31, 2013 | Royal Office Equipment & Supplies
What does fL code mean on the wtw6400sw3 washing machine
In your case, when your washer shows LF it means: washer is taking to Long to Fill. And fL would not mean full or overload, because then it would say oL (OverLoad).
I advise you call and ask the company.
U.S.A.:1-800-253-1301.
Canada:1-800-807-6777.
Oct 04, 2012 | Washing Machines
Hunter src plus irrigation panel- Getting a PErr message what is that?
A "P Err" readout means there is an overload in the pump/master valve circuit. A readout of "1 Err" means there is an overload in station No. 1, while "2 Err" means an overload in station No. 2 and so on, depending on the number of total stations being operated by the controller.
An overload occurs when the wiring circuit is requiring more than .56 amps of current. This overload will typically occur when the field wiring or valve solenoid is shorted, or if the field wiring is a smaller gauge than required for the application and/or distance.
Apr 02, 2011 | Garden
States Overloaded. What does that mean?
The shaft is getting stiff and motor can't turn it. Try taking the bottom off and cleaning the fuzz out. Use alittle oil on all of the joints.
Apr 21, 2010 | Husqvarna Huskylock Computerized 936
1988 cheyenne 6 cyl is overloading with fuel and won't idle.
Okay....tell me what you have changed. And, what do you mean overloading....you mean filling with fuel or just flooding?
Mar 13, 2009 | 1988 Chevrolet C1500
65 people viewed this question
 Grubhead
Grubhead
