Question about Maytag Washing Machines
Lavadora maytag mod. MAH7500AWQ muerta totalmente y si hay voltage
  • Maytag Master
  • 5,323 Answers
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
Posted on Apr 20, 2015
4 Suggested Answers
smartr10U
  • 1305 Answers
SOURCE: quisiera saber si hay que cambiar tarjeta
Checkas aqui... http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=WTW6600&siteCd=WHRCOM porque hay informacion en espanol en los instruciones por tu lavadora.. los instruciones dice: Oprima Pausa/Anulación (PAUSE CANCEL) una vez para despejar el código. Presione Inicio (START). Si el código aparece nuevamente, llame al servicio técnico.
Posted on Jun 05, 2009
SOURCE: como abrir la lavadora LG pues no habre
A lavadora tem uma trava na porta, tem que apertar.. e aii sim puxar para abrir.
Posted on Jul 26, 2010
blueextc3221
  • 15935 Answers
SOURCE: whirlpool lsr5132pqo
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Posted on Oct 01, 2010
Hola buenas tardes Espero que me ayuden en el problema tengo una lavadora tambi?n maytag Washer Epic Z que me est? marcando f01 error en el display Entonces ya desobstruir la bomba el nivel del agua y me...
No hablo a espa?ol, pero tengo un sitio web que traducir. Espero que esto te ayude.
El c?digo de error F1 en esta lavadora indica que la se?al del transductor de presi?n nivel del agua est? fuera del intervalo. La manguera de aire de transductor de presi?n est? aplastado o doblado de la tuber?a puede causar esto. Un transductor de presi?n fallida en el tablero de control de la m?quina tambi?n puede causarla.
Nota: Aseg?rese de desconectar la lavadora para desconectar la alimentaci?n el?ctrica antes de acceder a los componentes internos. Si est? obstruida la manguera de presi?n debe poder volar a trav?s de ?l para eliminar la.
Si no encuentra problemas con el tubo de transductor de presi?n, la Junta de control de la m?quina necesitar? ser reemplazado. En la segunda imagen de abajo se muestra el procedimiento de acceso y sustituci?n de la Junta de control de la m?quina. El n?mero de parte de la Junta de control de la m?quina es W10253697.
Si no te sientes seguro de reparar este problema usted mismo, entonces podr?s repararla en su casa por un t?cnico de Sears.
Sep 15, 2017 | Cars & Trucks
Lavadora lg wm2140c no prende
Si la fuente de alimentaci?n y el cable de alimentaci?n est?n bien, es necesario tener el control principal y el control de usuario y mostrar tarjetas electr?nicas sacar por faltas.
La junta defectuosa hay que ser reemplazado.
Feb 24, 2015 | LG Washing Machines
Mi lavadora maytag neptuno lava perfectamente bien cuando llega al siclo de exprimido semueve mullo la tina y me dise el display que la ropa esta desnivelada la acomodo y buelve astar y gual
nivela las patitas de abajo.. si tu lavada tiene desnivel ( movimiento ) tu lavadora aa lo ismo una y otra ve P espeo te ayude saludos
especialista ZeRoC0ol
Oct 13, 2010 | Washing Machines
Como abrir la lavadora LG pues no habre
Apr 05, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Se activo alarama dogde grand caravan 98 3.3l y no tengo control
Hola estoy intentando siguir su problema. esta es hora punta y tenemos muchas preguntas.
Asegurarse que no hay otra alarma que no es de fabrica. En este caso deberia de haber otro modulo de control de alarma. Alarmas no de fabrica suelen tener un boton de deactivaccion (Valet Key) debajo de la console de instrumentos.
Si el pin 34 esta libre, el alarma deberia ser inactivo. Probabilmente se activo' cuando hizo los trabajos en el coche.
Uno de los pins connectados al ~BCM es el alarma.
La unica manera de deactivar este alarma es enviar un impulso al pin del alarma, descargandolo a terra.
Hay que poner una resistencia de 9KOhm en el medio , de otra forma el alarma no se deactiva.
Aqui la esplicaccion:
"Factory Alarm Disarm Wire (-): This vehicle will disarm with (-) negative through a 9000 ohm resistor, must use single pulse to disarm and a double pulse on this wire will also unlock.
Factory Alarm Disarm Wire Location: N/A"
La esplicacion termina con "Factory Alarm Disarm Wire Location: N/A", sin decir qual pin es el alarma.
yo se de otras fuentes que deveria de ser el pin 34. Por esperiencia personal puedo decir que el connector deveria de estar conectado all bloque de aranque.
El hilo deve de ser blanco y rojo o bien violeto y azul.
Si no se pone una resistencia de 9Kohms en el pin apropiado, el alarma no se quita.
No hay otra manera.
Nov 06, 2009 | 1998 Dodge Grand Caravan
Quisiera saber si hay que cambiar tarjeta
Jun 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
ZARCERO. DESEO CAMBIAR EL RADIO ORIGINAL DE MI SENTRA 2003 YA QUE LA UNIDAD DE CD NO LEE MP3. AL INSTALARLE UN RADIO PIONNER MP3 SI FUNCIONA; PERO SE PERDIO EL SONIDO DEL WOOFER ORIGINAL QUE TIENE...
A lo mejor deberias leer las instrucciones de tu Pioneer. Haveces estos radios tienen settings para bajo. Si esto no te trabaja posiblemente hay un problema con tus conecciones. Estas usando el harness o solamente tape? Creo que este radio tiene salida para bajo a lo cual el woofer deberia estar conectato. Si todo esta conectado correctamente, es un problema de settings en el radio.
May 18, 2009 | 2003 Nissan Sentra
Mstr2kx
Yenny salu2 desde Mexico...
querida amiga lo unico que tienes que hacer es presionar el boton de play por unos segundos asegurandote que el boton de Lock que se encuantra en la parte de atras no este en rojo, eso seria todo, si esto no funciona hay un pequeño orificio en el PD-6070 MP3 player que dice Reset presiona hay y repite la primera instruccion. Yo se que funciona lo hice con el mio. Espero que te ayude esta informacion...
Mar 12, 2008 | MyMusix PD-6070 MP3 Player
Washing Machines Logo
43 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
