Question about Garden
I have huskee rinding mower 26 hp pedal going down how informaci?n can fix
    Sergeant:
  • 462 Answers
Brake pedal or clutch?
Posted on Apr 23, 2015
SOURCE: my husband says our mower wont cut in reverse but i have before
It will cut in reverse, but because of the rotation of the blades and where the discharge shoot is located it doesnt cut quite as good because it is try to discharge the grass on the opposite side of the deck while going backwards. Also, the is a factory installed safety switch that will kill the engine when the transmission is placed into reverse with the mower deck engaged. Because I dont wish for anyone to be accidentally injured do to the safety switch being bypassed i will not tell you how to bypass it. I know it is a pain in the **** that the thing quits everytime you just need to go back a few inches. Just find someone who will show you how to bypass it, its real simple.
Posted on Apr 25, 2009
rockitman187
  • 2559 Answers
SOURCE: need drive belt diagram for LGT2654 Huskee
Here is a link to the manual on pages 7, 8, and 40,
Please take time to rate this a fixya
Posted on May 10, 2009
  • 376 Answers
SOURCE: Huskee jerks while going forward
Go to... http://mtdparts.arinet.com/scripts/EmpartISAPI.dll?MF&App=MTD&TF=Empartweb&Lang=EN&searchDB=MTD&loginID=MTDCon&LoginPWD=&xmlPostDest=http://www.buymtdonline.com/webapp/wcs/stores/servlet/processShoppingCart_10101_19502_-1_19502 Enter the brand (Huskee) and model number, not the one you listed, but the one under the seat... hit search and click on illustrated parts, then click on Mower Deck. That will show you the routing and belt number.
Posted on Jul 06, 2009
  • 150 Answers
SOURCE: I have a MTD GT 1846 Tradesman 18 HP rinding
I use a 2x4 peice and wedge it between blade and deck that will hold the blade so you can apply pressure
Posted on Sep 29, 2010
philwalker78
  • 608 Answers
SOURCE: have new battery, mower crank
The starter solenoid is most likely faulty and not carrying enough amperage to the starter motor. Regards Phil
Posted on Apr 14, 2011
Huskee riding mower cruise control caused gas pedal not to work
yes look under the foot pedal and see if the linkages and springs are in place
Oct 01, 2016 | Garden
Huskee Riding Mower wont start
Try rotating the engine manually to check for any binding. I would also check the amp draw on the starter.
May 21, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a Huskee riding mower- 18.5 hp with 46 inch cut. The mower has 3 blades. When I engage the blades the belt squeals but will go ahead and cut until it gets hot at which time it will stop pulling. The...
check the pullie blade bearing if it is going out it would make the belt squeak and when it gets hot it will make the motor lug down I have worked on mowers for 41 yrs.
Aug 14, 2011 | Garden
Brake wont hold going down or up hill. How do you adjust them
Look in the manual if you can find one. If not drop the deck and take a look at the linkage on the brake pedal. You may well find that the pedal connects to shoes which pinch a small disc in the transmission via a long rod which has an adjustment set of threads and a nut. Either replace the little shoes, or adjust the nut and threaded rod.
Aug 05, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
My huskee lawn tractor will not turn over! The battery is fully charged, it is a 25hp with a 50inch cut, i replaced the selnoid last year!
The arm that engages the cutting blade tends to wiggle. Make sure it is pulled toward you (unengaged) before trying to start.
May 09, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Need drive belt diagram for LGT2654 Huskee
May 10, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
50'' Huskee lawn tractor only turns in one direction
the brand huskee is now manufactured by MTD
Parts are available from tractor supply company at www.tractorsupply.com
there are pages of not very encouraging reviews about the huskee mower or about the tractor supply company but you can contact them to see what you can get
as for the problem , if it is a zero turn unit it may be a clutch arrangement needs adjustment
If you do not get any help from that company, you could ring around the mower repairs shops to get an idea as what could be wrong as the principle of operation will be the same .
also there are sites that have pdf versions of the workshop manual for huskee
May 20, 2017 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
