Question about Gatehouse Gallo Polished Brass Tulip Residential Keyed Entry Door Knob
Replacing knob with drive in latch
I have kwikset locks on myvsteel door with the drive in latch. I purchased a gatehouse brand lock and it has a square plate on the door jamb. Can I remove this from the "new lock" and use the existing drive in latch.
Exterior door stuck closed manually retract ****** remove knobs KWIKSET
You will probably need to replace the latch assembly. There is a small rivet that holds part of the latch together, and it also acts as a pivot point for a small piece that retracts the latch. If it gets bent, the latch won't retract fully, but you might be able to push it back and get the door open.
May 24, 2014 | Kwikset 740ll 3 Smt Lido Keyed Entry Lever...
Remove collar from latch kwik set door knob
There are two small bumps on the latch body, which snap into two holes on the collar. Use a small screwdriver to get the collar over the bump on top or bottom, then repeat for the opposite side.
Apr 09, 2014 | Kwikset Drive In Collar for 6-Way Core...
How to remove gatehouse door knob?
Look for a small set screw on the side of the deadbolt on the inside of the door loosen the set scrww and remove the cover to expose the screws that hold the door knob on
Oct 31, 2013 | Gatehouse Springfield Satin Nickel...
Re-assemble a kwikset front door lever and knob type latch
Since the exterior side of the lock only has a keypad and no lever, I'm not sure what you mean by the "outside lever". Here is a clear, easy to follow video of the installation. Please carefully review each aspect of your installation against it to see if you can spot an installation mistake:
http://www.kwikset.com/Videos/Vitro/smartcode.aspx
Sep 03, 2012 | Kwikset 909 909-L03 Lifetime Polished...
I am replacing my door knob and replacing it with similar lock door knob by Kwikset. I measured from the end of the door to the middle of the hole where the knob goes into which is 2 3/8". The problem...
Most kwikset locksets will work on either 2 3/8 or 2 3/4 inch setback. There should be two holes on the latch where door knobs fit thru the door. If yours does not have this option I would suggest that you get one that will match your setback.Hope this helps.Thanks.
Nov 16, 2010 | Garden
How to remove a tumbler from kwikset entry knob ?
You need a kwikset removal tool. Search kwik set core removal tool to take you to a lock smith supply, or try to buy one locally.
Notice, purchase of this tool may not be legal in your juresdiction and MIGHT be considered burgary tools.
Dec 23, 2009 | Kwikset Professional Door Lock...
My door handle came apart and now I have the pieces and don't know how to put them back together. Kwikset, chelsea door handle.
I assume the latch mechanism is still intact... the piece on the edge of the door that locks inside the strike plate when the door is shut -- if that's the case the only thing left to do is align the two knobs, one on iether side of the door, making sure the shaft goes thru the latch mechanism properly (it only fits thru one way) and then sandwich it tightly to the door and tighten it together with a phillips head screwdriver... some kwikset locks require you to turn one of the knobs to get the bolt heads to seat properly.
I'm not familiar with the chelsea model but they are all very similar... if you have more than the 2 knobs with a long shaft on one then chances are the solution above does not apply... you probably will have a knob with shaft and then a flat plate with holes, a finished plate and a plain knob... in this case align the knob and shaft thru the latch mechanism, place the plate with holes on the other side of the door and twist it slightly so the bolt heads lock in and tighten the bolts to the plate... now snap the finished plate over that and push the knob over the exposed shaft that remains... you'll need a flat head screw driver to lock the knob on where a small spring loaded piece fits into a cutout on the handle...
that's about the best I can explain it.
Mar 30, 2009 | Hardware & Accessories
Changing doors would like to know how to take off kwikset door
remove the two screws on each side of the door knob from the inside of the door use medium size phillips head screw driver
pull the door handle off
remove the handle from exterior door side
remove two phillips screws from the side door that hold the door bolt pull the door bolt assembly out
reinstall on new door
insert bolt assembly
insert knob for exterior side(a lign it up
insert knob from interior side and align screws and tighten ligtly
check door for easy turning of knob and actuating latch
good luck
remove that assembly
take screw driver and remove the two scres that remove the plate on the side of the door and
Dec 29, 2008 | Kwikset Professional Door Lock...
Gatehouse Gallo Polished Brass Tulip Residential Keyed Entry Door Knob Logo
460 people viewed this question
Top Gatehouse Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Gatehouse Hardware and Accessory Expert? Answer questions, earn points and help others
