Question about Garden
Why does my mower blow smoke out of the muffler?
    Sergeant:
  • 462 Answers
Head gasket or rings leaking
Posted on Apr 23, 2015
5 Suggested Answers
  • 5 Answers
SOURCE: Craftsman riding mower starts, then runs for 30
The smoke is oil going in to the combustion chamber, will have to check for broken rings or piston. also if the tractor was stored in a position that the oil would run to the combustion chamber it will do that untill all the oil is burn
Posted on Mar 22, 2009
  • 81 Answers
SOURCE: muffler exhaust blows debris in front of mower
Most likely the problem if this is a reoccuring problem is that either the muffler flnge or head mounting surface is mis-formed and not totally flat, sometime the easiest and cheapest fix is to get longer mounting bolts and installing multiple gaskets between the 2 surfaces to give more room for forgiveness at the mis-shapen parts, anouther solution I have done is installed a metal deflection plate in the area where the exhuast blows out to deffect the exhaust to an area where it does not cause problems. Hope this helps solve the problem Don
Posted on Nov 10, 2009
Andriod Man
  • 271 Answers
SOURCE: I have a Toro Zmaster
you could have a broken piston ring. check the oil level. if it is ok or low and still smokes or hard to start then you may have to overhaul the engine. let me know what you find.
Posted on Mar 13, 2011
  • 6468 Answers
SOURCE: husqvarna riding mower blowing white smoke out front
check the oil does it smell like gas the needle valve is not seating and gas over flows the carb and dumps it into the crank case
Posted on Apr 30, 2012
17.5 briggs on troybuilt riding mower blows black liquid out muffler on startup.
the black liquid is most likely oil and the smoke indicates the rings are bad or a valve is sticking allowing oil into the cylinder.
you are most likely looking at an engine rebuild
Aug 15, 2014 | Garden
I have recently bought a poluan pro mower. It has been spitting oil in filter and blowing out white smoke from muffler.
sounds like it is overfilled with oil remove oil fill to level line for motor but white smoke means its getting to much gas or is this two cycle engine wich would mean you mixed oil and gas wrong and to make another batch
Sep 22, 2013 | Poulan "Poulan" Push Mower
I have a brand new masport mower, too much oil was put in and it was blowing white smoke, dripped it up drained some out few days later start to mow it'll mow for a few mins the blow alot of white...
make sure oil is at the correct level , remove exhaust muffler drain all oil if any, reinstall and run it until smoke clears , it should not take too long . Make sure engine is cool when working on any component
Feb 25, 2013 | Garden
Lawn mower throwing oil from muffler
If the mower has been tipped it will have sent oil up the breather and into the back of the air filter box, this will soak the paper filer and smoke badly, remove the air filter cover and filter, run the engine with these removed until the smoking stops, now replace the filter with a new one, when tipping the mower only tip it back on the handles, not from either side.
Jul 07, 2012 | Briggs & Stratton Garden
I have a Toro Zmaster mower The engine is a FH580V KAI19. It was running fine. Parked the mower last night, tried to start it today and oil is coming out of the OHV cover and blowing by through the...
Mar 13, 2011 | kawasaki Garden
When I start mower it is ok for about 30 seconds and then a lot of white smoke starts coming out and small drops of oil start to drip onto body
It sounds like a lot of "blow-by" which means the rings or piston is leaking compression in high amounts carrying oil and water vapor to collect onto the vent where it drips.
Jun 16, 2010 | Garden
Blue/white smoke from muffler, but when muffler is removed smoke disappears
Obviously it has had oil or similar inside it at one time or another. Have you given it enough running time to burn all that out? How old is lawnmower & was any work done recently to it?
Aug 03, 2009 | Briggs & Stratton Garden
Oil is leaking from the muffler and white smoke is coming out.
this is more severe.if you are not a small engine person 3 things get a book on mower or take to shop or get a new mower.
not trying to be funny but if you dont know its going to be hard for you to fix the valve guides are bad need to replace will take speical tools to fix.sorry
Jul 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Lawn mower blowing out white smoke
Change the oil...it is diluted with water or gas
Apr 05, 2009 | Garden
Craftsman riding mower starts, then runs for 30 seconds, then pours out white tons of white smoke and sputters and dies. It will then re-start and repeat the same. The amount of smoke is tremendous. It...
Mar 22, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
