Question about LG Radio Communications
How can I get my LG 759 blue toth head set to pair with my Iphone 6?
When I first brought it it paired but now it will not pair .
    Top Expert:
  • LG Master
  • 6,702 Answers
Make sure your LG has a compatible bluetooth protocol stack for the iPhone . Read all about it here:
Bluetooth stack
Posted on Apr 19, 2015
IPhone compatible with lg tone Infinim hbs910
Yes, no problem. Just read the instructions on pairing, or click on my Name and then Tips and read my bit on Pairing Bluetooth Devices. I have a number of Bluetooth devices pair to my iPhone 6 and 7. If you have any problems, reply by COMMENT to this post under my name and I will get a notification to help you.
http://www.lg.com/us/bluetooth-headsets-headphones/lg-HBS-910-Silver-tone-infinim
Nov 23, 2016 | LG Cell Phones
How to pair lg Bluetooth headset with ipadair?
on your iPad go to setting-> then down to bluetooth. on your headed set Press and hold the multi-function button for 10 seconds until the indicator light turns blue. It is now in pairing mode. it should show up on your iPad, click on your headset and it should pair.
Nov 26, 2015 | Apple iPad Air
I do I get my LG 759 blue tooth headset to pair with my Iphone?
Make sure your LG has a compatible bluetooth protocol stack for the iPhone . see this: http://en.wikipedia.org/wiki/List_of_Bluetooth_protocols
Apr 19, 2015 | LG Radio Communications
Forgot passcode and cant find manual so i cannot pair it with my new phone
iIf you know how to put ur device into pairing mode then most pass codes or pins\pairing codes are as follows 0000,9999,1111,or 1234 most blue toth manufactures from north america use 0000 i hope this helps but you need to know how to put ur blue tooth device into pairing mode ,usually you hold the power button on for 6 to 10 second untik u have a solid light or tone depending on the device u have..once again i hope this helps
Feb 21, 2011 | Anycom HCC-250 Bluetooth Headset
H681 wont' pair with iphone
Select YES to pair. Enter the passkey 0000 and select OK.
if you have any OTHER devices paired remove them.
1 reset network settings on iphone
2 power off blue tooth device
3 power cycle iPhone
4 attempt to re-pair
Jan 09, 2011 | Motorola Mobility H681 Bluetooth Headset
BlueAnt pairing with iphone...help
Just got off the phone with Apple and Blue Ant tech support.
If everything is workon g on both devices you probably need a memory dump on your headset.
1. Power off both devises
2. Power on iphone
3. Power on blue Ant - not in pairing mode - you should see 1 blue blinking light on MFB
4. Make sure iphone bluetooth is on and searching for devices
5. On Blue Ant, hold both volume buttons and MFB at the same time until you get a fast blinking blue light.
6. Check iphone it should now recognize device.
7. When Blue Ant shows up on phone press it so it completes the pairing priocess
Jun 24, 2009 | Blueant Z9 Wireless Headset
My iphone is not discovering my blue tooth head set, why?
Make sure the bluetooth headset and the iPhone are both in pairing mode. Set the headset in pairing mode first and once set then go and turn on the iPhone bluetooth. It may take about 30 seconds to a minute for it to find the headset. Once the iPhone has found the headset make sure you select it on the phone and it will pair from there - Hope this Helps!!
Jun 08, 2009 | Apple iPhone Smartphone
I cannot remember how to pair BlueAnt bluetooth to new devices
You will need to set the Z9 into pairing mode before your iPhone will find it.
The manual for the z9 is here
With the Z9 OFF, Press and Hold the MFB for about 6 seconds. The LED will appear a solid Blue, and then will start flashing. The Z9 is now in Pairing mode and ready to be found in searches by other Bluetooth devices. Pairing mode will be active for 2 minutes.
Enter Passkey "0000" when your phone prompts you. The phone and Z9 will now Pair.
Mar 10, 2009 | Blueant Z9 Wireless Headset
Multipoint bluetooth wont work with iphone 3g
I actually have both products, and I was able to get my bluetooth to work with 2 phones. All you have to do is first pair your phone with the H721. Then in the phones functions, turn off the bluetooth so it is no longer in discovery or connected...but do not turn off the bluetooth itself, just in the phones settings. Then go to the bluetooth settings in the iphone. you should see the H721 in discovery but not connected. Before connecting it you must put the H721 into discovery mode as well. Hold all three buttons down for 19 sec. it will go solid blue. then push connect on your iphone. onces connected, go to the original phone and turn the setting back on for bluetooth connection. both are now connected. Only one may apear to be connected, but both are. test it with another phone. call each number and you will see that you can now answer both calls with one device. If the iphone is connected and phone 1 rings...the H721 disconnects temporarily from the iphone and connects to the other device to answer it. Hope this helps. Cause thats how I got mine to work.
Oct 27, 2008 | Cell Phones
Radio Communications Logo
65 people viewed this question
Top LG Radio Communications Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
Mohamed Ismail
Mohamed Ismail
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
