Question about Kitchen Ranges
Smells electrical when running - Kitchen Ranges
  • 3,961 Answers
Unless it is very new, this would indicate some of the wiring is getting too hot. Since stoves are not normally wired through a safety switch, get it checked by an appliance electrician. You do not want a fire.
Posted on Apr 19, 2015
When dryer running there is a burning smell
Clean the lint trap and make sure you have good fan operation. Check your outside vent for good air flow. Could your burning smell be electrical wiring? Does it smell like plastic burning or lint burning?
These are things one needs to know in order to locate the trouble.
Feb 03, 2016 | Whirlpool GEW9250 Electric Dryer
BURNING SMELL AND CAR SHUTDOWN
Not good. Better have that car checked out asap by a qualified electrician since you have a nasty situation there. Smells like a massive short has invaded your car.
Aug 22, 2015 | Cars & Trucks
Kenmore Elite Oasis 6806 Electric dryer with burning smell
you must disassemble the unit and clean the lint out of the heating unit area, it is lint catching fire and could be dangerous to continue using your unit in this condition. a vacuum cleaner should do well to clean the lint and the drum must be removed to do a proper cleaning
Apr 15, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
My washer keep shorting out why is this
It may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell.
If the washing machine is old (15 - 20 years) you could have nuisance tripping on aGFCI outlet, however that doesn't mean you get rid of the protection of the outlet, it means you probably should consider replacing the washing machine for a newer model.
Apr 30, 2011 | Washing Machines
Bit of an electrical burning smell which may get worse on the drying cycle? also, how do you set the self diagnostics running?
Electrical burning is a bad sign. Unplug it and have it serviced! When you smell electrical burning that mean the resistance on the circuit has increased beyond the acceptable thresholds and the safety features such as ground fault, fuse and breakers are not operating. This is the cause of 100% of electrical fires! Take it seriously.
Jan 25, 2011 | Dishwashers
I smell an odor possibly electrical but I was unsure and had the gas company come and check. The gas company serviceman states the gas connections are good, nos gas smell in any areas of the house. The...
You should have an Amp draw on the system and it's motors. Your nose will be your guide in figuring out what component is getting hot. Smell circuit board and electric motors.
Jan 16, 2011 | Ruud UBHC Air Conditioner
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Electric burning smell from dryer
first check your dryer vent hole and dryer wall vent to make sure there not clogged with lent,most of the time that's what it is,let me know and we can go on from there-mike
Dec 17, 2008 | Dryers
Engine runs rough, or dies when the defroster is turned on!
get your heater core checked out. the heater core is right by the blower motor and if its busted it will blow the smell into your car.
Nov 15, 2008 | 2002 Mitsubishi Eclipse
Burn Smell (electrical) from my GE WPSE4200A0WW
We have the same problem, and found out the the electric motor is running very hot. Replacing the motor seam to cure the problem, but the motor is not inexpensive. $200 to $350.
Sep 04, 2007 | GE WBSR3140DW Top Load Washer
Kitchen Ranges Logo
52 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
