Question about Toro Garden
How do I replace the spark plug on my Toro LX 427 lawn tractor
  • 1129 Answers
SOURCE: Toro lawn mower. Have trouble starting(starts and
Remove the float bowl located under the carburetor it is a 1/2 bolt some gas will poor out so put a rag under the carb to soak up the gas, you actually may want to use a small container to collect the gas or make sure the gas tank is empty, remove the float bowl after removing the bolt by grasping it and turning, the bowl will most likely have debree and water in it clean with a rag and solvent and reinstall, becareful of the ruuber ring gasket when reinstalling the float bowl, one some movers there is no float bowl if you have this type of engine the tank and carb must be removed disassembled and clean out. Do not store mowers uncovered they must be covered when not in use, water gets into the fuel system and causes this problem.
Posted on Jul 14, 2009
  • 143 Answers
SOURCE: Non-starting Toro lawn mower
If the mower was lying up for a time you will need to remove and clean out the carburettor and fill with fresh fuel.Stephen.
Posted on Nov 09, 2009
SOURCE: Our Toro Personal pacer Model 20031 lawn mower will not start;
i turn the key and it grinds
Posted on Dec 06, 2009
heres2maine
  • 84 Answers
SOURCE: Have a Toro LX 465 lawn tractor, won't start;
Could be your coil. Might be bad or it went out of gap. Gap is .10
Posted on Jul 10, 2010
2strokeJim
  • 577 Answers
SOURCE: what is the spark plug gap for a Toro 450, GTS2
most generally out of the box your good to go! not like the old days !
Posted on May 17, 2011
What is wheel drive belt size for toro lx 426 lawn tractor
Motion drive consists of two belts,
Engine to variable speed pulley 5/8 x 90-1/2
Variable speed to transmission 5/8 x 42
May 30, 2015 | Toro Garden
What's the proper gap for a toro mower spark plug
Spark plug gaps for lawnmowers and lawn tractors are not as critical as they are for motor vehicles. Generally, an acceptable spark gap is anywhere between .025" and .035".
May 13, 2015 | Toro Garden
I drained my oil in my toro and it had gas in it lx420
the float in the carb is stuck open allowing the cylinder to flood with fuel. Clean or replace the carb and try it again
Feb 03, 2013 | Toro LX Lawn Tractor Rear Tire Chains (20"...
Where is the fuse box on the toro lx 425 lawn tractor
MOST LAWN TRACTORS DO NOT HAVE A FUSE BOX. SEE IF THERE MAY BE A IN-LINE FUSE.
May 26, 2012 | Toro Garden
How do I change the drive belt on a Toro LX466? Also, what would cause this lawn tractor to go thru one drive belt a year since 2008?
well I have a Lx 500 and the problem is that the bearings on the pulley shafts are wore out, makin the pulleys hard to turn or dragging heating up your belt. It heats up from the friction of the pulleys not free spinning like they should. next time you have the belt off check out the pulleys and see if they spin freely that will be the tale tell sign.
May 04, 2011 | Toro LX466 22HP Lawn Tractor 13RT61RH244
Garden Logo
60 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
