Question about Electrical Supplies
I need to know how to wire up my electrical connection to an Akira EM3900DQ
I am not familiar with the plug on the generator and ctn find the pin assignments in the manual
  • 3,957 Answers
It should have NEMA plugs to provide power. Find the plug type from here: http://www.generalcable.com/NR/rdonlyres/75CFEE81-ACDA-4F60-9E22-4CC19C14F343/0/Pg9698_NEMA_Chart.pdf
Once you have identified the plug, google search 'how to install a NEMA [number] plug.
Posted on Apr 19, 2015
Does it need 6mm hard wired cable or can it be used with standard 13amp plug via ring min
hard wired is the normal way ranges are done unless they are gas .then the electric can be lighter gauge
Apr 23, 2016 | Ovens
I get a small electric shock each time i put my hand on the heart rate monitor on the left of the treadmill. Also happens when i h the inclune buttons on the left. Any suggestions?
Hi Pjd
Shocking problem!
Suspect that the treadmill is generating static electricity.
It is building up as you run... via the rubber mat.
Like the comb through the hair picking up tissue paper bits.
This is basically a Van De Graaff Generator.
Try attaching a wire from the machine chassis (metal) to a metal tap at your sink.
Do you still get a shock?
Not sure where you are and what your electric supply is.
I'm in Australia and our AC plugs have a third pin which is connected to our meter box which is then connected to an outside GROUND ROD.
Perhaps the AC power you are using has no ground or only a 2 pin connection. I which case I would add a three wire plug to the treadmill and the ground pin would connect to the treadmill's metal chassis by a screw or bolt.
Anti static spray may also help
Cheers
Van de Graaff generator
https://www.target.com.au/p/anti-static-spray/50563715
anti static wrist strap
Mar 01, 2016 | Exercise & Fitness
I have a AKIRA EM6500AE 5.5kw generator.The engine wiring has been disconnected and the ignition switch has been misplaced.
the wiring to the magneto cud be worn w high resistenc--as well as the fuel system--library sec 629 has books on engines--u can take them out or use referenc
Nov 28, 2014 | Cars & Trucks
I have a three wire cable and a plug to connect to
Can you perhaps copy the connections that are on the female jack on the generator? If not, there should be a diagram with picture on the container the plug came in. Or ... go to a Lowes, Home Depot etc and locate a sample of the plug you have and copy down the diagram. The red and black can be interchanged but the white and green MUST be correct!
Sep 29, 2017 | Electrical Supplies
Manual for a akira generator em8000ae
http://www.manualsdrive.com/results.php?lang=en&search=AKIRA%20GENERATOR%20EM%208000%20AE#.VTDWhl33-iw
Jun 01, 2013 | Electrical Supplies
AKIRA GAS GENERATOR START BUT DOES NOT GENERATE ANY POWER
Reset overloads if tripped. If this doesn't help, inspect and replace if needed the brushes in the generator. If that doesn't help. Inspect for
loose/broken wires. Last resort is a qualifies generator repair tech.
http://www.powermate.com/productmanuals.php?cat_id=3
http://www.powermate.com/pdfs/2011/05/26/pm0106507.pdf
http://www.powermate.com/pdfs/2007/11/17/parts_pm0116000.01.pdf
Oct 05, 2012 | Coleman Powermate Premium Plus 6250W...
Describe your 9100 Next Generation Remanufactured Treadmill Problem display shows waxer disconected ???
Dear Sir:
I will help you inmediately.
1) Display does not illuminate
when machine is powered
on.
Insufficient power source.
Plug treadmill into a dedicated amp circuit.
2) Loose 10 pin connection at
display console or wax/lift
control board.
Check all electrical connections for proper
attachment.
3)Damaged main harness wire
connection.
4)Replace wire harness.
Faulty display console or Wax/
Lift Board.
Verify if 8VDC is present at P1 pin, 3-4 and
12VDC at P1 pin 9.
a)If yes, replace Display Console.
b) If no, replace Wax/Lift Board. See How To...
Replace Wax/Lift PCB.
Use VOM digital (Voltimeter)
Hoping that you can resolve, if you need some extra help, please reach me.
blessing.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 13, 2011 | Life Fitness 9100 Next Generation...
Where do you remove the Ground Neutral bond on a EU6500is generator? I need to do this to hook it up to a transfer switch as per Service Bulletin #20.
Page 39 of the current owners manual for the both EU6500 and the EM5000 generators indicate that there is not a neutral ground bond on these units.
Per the wiring diagram, the ground pin on the outlets is connected to the frame ground of the generators (on both generators). To have grounded electrical service, a bond wire would connect the generator frame to the ground terminal on the transfer switch. The ground system from the breaker / distribution box (usually to a ground rod) then serves as the electrical ground for the generator, as well as the balance of the rest of the system, satisfying NEC requirements.
See Page 39 in both manuals:
EU6500 EM5000
"The system ground is not connected to the AC neutral
wire. If the generator is tested with a receptacle tester, it will not show the same ground circuit condition as for a home receptacle."
Sep 22, 2010 | Honda Transfer Kit for EM 5000iSAB and EU...
Kohler magnum12 gas generator will not produce electric power
Plug an electric drill into your output power at the generator IF you have a plug at the generator. (Output power CB must be on.) IF not the closest point to the generator and then pull the drill switch and turn the drill in the reverse direction. That will flash the field. 1/2 inch drrill works best but with some effort a heavy duty 3/8 drill will work. Just rotate it quickly... when the generator starts working it will try to yank the drill from your grip so keep that in mind. (Trigger Sw on drill ON)
Kelly
Sep 02, 2009 | Kohler 12 kW Emergency Power System -...
Electrical Supplies Logo
63 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
