Question about Hotpoint RLA30 Compact Refrigerator
Build up of ice
A thick blanket of ice builds up at the back of the fridge. Could this be the thermostat?
  • 2angels Jun 20, 2008
    I have the same problem. Where can I find the thermostat? My father-in-law is a qualified electrician and he will be able to get it replaced for me.
    Thank you.
  • Anonymous Mar 24, 2014
    thick ice builds up around the coolant tubes leading to and from the evaporartor plate and gradually spreads over the immediate area of the plate itself.
  • 139 Answers
YES
The thermostat is not cutting out.. It needs to be replaced.. Your compressor risks burning out if its is continoulsy running ...
Posted on Nov 14, 2007
Just did a defrost due to large build up of ice. I took off the back panel of freezer and found fan was encased in ice.
No this time the fan was the cause of the ice build up and the fridge will be damaged if the fan problem is not resolved. What is the model number of your fridge?
APPLIANCE 911
Dec 07, 2015 | Refrigerators
Frost free fridge freezer build up of ice
The defrost timer has quit.
They have a relatively short life.
Jul 25, 2015 | Hoover Refrigerators
Possible problem with ice build up and fridge doesnt get cold enough to store food. Freezer works fine.
The noise is due to the ice build up in your evaporator. The evaporator fan blade is rubbing against the ice build up. This can is designed to turn off when you open the door. As far as the defrost problem it can be your defrost bimetal thermostat, the defrost timer/control or your defrost heater.
Nov 07, 2013 | Samsung Refrigerators
Fridge not staying cold and build up of ice on back piping
One of you fans is not running and causing the compressor to eventually making your compressor overheat and eventually shut off
Apr 14, 2013 | Refrigerators
Food not getting cold in the fridge
There are many reasons for that to happen.
Check your refrigerator for a thick build up of ice in the freezer, you need to defrost the fridge.
A poor circulation of cold air will happen if thick build up of ice is not defrost.
Do not block cold circulation with so much food inside, you need to organize it.
Check temp control to lower degrees or high number.
A door gasket leak will cause cold air to flow outside the fridge.
A system tubing clogged dirt inside the copper tubing will also cause it, but this one need to be check by a service technician.
I hope I give you idea for your refrigerator problem.
Jun 26, 2011 | Dometic NDR 1292 Refrigerator
Fan in freezer very loud noise
There is probably an ice build up behind the plastic rear panel. The ice build up gets so thick that eventually, it obstructs the fan and then you get that loud noise as the tips of the fan are chipping away at the ice.
What you need to do is to remove the rear panel and thaw the ice build up. To remove the rear panel is usually only 2 screws at the bottom.....you will find that the panel is difficult to remove due to ice build up behind it, so gentle heat from a hairdryer is a good way to accelerate the thawing process....once the panel is removed, you will see the ice build up......mine was about 2 inches thick!!!
I used the hairdryer to thaw it all out and then once cleared, switched it back on and have never had a problem since.
By the way, my F?F is a Beko CDA563FS......the one with the water dispenser on the front and frost free.
Hope this helps
Feb 01, 2009 | Freezers
Ice build up
Check that the door is closing properly otherwise the freezer will be working overtime to cool and ice will form. If the door seal is good, it is possible that the thermostat needs to be checked.
Oct 02, 2008 | Refrigerators
LG LRFC22750 Bottom freezer french door refrigerator
6343ed3.jpg The problem is ice build up on the back wall. The noise you hear is the fan blades hitting the ice. On the back wall water gets trapped, it then builds up over time, and a big ball of ice forms and blocks the fan. Take off the back wall, defrost the build up and cut the insulation off as above. The water will no longer get trapped and the problem will not come back.
Sgt 48
Feb 13, 2008 | LG LRFD25850 French Door Refrigerator
Kenmore fridge
First we need to see if the compressor is running.  Pull the fridge out take off the lower panel on the back and see if you can hear it running.  Also, need to know if freezer fan and fan by compressor is running.  Check for thick frost build up on back panel in freezer.  Let me know what you find.
Oct 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Hotpoint RLA30 Compact Refrigerator Logo
175 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
