Question about Cell Phones
Where is the battery at in the phone - Cell Phones
  • Cell Phones Master
  • 3,957 Answers
Normally under the back cover.
Posted on Apr 19, 2015
Batteries in phone but message says insert batteries. Original batteries in phone
I will start by qualifying some answers regarding your device.
  1. Your device was working fine before this issue came up.
  2. This is not a new phone with a new battery install.
  3. The battery is removable.
If your phone/battery was working fine and this happened all of a sudden, then try the following.
  1. Open the phone and remove the battery. Leave it out of the phone for a full minute (don't leave phone on charger while doing this.)
  2. Re-insert battery into phone and power up the device.
  3. If it starts up, then all is well. If not then you may have a bad battery.
  4. If it fails to start, there are two possibilities:
  • Battery is bad, old.
  • USB port is bad and not charging the battery.
As we all know, batteries have a life expectancy given their use and care. Most every phone I have ever purchased came with a statement regarding the "life expectancy and care for battery." It is generally recommended that you let the battery drain all the way down before recharging it so as to "condition" it to hold a charge longer and increase it's life. Also, it is not recommended to leave your device plugged in all the time (past the point where the battery is fully charged.)
Perhaps where you live, there is a phone store which specializes in phone repair, not a branded retailer like "Verizon" or "Sprint", but a repair shop. Do a search for one close by and they will be able to test the battery. Also, you may have a battery store which deals with only batteries who can test the battery for you.
Hope this helps.
Nov 01, 2015 | Panasonic Lands Phones
Tip
How to Check Your Cellphone Model Number
  • For Nokia : Check Off The Battery and look Inside The Phone Or Write : *#0000#
  • For Samsung : Reboot The Phone and the model appears on startup
  • For Sony ericsson : Check Off The Battery And Look Inside The phone
  • For Sharp : Check Off The Battery And Look Inside The phone
  • For Motorola : The Model Number Writed On The battery And Inside the Phone
  • For Siemens : Check Off The Battery And Look Inside The phone
  • For Pocket Pc (Phone) : Writed in the back off the Phone
  • For alcatel : Writed In The Back Of The Battery
  • For LG : Check Off The Battery And Look Inside The phone
Thanks , Fix-shad0w
on Jul 07, 2010 | Lands Phones
Goes from full battery to no power when speaking, power lasts approx 15mins !
Hi, when a phone battery is fully charged and it does not stay long to power the phone,You might need to replace the phone battery.
Phone batteries has cells inside them that determines how long the battery life will last..When these cell dies, it will be unable to power up the phone for too long and the phone will go off..
To solve the problem of charging a battery and not lasting too long,you will need to replace the phone battery with a new one.
You can get a replacement battery from nearest outlet store around your area...
Warning before you buy a new battery, make sure that the phone does not get hot when you insert the battery inside the phone...Because that is not a battery fault. It's a phone board problem.
Take care and thanks for using fixya...
Jun 15, 2011 | Motorola Mobility RAZR V3
I have( LG CE 0168 model),this lg mobile phone but there is some battery problum. so tell me what did i do of that problum. and how because , i live in bijnor and there is lg costumer care but care service...
I have LG CE 168 mobile, But the battery is robbed, So I need to buyy the new battery. I dont know the battery No. So please give me the battery No. ....Thanks
May 23, 2011 | LG KG800 Cellular Phone
After full charge, battery lasts about 1 day, with only "device usage" on the battery.
Phone batteries has cells inside them that determines how long the battery life will last..When these cell dies, it will be unabletopower upthe phonefortoo long and the phone will go off..
To solve the problem of charging a battery and notlasting too long,you will need to replace the phone battery with a new one.
You can get a replacement battery battery from nearest outlet store around your area...
May 23, 2011 | HTC Snap S522 Cell Phone
What does Inval Battery mean when displayed on my screen?
This means your battery isn't properly inserted or the battery is not the specified battery for that phone model..
Open the user manual for your phone and look up the battery information. The exact battery model number is listed here. Compare the model number to the battery you are attempting to use. If the model number is different, you are using the wrong battery.
If you are sure you have the right battery,remove the battery case from the phone Look on the battery for a white piece of adhesive with installation instructions. On the adhesive it states which side should be facing away from the phone.
Slide the battery into the phone following the instructions given on the battery. If you attempt to slide the battery in upside-down or flipped over the phone is not going to power on.
Aug 31, 2010 | Motorola Mobility W315 Cellular Phone
Lgvx2000
Normally a drained battery would take about 30-40 minutes to charge, however if the battery charges in about 2-3 minutes or even faster (as in your case) the fault lies in the battery. If your phone isn't water dropped and is within the warranty period you will get a new battery. I would suggest u change the battery and check (maybe with another battery of a similar make) and then see the results before u could buy one.
Dec 15, 2007 | LG VX8300 Cellular Phone
Charging problems
have you tried your dads battery in your phone it sounds like the battery is dead if your charger works on your dads phone then you know it not the charger the chances are it is the battery it would only be the phone if it has been dropped or got wet if this hasnt happened then the problem is the battery if your dads battery is the same then try charging his batt through your phone that way you would know if it was phone or battery.
If you take the phone into any phone shop they will test the phone and battery for free for you they can try the battery and also try a new battery in your phone and they will tell you if it is phone or battery but from my experiance it is going to be the battery let me know how you get on ok
Nov 27, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
