Question about Toto MS970CEMFG01 Cotton G500 G500 One Piece Elongated 0.9 GPF
My toilet will not respond to the remote. I have replaced the batteries in the remote and the toilet and it still doesnt work?
The remote for intelliseat doesnt work, even with brand new batteries. Any ideas?
My remote worked but the blower would not respond. If that's the issue, take the label off the remote (the corner by the heater button) and put a piece of aluminum tape over the contacts so there is a better connection. I also got a new one from AMDM (under warranty then) but I am still using the first remote I fixed. AMDM customer service: 1-800-778-1450
Feb 13, 2015 | AMDM Intelliseat - The Ultimate Bidet...
Tip
Toto SW834r Remote Control Problem
Note: Toto does not sell parts and requires dending in a unit with a maximum repair price of $300 as of 1/.2015If after replacing remote batteries the seat still does not respond, try the following:1. Turn off the water shut off valve at the wall and unplug the power.2. Unscrew the water inlet hose to the seat.3. Unsnap the seat from the toilet by pushing the quick release on the side of the seat neat the hinge on right side facing the toilet.4. Bring the seat to an area you can get dirty (outside) and remove the two stainless screws on the rear of the seat.5. Carefully unsnap the cover  (four plastic clips inside the cover)6. Clean everything inside and out including water filter on side (unscrews), air filter underneath, top of toilet,  and rinse and allow to dry thouroughly.7. While drying carefully unclip the remote sensor and remove the connector by holding the lock and pulling straight off. Confirm there is no corrosion on the connector. Use a contact cleaner/protector and clean the contacts and replug in the connector.8. It is also recommended to do the same for all of the other connectors.9. Put everything back together.10. Replace hose and plug in power and allow "restart" to finish11. Test remote to see if remote "talks" to seat before turning on water.12. Turn on water and wait for inner tank to fill.13. Manual controls on side of seat can be used to confirm unit is working.  After confirmation the remote should work normally.14. After this procedure my SW 834r worked perfectly......  enjoy.
on Jan 26, 2015 | Home
Replaced battery now nothing works,doors dont unlock,car doesnt start,no sounds when pressing buttons although it still sang when battery replaced,pressed "P" button hoping it would do something and now it...
The waves mean that the remote is vibrate mode. Try reprogramming the remote. Open the door, turn ignition on, press and release the valet button once then, press and hold the valet button. press the lock button on the remote. Vehicle should respond with a chirp from the siren. Release valet button, turn off ignition, test system.
Jan 17, 2014 | Directed Electronics 479V Remote Gen 2...
Sharp aquos remote not working
the polarity of the batteries in case the monkeyed with them.
Remove the batteries from the remote, unplug the Power to the TV, reinstall remote batteries taking care the polarity of the batteries in case the kids monkeyed with them and then plug the power cord back into the TV.
If that fails, take the remote to the store and and see if it works on their Sharp TV like yours. If that fails contact Sharp support for a replacement. (1.800.BE.SHARP)
Dec 17, 2013 | Televison & Video
Philips htl2100/12 soundbar doesnt respond to remote control after plugging in
My soundbar won't power up. So I pull the battery out of remote, press a few buttons, put the battery back in and all of a sudden the device can be powered up and controlled. Until next time it stops responding. I replaced that original battery with a new one but the problem still persists.
Dec 10, 2013 | Philips SoundBar DVD Home Theater with...
Remote isn't working for my Kohler C3-200
Sounds like bad remote that only works partially or some parts on toilet vent bad.
Apr 09, 2013 | Kohler C3-200 Elongated Toilet Seat
Malibu 2007 remote, i changed the batteries now doesnt respond, what should i do? thanks
stop by a chevy dealer and ask them to test your remote. often the contacts in the remote get corroded and crudded up so a new battery will not make it work. if the remote does not test good , then you can buy a replacement on eBay or just take that one apart and clean it. if you get a replacement, your car will have to be reset to work with it, expect there to be a charge for that service.
Jan 20, 2011 | Chevrolet Malibu Cars & Trucks
G1 in the toilet
Let it dry for a longer period. As, if the water has gone into the screen area, draining the water is a real issue. If it still doesnt respond, get it to a service station before the condition worsens.
Jul 27, 2009 | HTC G1
Remote control doesnt respond
make sure the remote works and check the batteries. Call me if that does not work. 4156379989
Apr 08, 2009 | Polycom VSX 7000 Video Conference
Toto MS970CEMFG01 Cotton G500 G500 One Piece Elongated 0.9 GPF Logo
73 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
