Question about LG Radio Communications
I do I get my LG 759 blue tooth headset to pair with my Iphone?
    Top Expert:
  • LG Master
  • 6,702 Answers
Make sure your LG has a compatible bluetooth protocol stack for the iPhone . see this: http://en.wikipedia.org/wiki/List_of_Bluetooth_protocols
Posted on Apr 19, 2015
How can I get my LG 759 blue toth head set to pair with my Iphone 6?
Make sure your LG has a compatible bluetooth protocol stack for the iPhone . Read all about it here:
Bluetooth stack
Apr 19, 2015 | LG Radio Communications
I need the passkey for a Lg-230 blue tooth headset
Most blue tooth manufactures use a 4 digit pin or pairing code you first must discover your device you have to put the device in discovery mode once you have done all taht and you are asked for the pin or pairing code they are as follows 0000,1234,1111, or 9999 i hope this helps
Feb 20, 2011 | LG HBM210 Bluetooth Headset Wine Red Color
My iphone 4 cannot discover my BlueAnt Z9i. I put the headset right on tp of the phone and it just says "seaching". The headset is on and phone's bluetooth is on as well
First you must turn your power to the blue tooth to on in the phone menu,then you have to put your blue tooth device in discovery mode,most blue tooth device manufactures use the power button,by holding it down for 6 to 10 seconds when turning on the device it should have a solid light the you can add or search for device ,they will pair if you have your power on and your device in discovery mode once they pair you will have to enter a pin or pairing code.Most blue tooth device manufactures use a 4 digit pin pairing code they are as follows 0000,1234,1111, or 9999 i hope this helps
Feb 19, 2011 | Blueant Z9i Bluetooth Headset
Pairing with iphone4
Select YES to pair. Enter the passkey 0000 and select OK.
if you have any OTHER devices paired remove them.
1 reset network settings on iphone
2 power off blue tooth device
3 power cycle iPhone
4 attempt to re-pair
Feb 06, 2011 | Motorola Mobility HS820 Consumer Headset
H681 wont' pair with iphone
Jan 09, 2011 | Motorola Mobility H681 Bluetooth Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
User manual for LG HBS-110 bluetooth headset
To pair the headset with your phone:
Turn on the headset. Then turn on bluetooth in your phone and search for bluetooth device.
When your headset is detected, just select it and follow onscreen instructions to pair it with your phone.
Jun 08, 2009 | LG HBS-110 Wireless Headset
My iphone is not discovering my blue tooth head set, why?
Make sure the bluetooth headset and the iPhone are both in pairing mode. Set the headset in pairing mode first and once set then go and turn on the iPhone bluetooth. It may take about 30 seconds to a minute for it to find the headset. Once the iPhone has found the headset make sure you select it on the phone and it will pair from there - Hope this Helps!!
Jun 08, 2009 | Apple iPhone Smartphone
LG VU does not recognize my blue tooth while trying to pair two
Help my pair my bluetooth with my LG shine phone. I have a jawbone bluetooth.
Mar 23, 2009 | LG Shine KE970 Cellular Phone
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Radio Communications Logo
61 people viewed this question
Top LG Radio Communications Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
Mohamed Ismail
Mohamed Ismail
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
