Question about Refrigerators
Accidentally left the freezer door open, and ice crystals formed.
Reset the temp. controls, ice crystals are still there. Should I defrost? Can I? How?
  • 3,961 Answers
You can defrost by turning off the power and leaving the door open, but if it is a frost free model it should gradually rid itself of ice at normal temp settings. This may take several days.
Posted on Apr 19, 2015
Icy crystals forming on food in freezer
Ice crystals forming on Frozen items in the freezer is an indication of an air leak caused by either a bad seal leaking seal or an open door to the ice maker Ice chute door
Appliance 911 Sea Breeze
May 17, 2016 | Frigidaire Refrigerators
Upright freezer door was left ajar. The alarm keeps sounding, can you tell me where the reset button is located.
Hello Deena;
My name is Peter. I am a retired field service refrigeration technician.
There is no reset for the alarm. The alarm goes off when you are not maintaining temperature.
During the time the door was ajar, warm air got into the freezer either icing up and locking the cooling fan or forming a block of ice on the cooling coils (Restricting cooling air flow.)
The best thing you can do, unless you want a $300.00 plus service call to defrost everything, is to turn power off to the freezer. Open the freezer door. Have plenty of old towels to soak up the water in the bottom of the freezer as it defrost.
You did not provide a model number which is located on the inside wall of the freezer. Every 8-10 hours your freezer will completely shout down for 20-30 minutes where only the light works and the defrost heater turns on. The ice build up is too much for the defrost heater to handle.
In some freezers the defrost mode is in the control board, in others it is a separate component that you can repeat trip using a flat head screw drive.
Jan 26, 2016 | Freezers
Freezer door accidentally left open. back of freezer iced up. can using a hair dryer carefully thaw the defrost and thermostat controls and get normal function?
it could be used provided that the drier was not on high and too close to the units
Sometimes it is jut better to leave the door open with a fan running full blast into the freezer as the continuous supply of air will defrost it quickly
place old towels /rags at the door opening to soak up the water
Aug 28, 2015 | Refrigerators
Freezer is running constantly. ice crystals formed on outside of packaged foods. food is still frozen.
the door was left open,if you find frozen water droplets on the food packages or ice crystals it forms from the warm air coming in,make sure all the packages are pushed in and not hitting the door and you can tilt the fridge back a little so the door will close with a slight push.also check the ice shout door and make sure no air is leaking through it,you'll know you'll see all ice around it.you can check the condenser coil and condenser fan to see if it needs to be vacuumed,the machine will run longer if the coil is clogged with dust or if the fan isn't blowing,the coil should be cleaned every 6 to 12 months.hope this helps but it sounds like the freezer door was left open.
Sep 06, 2011 | Frigidaire FRS23KF7AB Side by Side...
Hotpointt FFA80 freezer door kept opening on its own. noted that ice had formed and was pushing drawers against door. cover removed from coils and found solid with ice. left to defrost but when plugged...
Does the light inside the fridge come on? if it does then you are getting power. If not you are not getting primary voltage. As far as resets or cut outs there is three things that can stop the power to the compressor 1 the cold control (thermostat you set to raise or lower temp) 2 defrost control that is suppose to cycle and put the fridge into the defrost cycle about one time every 24 hours. 3 the over load heat activated cut off that is a small round device usually on the side of the compressor (the big black round can that is in the bottom of the fridge) Since ice formed I would check the defrost control first. It is a timer that should advance slowly on its own but usually can be turned by hand to advance to the defrost position. the defrost timer is usually at the bottom of the fridge and many times can be seen from the front of the fridge when the "kick plate" or bottom grate is removed. if you can find the little knob on the defrost timer try to turn it to the right (clock wise) and see if anything changes. Since the ice formed either the heat element that defrosts the coils or the defrost control has probably stopped working.
Apr 22, 2011 | Refrigerators
Freezer has defrosted on its own. Red freezer high temp light will not go off.
Door has accidentally been left open. Have missed a proper defrost and ice has built up internally. Switch off and do a 12 hour defrost. then switch on again. (Thats where i would start.).Because fan is stuck in the ice, it cant blow cold air to the sensor. Sensor detects this and shows red error light.
Nov 13, 2009 | Hotpoint FFM70 Bottom Freezer Refrigerator
Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
Charlie
May 07, 2009 | Refrigerators
Whirlpool refrigerator side by side Ice control
its a defrost sensor that reads the inside temp of your freezer so it knows when to defrost itself.you need to close it so it wont allow th freezer to freez up.
Oct 12, 2007 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
